Old 09-30-2012, 12:20 PM   #13216
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,097
Send a message via Skype™ to shearboy2004
Or... Maybe on the bent end, you can take that cut off wheel and grind away only the part of the shaft that is pushed to the back. Can't tell from the picture if you can get all the bent part or not. Pull the seal and you might get a better idea. You could just cut the bent part off, but that eliminates any possibility of straighting the shaft back to remove it. More than likely, it's bent all the way to the bushing (I hope there's a bushing in there) and you won't be able to get to it. When you get it apart you'll be able to tell where the bend is by pushing the shaft back and forth.
Pretty sure it will be bent all the way back to the case , it's a plain bushing ,meaning there isn't one just alloy , tempting to try heat but the fallout is really bad if things went wrong .
I have another shaft here and looking at it last night came to the same conclusion as you in grinding the clutch end down and pushing it through .
It will be a time consuming project I'm sure, but beats splitting case's
I'll wait the rest of the day to see if anyone else bainstorms my wee problem .
Thanks Guy's .
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 450 called BLING.
07 Sherco 510 called Holy Shit .
shearboy2004 is offline   Reply With Quote
Old 09-30-2012, 01:40 PM   #13217
original mcguiver
original mcguiver's Avatar
Oddometer: 19
I would not be afraid to heat the shaft and straighten it enough to remove it or still use it. If you think about it, the case was strong enough to bend the shaft to the rear without breaking and the case looks stronger to the front. You will need to use a pipe that fits over the shaft pretty snug. Heat it on the side of the shaft facing the back of the bike with an acetylene torch :note it doesn't have to be Red hot.,, Hope it works out for you. (I have done this myself more than once, successfully)
original mcguiver is offline   Reply With Quote
Old 09-30-2012, 01:45 PM   #13218
shearboy2004
KIWIINUSA
Oddometer: 4,097
This is exactly what I was wanting to hear Mate !
Lucky you chimed in , I have washed the bike and just waiting for it to dry before I was going to pull the clutch side off and go for it with a grinder if I didn't hear from anyone .
Thanks .
88 R100GS
98 DR450
Old 09-30-2012, 02:37 PM   #13219
shearboy2004
KIWIINUSA
Oddometer: 4,097
OK I have been over thinking this problem , I went out looking for something to fit over the shaft and found a set of handle bars that came close , while trying the fit I thought I would give it a bit of a push to see how mild the steel was and it move and in fact moved straight. That shaft was not the hardened crap I was thinking it was going to be .
Thanks for the input Guys
88 R100GS
98 DR450
Old 09-30-2012, 05:15 PM   #13220
Crenshaw
Bum
Oddometer: 82
I love it when a plan comes together.
Crenshaw is offline   Reply With Quote
Old 10-01-2012, 01:46 PM   #13221
nickgindy
Doing it Wrong
nickgindy's Avatar
Oddometer: 1,363
Send a message via AIM to nickgindy Send a message via Yahoo to nickgindy
Alot of pages here. Anyone have a lowered dr they take off road? If so how does it do?
2003 Sv650s; 2012 BMW F650GS; 1999 Suzuki Dr 350se
"I guess a klr is the perfect bike for people of Walmart." - dougfromindy
My Youtube Channel
nickgindy is online now   Reply With Quote
Old 10-01-2012, 02:03 PM   #13222
MrPulldown
MrPulldown's Avatar
Oddometer: 1,270
Originally Posted by Stretch67 View Post
Wanted:
Street-legal frame - DR250S, DR250SE, DR350S, or DR350SE. MUST HAVE INTACT AND LEGIBLE V.I.N. DATA PLATE.
Needed in order to swap into my '94 DR250SER. I found a couple frames on eBay, but was hoping an Inmate here may have one he needs to unload.
PM here on ADV or email stretchman67@gmail.com
Thanks.
Look what I jsut picked up this last weekend.
Too bad only one of the frames has a VIN plate, and I want that one. Sorry. Thsi whole missing VIN plate thing seems to very common.
Some other weird things. This looks like some kind of vac operated fuel pump.
Also came with an old school Acerbis tank. Vac petcock.
94 DR 350 SE
MrPulldown is offline   Reply With Quote
Old 10-01-2012, 02:15 PM   #13223
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,202
Sweet.
Speaking of Suzuki VIN's... any idea what a 'D' 4th character indicates? 'S' is Off-Road, and 'N' is for Single-Cylinder Sport Street Bike. I've run across a couple DR350 frames with 'D' for the 4th VIN digit, and I can't find a decoder for that.
http://www.suzukicycles.org/_misc/identification.shtml
Edit - It seems the 'S' (Off-Road) 4th-digit does not indicate that the bike isn't street-legal. Off-Road is merely the style of bike, as compared with 'Multi-Cylinder Sport Street' which is 'G'.
I haven't seen this written anywhere, but 'D' seems to indicate 'Dirt' (not street-legal). The dirt-only DR frames I've looked at carried the 'D' 4th VIN digit, and had the bolt-on tank and no passenger footpeg mounts, which are indicative of dirt-only DR's.
Stretch67 screwed with this post 10-01-2012 at 10:04 PM
Stretch67 is offline   Reply With Quote
Old 10-01-2012, 02:21 PM   #13224
Ghostyman
Ghostyman's Avatar
Oddometer: 129
I believe that is the California model charcoal canister.
Ghostyman is offline   Reply With Quote
Old 10-01-2012, 02:41 PM   #13225
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,202
Deleted
Stretch67 screwed with this post 10-01-2012 at 10:02 PM
Old 10-01-2012, 02:45 PM   #13226
MrPulldown
MrPulldown's Avatar
Oddometer: 1,270
That would make sense. Seems very stock. Yet I do not have one on mine since I got mine from Nevada. The fact that it was connected to the carb is what threw me.
94 DR 350 SE
Old 10-01-2012, 03:22 PM   #13227
Teeeeeemu
Oddometer: 104
Man theres so much "unneccessary" crap on that bike. All I have on my subframe is fender, side panels, exhaust and airbox
Teeeeeemu screwed with this post 10-01-2012 at 03:46 PM
Teeeeeemu is offline   Reply With Quote
Old 10-01-2012, 04:52 PM   #13228
mustangwagz
mustangwagz's Avatar
Oddometer: 192
My head...
Put my spare head on Ebay guys, im sure some of you have seen it already (have 13 watchers) cleaning out my stash of stuff that i have rationed in the garage. Trying to pay down the PayPal account. lol if anyone has wants or needs for misc parts and pieces, let me know?
-WagZ-
-WagZ-
'93 DR350S
**WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details.
mustangwagz is offline   Reply With Quote
Old 10-01-2012, 06:13 PM   #13229
tntmo
Oddometer: 229
I wouldn't worry too much about the missing VIN plate, they stamp the frame for a reason. If the DR frames have passenger peg mounts, they are street legal frames from the factory. Another visual clue would be the gas tank mounts, street legal uses the rubber bumpers and the dirt model has the bolt mounts.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 10-01-2012, 07:30 PM   #13230
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,202
Originally Posted by tntmo View Post
... If the DR frames have passenger peg mounts, they are street legal frames from the factory. Another visual clue would be the gas tank mounts, street legal uses the rubber bumpers and the dirt model has the bolt mounts.
Times are GMT -7.   It's 09:10 PM.
