10-05-2012, 02:47 PM
#13291 | |
Bum
Oddometer: 82
Went after the parts with micrometer this morning and everything is great other than the piston itself being right on the limit of wear. I would like to replace it mostly for peace of mind. The difference in price between 385cc kit and stock parts is almost a wash. There's a local machine shop that I trust to do the bore and head work without taking me to the cleaners. Am I correct in thinking the 385cc piston (83mm) is the largest that will fit without a resleeve? |
10-05-2012, 03:42 PM
#13292 | |
Oddometer: 104
Update on my spark issue: Kickstand safety wire wasnt grounded ![]() ![]() ![]() But now it sparks like before, one less problem!
Teeeeeemu screwed with this post 10-05-2012 at 03:52 PM |
10-06-2012, 05:36 AM
#13293 | |
mc caregiver
Oddometer: 2,606
dont button it back up until you are sure the basket spins freely, almost loosely when cold. |
10-06-2012, 06:56 AM
#13294 |
Bum
Oddometer: 82
+1. ~40 ft/lbs is hardly anything. Not sure what your impact gun is rated for but my beat up IR will usually torque to at least 150. I would be surprised if the threads for the clutch basket nut can even handle that.
10-06-2012, 07:52 AM
#13295 | |
Oddometer: 233
27 CABLE ASSY,SPEE 34910-12E00 (replaces 34910-14D13) 1 $33.49 That is off the microfish from my local dealer, I need one to, since no one has any other comments I guess this is the route I will go |
10-06-2012, 07:56 AM
#13296 |
Oddometer: 104
Theres tons of speedo cables for under $15 in ebay. It isnt oem but I dont think oem is worth twice
10-06-2012, 08:28 AM
#13297 | |
Oddometer: 520
http://www.ebay.com/itm/Suzuki-DR350...sories&vxp=mtr http://www.ebay.com/itm/Motion-Pro-S...&forceRpt=true |
10-06-2012, 08:39 AM
#13298 | |
Oddometer: 611
Regards, Gregory Bender |
10-06-2012, 11:41 AM
#13299 |
Oddometer: 233
Ordered the motion pro from ebaay, we will see how it goes
10-06-2012, 02:17 PM
#13300 |
Oddometer: 32
Thanks Plugeye and crenshaw! I did go back in it last nite and torqued the nut to spec.That fixed my clutch problem but I got te shift mechanism off when I put it together so now all I have is 1st gear.This has been a learning experiance! So I going back in it for the 5th or 6th time,hopefully I'll get it right this time..
10-07-2012, 07:00 AM
#13301 |
Oddometer: 54
Sorry to jump the clutch bandwagon, but I finally got into the clutch on my 99 SE to see why it wasn't working right and want to glean as much wisdom as I can while it's going around. I really want to do this myself rather than sheepishly trucking it to the dealer - more so that I know than to save cash.
Problems included hard shifting and the clutch not fully releasing, even with lever all the way to the bars. Neutral was next to impossible to find, unless engine was off and even then difficult. First thing I checked was cable adjustment which was within spec. - I drained the oil (which looked brand new, literally - I think there was less than 100 miles on it) and opened the cover to find everything looking new. Most parts ARE new, having been replaced by the PO but this bike hasn't been abused. - I checked the disks; they were flat when checked against a tablesaw table. - The basket rotates side to side easily, but with no play on its shaft - does that mean that it doesn't need clearancing on the back? - The shift drum bolt seems tight when I put a wrench on it, but the head is 1-2mm above the cam gear assy, or whatever it is that the bolt is holding down. I haven't removed the basket yet - I'm not sure what would be different behind it. The thrust washers are new, so can't be worn yet and I'm loathe to work the lock washer too many times. This would be its second bend. ? Do I need to pull the basket to check on the drum bolt? ? If I have to pull it, what's the best technique to undo and redo the lock washer without gouging the clutch hub? I plan to follow the advice on Maximumsuzuki about pop riveting some old disks together and using a penny to jam the gears if I have to pull it. ? Drum bolt. When I put the wrench on it, it wasn't loose and moving the wrench just moved the cam gear, which is pretty much what's supposed to happen - correct? Again, no slop in it just the slight space under the head. ? Is there a break-in period for new disks such that they grab for a while until they bed in? Anyway, any help appreciated as always. It was fun getting in there yesterday and today looks like another chance to hang out in the shop working on the bike so a good day. - Spad
___________ 06 Wee Strom 82 CM450E 99 DR350SE |
10-07-2012, 07:12 AM
#13302 |
Oddometer: 104
1 Yes
2 I jammed something between the swingarm and rear wheel. Not the best but only way for me 3 Correct. I have the gap on there too. 4 Yes. This sounds like your only possible reason. I dont know how the basket should move but it could be that too. I also just clearanced my hub and put in new plates and springs but havent had the chance to ride yet. Everybody has clutch problems haha |
10-07-2012, 07:20 AM
#13303 |
Oddometer: 54
Thanks so much for the quick response (and others welcome too). I don't mind clunky shifting, but if it wants to stall when I stop the bike or I can't get it into neutral it needs fixing.
- Spad
10-07-2012, 09:19 AM
#13304 | |
Oddometer: 520
2bold2getold screwed with this post 10-07-2012 at 09:30 AM |
10-07-2012, 09:20 AM
#13305 | |
Oddometer: 104
Couldnt find neutral at all while the engine was running.Now just have to hope for the best Page 888 wohoo!
