10-10-2012, 04:17 PM
#13336 |
wandering the desert
Oddometer: 680
Got the molle panels in, for $9 each they sure beat the $180 Tank Vest.
I attached a holster on the right side, I had this one laying around from an old vest. I really wanted it on the left so I'll probably order a left handed one whenever I get my Acerbis tank on here. But for now, I can still work my left hand over and use this if need be. ![]() I put a water bottle holder/storage pouch on the left side and still have room for other things like a gps holder. Plus the molle panels have internal storage large enough for maps. I'll end up trimming the excess off the straps once I get the Acerbis tank on here. ![]() For $20 I can't complain.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
10-10-2012, 05:51 PM
#13337 | |
Oddometer: 54
As to getting help, I am - from Kientech. I went back and forth for a while, but I really don't mind drilling and tapping (well, I do mind chipping out old bolts). In the end, I'd just end up with an equally lame bolt in a hole that might end up if anything slightly oversize. This way, I'll have a stronger bolt there. One of the reasons I got this bike is that it's a good one to learn wrenching on. Parts are still available, and it's not my regular ride so if I take a while I'm not left high and dry. -Spad
___________ 06 Wee Strom 82 CM450E 99 DR350SE |
10-10-2012, 06:03 PM
#13338 |
Oddometer: 21
quick question, the idle mixture screw, do you turn it out for more fuel or in for more fuel? i think im idling a lil rich and want to lean it out but im not convinced im turning it the right direction it starts and idles great but just seems to smell a lil rich
10-10-2012, 06:31 PM
#13339 |
Oddometer: 485
I weighed my "98 DR350se (legal, e-start) the day I got it. With half tank (~ 2 gallons) it was 302 lbs. I don't find it top heavy at all. Not like the KLRs. I'm 6'- 160lbs. On a recent trip, about 50/50 off road with some single track, it averaged 68mpg (other models/your results may vary) at 7k ft to 12k ft in the northern NM mountains. Motor is stock with stock gearing, and has 325 frt and 510 rear Kenda K270s.
2bold2getold screwed with this post 10-10-2012 at 08:37 PM |
10-10-2012, 06:57 PM
#13340 | |
Oddometer: 485
10-10-2012, 07:47 PM
#13341 | |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,088
![]() I use a pair of cheap ATV tank panniers to which I eventually added a tie-down strap so they wouldn't flip back into my lap whenever I go over 50 mph (not in the pic below). They have a water bottle holder on the outside and are well enough constructed to keep out dust and mud under normal circumstances, although I wouldn't trust them to keep anything critical dry in a rainstorm or river crossing. They are certainly suitable for carrying a handgun but not in an immediately accessible way
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
10-10-2012, 08:22 PM
#13342 | |
Oddometer: 485
10-11-2012, 02:40 AM
#13343 | |
Oddometer: 21
10-11-2012, 02:51 AM
#13344 |
-Devo
Oddometer: 2,905
Pretty sure that is xt wet weight vs dr dry weight. I don't find it top heavy at all.
06' Wee 99' DR350 |
10-11-2012, 04:55 AM
#13346 | |
Dodgin' the Ditches
Oddometer: 1,158
I don't know. I just google the specs, and usually get the # from motorcycle-usa.com or whatever site comes up. The XT225 "feels" really light, but they say my WR450 is only 248 lbs, and it feels heavier than the 225 when I'm stuck or trying to lift & drag it over a log, or when trying to turn around in a tight spot on the side of a steep hill. I was always under the impression that the DR350 was quite a bit lighter than the DRZ400S. But if you weighed your bike at over 300 lbs, I guess there isn't much difference. Maybe the Z carries it a lot higher? |
10-11-2012, 11:30 AM
#13347 | |
Oddometer: 120
Ghostyman screwed with this post 10-11-2012 at 11:48 AM |
10-11-2012, 12:46 PM
#13348 | |
Oddometer: 680
Starting next year I'll be riding this bike as a commuter to work (~50 miles) and 30 miles of that will be ranch roads. Since I'll be riding in a green uniform with a duty belt, I'll aready be standing out. It wont be too noticeable having another pistol on the bike. Why do I need two you ask? its nearly impossible to use your left hand to get a pistol on your right side. If the situation presents itself and I need to access a pistol quickly, I'll have one on the tank within quick reach. Plus there are tons of coyotes out here and they make great target practice. ![]() I'm not concerned about the pistol getting dirty. We ride ATV's constantly through mud, dirt, dust and rain and never seem to have an issue. On the other hand, we do have broken pistols occasionally from ATV wrecks. Here is a pic I took of such an instance:
RuggedExposure screwed with this post 10-11-2012 at 02:33 PM Reason: bad link |
10-11-2012, 01:20 PM
#13349 |
Oddometer: 120
XR650 5.8g tank on DR350?
I've seen a few references to people putting 5.8 gallon gas tanks from a XR650 on their DR350. It sounds like mounting them isn't a huge issue.
Does anyone have pics of one of these tanks on their DR? I'm not worried about the mounting, I'm just curious how big it's going to be and if it gets in the way. |
10-11-2012, 02:03 PM
#13350 |
Oddometer: 1,249
The tank does not look too big as most of the gas is forward of the rider's knees. However you have to hack up your stock mounts.
Here is a write up on how to mount it. http://www.wilddog.za.net/forum/inde...opic=58367.160 If you want big tank though this is what you need. I think it is a ten gallon tank. ![]() ![]() ![]() http://www.enduro-manufaktur.ch/tangebot.html
94 DR 350 SE |
