10-19-2012, 06:03 AM
#13411 | |
Oddometer: 578
There is no specific spline notch. Even if you marked yours before you disassembled it, you would be very lucky to find it lined up properly on reassembly because the shaft can work in any orientation. The idea with pretty much any cable actuated lever is that there be a 90 degree orientation between the lever and the cable (90 degrees provides maximum leverage on the lever). Of course, this 90 degrees will change as the lever moves as you pull the cable, but it provides a good starting point for positioning the lever on the shaft. In short, just move the lever on the splined shaft until you find the spot that works well. Hope this helps! Regards, Gregory Bender |
10-19-2012, 09:11 AM
#13412 |
Oddometer: 2
gardog
i need some help folks. i got a 1990 dr 350 dirt only. what a tuff bike to start. but i want to rebuild the carb. no one has the kit . so whats a good new carb to get? and yes it was clean and ran great for awhile.
thanks, gardog |
10-19-2012, 10:02 AM
#13413 | |
Oddometer: 201
Courtesy of Greg bender
___________________ 1999 DR350X 1982 GS750T |
10-19-2012, 10:50 AM
#13414 |
Oddometer: 32
Clutch cable/ arm orientation
The correct position for any clutch operating arm is to have the arm and cable at 90 degrees with the handlebar lever pulled fully in. Think of a drum brake actuating lever, over center is bad!
10-19-2012, 03:11 PM
#13415 |
Oddometer: 83
10-20-2012, 08:02 AM
#13416 | |
Oddometer: 232
read this thread for more info about this common problem or look at some of my older post about it. |
10-20-2012, 01:15 PM
#13417 | |
Oddometer: 9
1. bike in neutral 2. choke on (pulled out) 3. petcock on prime so there is for sure fuel in the carb 4. pull decompression lever, push kickstart until the decompression lever pops 5. bring kickstart back up and the slowly push down until the piston goes just past top dead center and stop immediately (you'll feel a little pressure and then it will quickly release indicating you have passed TDC) 6. Bring the kickstart fully back to the top, and in one smooth, quick motion kick for all you worth. You will hit full compression at a point about halfway through your kick start levers swing, i find unless i wearing supportive boots it nearly breaks my ankle. 7. bike should start, if it doesn't repeat steps 4-6 I've found when I do it that way it usually starts 2nd or 3rd try
Stock 1992 Suzuki DR-350S |
10-20-2012, 09:01 PM
#13418 | ||
Oddometer: 186
Thanks for the info guys. Going to give it a try tomorrow.
2000 R1150GS 1994 DR350R 1978 XL125 |
10-21-2012, 07:37 AM
#13419 |
Oddometer: 83
Thought I should introduce myself....I've been hanging out over at maximum suzuki for a while, and have been lurking here for a year or so.
Had my DR about 10-11 years, used it mostly for trail riding (located in Ontario Canada) with occasional street rides - its getting cold so I went out today for a putt in the country. Here's a couple of shots after the ride: ![]() ![]() I've been riding bikes for over 35 years, trail riding for 25 or so.....rode trials for a while, now just have fun. |
10-21-2012, 09:18 AM
#13420 |
Oddometer: 1,104
10-22-2012, 11:21 AM
#13421 |
Oddometer: 339
Day ride
Just did a quick ride, thought I'd post a link to the report:
http://www.advrider.com/forums/showp...1&postcount=76
10-22-2012, 04:39 PM
#13422 |
wandering the desert
Oddometer: 679
Oh lord no. That'd be like eating a mangy version of my dog.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
10-22-2012, 08:52 PM
#13423 | |
Wishing I was riding RTW
Oddometer: 2,420
Great link to the ride. I need some of those luggage stand off racks
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
10-22-2012, 09:12 PM
#13424 | |
Oddometer: 339
I don't have a welder so a friend welded it up. Truly, it was an easy job that took about an afternoon once I had all the supplies. Here's a couple pics that show them a little more. ![]()
MadChap screwed with this post 10-22-2012 at 09:16 PM Reason: Added pictures |
10-23-2012, 12:15 AM
#13425 |
Oddometer: 21
still lost i pulled the carb back off my 96se today and cleaned it good
carefully reassembled everything and still the same problem just no top end power it literally even in neutral feels like its got a rev limiter keeping it at 6-6.5 k u can pin the throttle and thats all it will rev to i tried with tank cap removed, installed a clear fuel filter to check fuel flow and its staying full and flowing good, i tried without air filter no change, choke on or off same thing, only with it on get exhaust popping on top of it brand new iridium ngk plug carb cleanered everything completely removed everything and cleaned and sprayed out with compressed air i thought it was my slide diaprahgm but i know its seated correctly used some shallac on it to be sure it stayed in place this time im lost guys any idea's? its a totally stock bike with the stock jet sizes (both jets brand new) hadnt ran in 3 years, and will only do 50mph grrrrrrr kaukasion screwed with this post 10-23-2012 at 12:25 AM |
