12-31-2012, 08:57 PM
#14026 |
Oddometer: 485
Yep, each valve on the lowest place on it's cam lobe. It won't hurt to recheck for piece of mind. But if you used the correct gage the last time, I bet you're close. After all the times you've set your valves now, guess we can call you VALVE Lasherman. :-D I've got no room to talk, I've set thousands of valves, maybe more.
2bold2getold screwed with this post 12-31-2012 at 09:54 PM |
12-31-2012, 09:41 PM
#14027 |
Oddometer: 8
Found 2 Dr350 with big bore and parts bike in NC
Check it out. Just outside Raleigh, NC
http://raleigh.craigslist.org/mcy/3505962959.html |
12-31-2012, 10:54 PM
#14028 | |
Ah Sh!t!
Oddometer: 196
Ha! Im going to Death Valley Daze in three weeks and dont wanna have an issues! just never had them tight like that before. |
01-01-2013, 03:06 AM
#14029 | |
Oddometer: 731
OTOH, you will feel a lot better if you re-check it, especially when riding it far from help? |
01-01-2013, 05:59 AM
#14030 |
Oddometer: 19
Tire Recomendations.....
My 1990 Suzuki Dr350S, under 1500 original miles, I recently uncovered it to start riding again. I purchased it with 850 miles on it in 1994. It still has the factory original Dunlop K560 tires on it. They look like new with no cracks at all. The bike was always stored indoors in a heated building. I don't trust them for dualsport use so a change is in order. The Dunlop K560 is no longer available, plus I'd like something a little more aggressive. My riding will be 50/50. What do you recommend? Thanks, Frank
01-01-2013, 07:57 AM
#14031 | |
Oddometer: 581
IMHO, the only bolts that really require accurate torque are the 4 cylinder head bolts as those are the ones that do the lion's share of the work in securing the cylinder head to the cylinder to the crank case. Torque those properly with a wrench. As for the two nuts at the bottom, I just snug them up with a box end wrench and forget about it. I've never had any trouble with them loosening up (and I apply antiseize compound to them). Hope this helps! Regards, Gregory Bender |
01-01-2013, 09:14 AM
#14032 |
Oddometer: 485
Finding TDC
A simple, logical way to find the correct TDC for valve adjustments is to remove all the necessary parts...seat, tank, adjuster covers, spark plug, left side access plugs, etc. On the manual decomp models, make the necessary adjustments to insure the decomp won't interfere with adjustments. Rotate the crank shaft in the direction the motor runs and watch the intake valves (closest to the carb). When the adjuster screw pushes the intake valve down (open) and it returns back up (closed) the next TDC mark that shows up in the access window is the correct position. "Turn the crankshaft untill the engraved line on the magneto rotor is aligned with the center of the hole on the magneto cover" Works on all 4 stroke motors. On most motors, you can put a "tool" down the spark plug hole and watch the up and down motion to be sure you're in the right spot, but that's really not necessary. If you do this, be sure to use something that won't damage anything or break off in there.
01-01-2013, 09:49 AM
#14033 | |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,090
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
01-01-2013, 10:12 AM
#14034 |
Oddometer: 124
I happen to have a main wiring loom for little doctor. Taken from almost new bike when it was modufied to be more offroad capable at nineties. Pm if interested.
G650X Challenge, R80G/S project bike. |
01-01-2013, 10:38 AM
#14035 | |
Oddometer: 119
01-01-2013, 11:54 AM
#14036 |
Oddometer: 166
It happens to all of us. lol nice ride too btw! haha. You'll enjoy it! Trust me! hahaha
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
01-01-2013, 12:59 PM
#14037 |
wandering the desert
Oddometer: 680
My bike started popping and backfiring while on a 2 hr ride a few weeks ago...
As the trip progressed, the backfiring got worse. It started out only being under acceleration and nothing noticeable, then it started bogging down and barely made it to my destination. I cleaned the air filter, reoiled it and that didn't work. I then checked the plug, gapped correctly and the correct color. I doubt its the carb, I just rebuilt that. Possible the coil? Has anyone used the aftermarket coils available on fleebay?
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
01-01-2013, 02:42 PM
#14038 | |
Rides a dirty bike
Oddometer: 1,419
BikeBandit has them for around $70/ea ($74 for 130/80-18), but I don't know if that's the best price.
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
01-01-2013, 03:32 PM
#14039 | |
Oddometer: 83
01-01-2013, 03:35 PM
#14040 |
Oddometer: 1,011
Typically backfiring is a symptom of lean running, not rich ^^^^^
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution. |
