Old 01-14-2013, 09:57 PM   #14191
heirhead
Oddometer: 580
rear brake
Hello,
Thanks to greg bender and 2bold2getold for there help.
On the rear brake pedal is there splines inside so you can adjust it up or down?
Mine with brakes adjusted is 2 inches to low.
Thanks for your wisdom,
Heirhead
heirhead is offline   Reply With Quote
Old 01-14-2013, 10:09 PM   #14192
ADV BUM
Oddometer: 124
Previous owner installed the vapor computer. He did not install the temp sensor. I was going to hook it up to the spark plug like trail tech says, but I am reading people dont like those temp readings. I like the idea of hooking it up to the banjo bolt like others have done. Does any one know off hand what size loop/sensor I should order to install on the banjo bolt?
Thank you
ADV BUM is offline   Reply With Quote
Old 01-14-2013, 10:28 PM   #14193
2old2Bbold
was 2bold2getold
Oddometer: 1,704
Originally Posted by heirhead View Post
Hello,
Heirhead
No splines. Looks like there is a stop bolt and lock nut in the frame just in front of the brake pedal pivot used to adjust the brake pedal upper limit. And a couple of lock nuts on the master cylinder rod, at the clevis, to adjust the throw. If your pedal isn't bent or messed with.
2old2Bbold is online now   Reply With Quote
Old 01-14-2013, 10:34 PM   #14194
heirhead
Oddometer: 580
Hello,
Thanks,
will try and adjust that way.
Heirhead
Old 01-14-2013, 10:37 PM   #14195
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,243
Just got the o-ring kit from Greg Bender.
Looks like an outstanding setup. Will have pics posted when I get a chance.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 01-15-2013, 01:57 AM   #14196
tntmo
Oddometer: 494
Hello,
Heirhead
If you are still having issues, let me know. I have three rear master cylinders in my stash of parts. We can get you going in no time!
Buncha dirt bikes with license plates.
tntmo is online now   Reply With Quote
Old 01-15-2013, 04:49 AM   #14197
Greg Bender
Oddometer: 1,173
Originally Posted by visovm View Post
To pick up on the discussion on page 943, I developed a slightly different attachment method for the MooseRacing skid plate I picked up through ProCycle.
I did not like the "P" mounting clamps in the back, and read about others who welded on pieces of aluminum to the rear of the skid plate to attach to the factory mounts. I dont have easy access to someone who knows how to weld aluminum, so I decided a mechanical connection could be no worse than the "P" clamps and would eliminate the bolts sticking out and getting destroyed and subsequently impossible to remove.
I have a lot of old stock aluminum, and machine hardware so that was not the issue. I used some L shaped aluminum and stainless hardware to attach the brackets to the skid plate in the proper position. This was a free mod for me since I have all the tools and materials, but I would imagine it would not be too expensive to purchase the materials if you dont have a friend who can weld it for you.
Here is the solution I came up with:
I hope this helps anyone who is considering something like this. When I have a chance to take it out and beat the heck out of it, I will report back if there are any failures.
I wish Moose and others would just weld on these tabs to use the factory mounting points. I would be willing to pay a little more for a skid plate that used all four stock mounting points.
OUTSTANDING!!!
Like you, I would have been very willing to pay extra to have the skid plate use all four stock mounting points.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 01-15-2013, 04:51 AM   #14198
Greg Bender
Oddometer: 1,173
Thank you
To which banjo bolt are you referring? There are several and I probably know the size or can take a quick measurement in the garage this morning.
Regards,
Gregory Bender
Old 01-15-2013, 04:52 AM   #14199
Greg Bender
Oddometer: 1,173
Glad to hear it :>
Regards,
Gregory Bender
Old 01-15-2013, 11:38 AM   #14200
MrPulldown
MrPulldown's Avatar
Oddometer: 3,165
Originally Posted by Greg Bender View Post
OUTSTANDING!!!
Regards,
Gregory Bender
That is a great solution. I had a local welder weld on tabs for me. Cost about $30. Which is not bad but messed with the heat treat. After smacking a couple of rocks near the weld, they have now cracked. If I only thought to bolt it together.
MrPulldown is offline   Reply With Quote
Old 01-15-2013, 06:10 PM   #14201
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,710
Rear rack forsale or trade
http://www.advrider.com/forums/showt...0#post20493730
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 01-16-2013, 07:49 PM   #14202
Drufiddy
Drufiddy's Avatar
Oddometer: 37
Any little DR riders out there have a front rotor for a 94 SE? I did the Western TAT in August and bent the front a tad. Breaking power is pretty bad. Thanks!
Drufiddy is offline   Reply With Quote
Old 01-16-2013, 10:15 PM   #14203
O'Hooligan
Ken Dodd's dads dogs dead
O'Hooligan's Avatar
Oddometer: 621
OK, I need the opinions of the gathered experts on my paranoia! I removed clutch and sidestand switches and wired the connector wires together and the bike ran fine. I ran the bike a few times no problems, But then my CDI unit malfunctioned, consequently the bike won't run. I know its the cdi as I was able to swap out a borrowed one and the spark was good.
The question is was this just coincidence or did it just decide it was time to quit? Before I drop lots of $$$ on a new cdi, I want to make sure it was not something I did.
Any suggestions?
O'Hooligan is offline   Reply With Quote
Old 01-16-2013, 10:37 PM   #14204
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Originally Posted by O'Hooligan View Post
The question is was this just coincidence...?
Yes. Many, many of us have removed the 'safety' switches from our bikes. I have had mine removed from just about every Suzuki I have ever owned, including my track-only GSX-R1000, DR350, DR650, and my Ducati track bike, and they have continued to run just as before with no issues what-so-ever.
VooDooDaddy is offline   Reply With Quote
Old 01-16-2013, 10:38 PM   #14205
2old2Bbold
was 2bold2getold
Oddometer: 1,704
Any suggestions?
I removed my side stand and clutch switches about 1200 miles ago. No problems so far.
Times are GMT -7.   It's 03:34 PM.
