Old 01-19-2013, 03:58 AM   #14236
Greg Bender
Oddometer: 611
Originally Posted by Cool_Hand_Luke View Post
Hello Mr. Bender,
Thanks for the info...I already placed an order for the KX Highs so hopefully the cables will reach okay. If not maybe I will return them and do the same set up you have with the CR Mids and the risers. Oh and I like where your head is at with the leg work out!
Luke
Hi Luke,
Let us know of the KX Highs work with your cables. Picture would be nice, too. :>
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 01-19-2013, 04:37 AM   #14237
andrius
Oddometer: 9
Originally Posted by RuggedExposure View Post
The manifold looks sealed, I adjusted the valves a few hundred miles ago, but it is possible something came loose.
The bike seems to have great compression and is still easy to start.
How much does it cost to have a stator re-wound? Can I buy a new one?
One more thing to check (adjust) would be float heigth. Fellow from my local forum had similar problem - engine started easily without choke (even in cold weather), and after reaching working temperature it died. The problem was improper float heigth (the bike was high mileage), causing too rich mixture.
Good luck with Your problem!
andrius is offline   Reply With Quote
Old 01-19-2013, 05:33 AM   #14238
boboneleg
we can rebuild him.
boboneleg's Avatar
Oddometer: 636
Yesterday
In south-west England...........
oooooooooops
'04 KTM 950 Adventure
'00 Honda XR650L
'98 Suzuki DR350SEW
boboneleg is offline   Reply With Quote
Old 01-19-2013, 05:47 AM   #14239
cwc
Oddometer: 743
Anyone else have any ideas? This problem seems to be linked to heat, or something warming up and making it run awful.
I can't remember if this has been mentioned, but have you checked the air filter?
I've been involved with this set of symptoms twice recently. The first was a XT350 that had a mouse nest in the airbox and the second was a DR650 with too much oil in the air filter.
Neither one was my bike or my work.
Charlie
DR350 It'll get you there
But then so will my DR650
My Ride Reports Here
cwc is online now   Reply With Quote
Old 01-19-2013, 06:44 AM   #14240
jeep8
Oddometer: 233
http://www.youtube.com/watch?v=04iOmfhABEo
Thought ya'll might enjoy this
jeep8 is offline   Reply With Quote
Old 01-19-2013, 06:48 AM   #14241
RuggedExposure
wandering the desert
RuggedExposure's Avatar
Oddometer: 720
Ya, this was my first thought too. I cleaned the filter and re-oiled it to no avail.
Possibly the float is too high? Anyone have pics of the metal tab on the float and where its supposed to be set at?
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood.
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 01-19-2013, 07:22 AM   #14242
tntmo
Oddometer: 229
Originally Posted by pnw View Post
I have a '99 with a K&N air filter but thinking of going back to a foam filter. Anyone know of a source for a new cage for a foam filter? Or is the K&N not as bad as I read about on this site for use in dusty conditions?
Anyone know if trimming the snorkel tube shorter causes any problems?
I think I have one in my spares.
Buncha dirt bikes with license plates.
tntmo is online now   Reply With Quote
Old 01-19-2013, 07:36 AM   #14243
andrius
Oddometer: 9
Sorry, don't know at what heigth float is supposed to be. There should be two ways to check it:
1. With tube connected to the lowest part of carburator (when on bike);
2. with calliper (roller) when carb is dismantled.
I could attach pictures from my manual, but I don't have imageshack or similar account to place pictures at the moment...
As for example You can check this online manual:
http://er5.atw.hu/letoltesek/Kawasak...Manual_ENG.pdf
Pages are: 2-10, 2-11 and 2-12
When check Yours DR manual for info.
I hope this info is clear enough :)
Old 01-19-2013, 08:02 AM   #14244
OldUKBikerGuy
Cultural Attaché
OldUKBikerGuy's Avatar
Oddometer: 21
Great 'snow' pictures, BobOneLeg; I'm SO jealous!
Not very far away, here on the South Coast, we just got slushy crap.
(Enough excuse to close the schools though...)
Good to see you out having some fun......!
OldUKBikerGuy is offline   Reply With Quote
Old 01-19-2013, 08:30 AM   #14245
2bold2getold
Oddometer: 520
oooooooooops
Hi, Bob. Nice ride, and nice wind screen combo. Another "98 in England with early forks... http://www.advrider.com/forums/showp...ostcount=14177
2bold2getold is online now   Reply With Quote
Old 01-19-2013, 08:34 AM   #14246
ADV BUM
Oddometer: 118
Looking for DR350 rear wheel compatibility
DR250 - Direct swap I believe
Drz400?
Rm125/250?
ADV BUM is offline   Reply With Quote
Old 01-19-2013, 09:42 AM   #14247
motolab
motolab's Avatar
Oddometer: 1,146
If it was a high mileage BST33 equipped model, it could have easily been running rich because of a worn out emulsion tube (which is caused by a worn out slide guide). A worn out emulsion tube affects the same rpm range as float height does, and increasing the float height can to a limited extent be used to compensate for emulsion tube wear.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-19-2013, 09:49 AM   #14248
motolab
motolab's Avatar
Oddometer: 1,146
It would have to be too low. Increasing leans the mixture and decreasing richens. I would not set it to other than stock specification unless I knew that the mixture needed to be changed at low rpm at all openings, and had a good way to evaluate the change (such as testing on a 5-gas EGA equipped brake dyno).
Regards,
Derek
Old 01-19-2013, 09:52 AM   #14249
motolab
motolab's Avatar
Oddometer: 1,146
That checks the fuel level.
Using a float height setting tool will be more accurate and less time consuming.
Regards,
Derek
Old 01-19-2013, 10:10 AM   #14250
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,425
Trade?
I got a seat bag for sale but im also looking for a DR350 after market skid plate trade
http://www.advrider.com/forums/showt...3#post20526103
Also listed a stock exhaust and K&N air filter for the DR350
http://www.advrider.com/forums/showt...1#post20526161
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Times are GMT -7.   It's 07:38 PM.
