01-20-2013, 01:29 PM
#14266 | |
Love those blue pipes
Oddometer: 4,084
Good luck with the ongoing improvements. I'm sure you'll have it running sweetly soon enough.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
01-20-2013, 01:38 PM
#14267 |
Oddometer: 71
Can anyone ID this carb? No model number or serial. The build up just mentions it was a dirt carb instead of the stock carb that came on the 91 dr250.
01-20-2013, 02:43 PM
#14268 |
Oddometer: 118
mikuni tm31 or 33mm, is what it looks like,if it came off a 250, it is 31mm, 350 33mm.
01-20-2013, 04:34 PM
#14269 |
wandering the desert
Oddometer: 679
Looks like a tm33
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
01-20-2013, 04:35 PM
#14270 |
Oddometer: 679
Yeah... That's how I do things.
01-20-2013, 05:23 PM
#14271 |
Oddometer: 28
Just a bit of info on some bar risers that worked out for me because I had the stuff laying around.I have two LT80 quads that I bought for parts to fix up another.I was able to use two of the bar mounts and the long bolts from the quads handlebars to raise my DR bars up 3/4 of an inch which is not a lot but in my case,any rise was a huge improvement.
01-20-2013, 05:59 PM
#14272 |
Oddometer: 50
Parts Interchange
Hey guys. Noob here planning a father&son TAT ride and considering a 93 dr250 (s? se? it's the dual sport version) and 99 dr350sex (dual sport version) as the bikes to do it on. I have read at least half this thread but haven't been able to answer my questions. I have no idea what the letter codes for the 250 should be, I think it would be an S or SE and I think the 350 is an SE, never seen the X (maybe it's a joke? SEX) but again, I'm a noob. My question is: what consumables interchange? as in brake pads, oil and air filters, clutch and throttle cables, brake and clutch levers, seats, fuel tanks and petcocks, carb kits, etc. Both bikes need at best some TLC and at worst rebuilds of everything but the engines/transmissions. I plan to grease suspension and wheel bearings, replace appropriate seals, lube or replace cables (and carry spares), replace and carry spare levers, change any vacuum petcocks I find (don't own the bikes yet, planning 2 retrieval trips this weekend), and probably make at least 1 gas tank swap, might buy a Corbin seat from the flea market and want to know if it'll fit both bikes or just one. Thanks a TON for your help! hope i join the DR ranks soon!
mwilliamshs screwed with this post 01-20-2013 at 06:00 PM Reason: clarity |
01-20-2013, 06:31 PM
#14273 |
Oddometer: 28
The X in sex is year code. I don't have any experience with the 250,but it's my understanding that it's the same bike just a different motor basically.
01-21-2013, 12:25 AM
#14274 |
Still a n00b
Oddometer: 149
Howdy, I am looking for a kickstart lever for my '90 dr350s. More specifically a shortened one. Last summer at a KTM demo ride, as a KTM employee was trying to tell me not to give my DR any gas while I was starting it
(like it was sum newfangled fuel injected bike), he made a point that newer bikes have shorter kickstart levers for less torque, faster rotation. Makes sense. My DR isn't too hard to turn over, unless it's in that one spot in the rotation, so I want to look into some possibilities. Anyway, any help would be appreciated, like if newer RMZ levers will fit, or even just the size of the splines. Thanks!
01-21-2013, 02:18 AM
#14275 | |
Oddometer: 578
Regards, Gregory Bender |
01-21-2013, 02:26 AM
#14276 | |
Oddometer: 578
I'm looking forward to trips like that with my children when they get old enough :> Regards, Gregory Bender |
01-21-2013, 06:56 AM
#14277 |
Miner
Oddometer: 40
anyone the differences between the brake lines on the 90-94 dr350 and the dr350s bikes? They have different oem part numbers, my front line is shot and was looking at aftermarket lines. I imagine maybe the length is a little different with the same banjo connections?
01-21-2013, 08:12 AM
#14278 |
Oddometer: 119
case saver
Does anyone know where I could find some? Would like to see price for store bought vs me making them.
THanks |
01-21-2013, 08:32 AM
#14279 |
Oddometer: 50
Thanks Chiknmunky and Greg Bender
Appreciate the input!
My largest areas of concern at the moment are charging systems. I know the bikes OEM part numbers differ but I wonder if one might fit the other in an emergency or as an upgrade? I've spent several hours on parts sites comparing part numbers and here is a short list of what I've found so far: FITS BOTH oil filter: EMGO: 301701 Turn signal lens, amber: k&s 21534 clutch spring set: ebc: 382014 front sprockets interchange clutch kit:ebc:384071 exhaust (from headpipe back anyway...)same skid plate same foot pegs same push/pull throttle cables: motion pro: 040144 fits both shifters interchange rear disc guard fits both moose shark fin air filters interchange front brake pins interchange front tires interchange rear tires interchange fork seals interchange frame covers interchange front fenders interchange rear fenders interchange rear axles interchange both sides chain adjuster interchange front caps interchange front protector tubes interchange front spoke sets interchange front rims interchange front innertubes interchange Doesn't Fit Both speedo drive differ starters differ front brake rotors different rear hub different front master cylinders differ rear wheel bearings differ clutch cables differ front wheel bearings differ shock bearings differ rear rotors differ front hub differ front axles differ Definitely more work to do but this list is more complete than I'd expected it would be by now. Seems most engine parts differ which was surprising. I'd been told they were the same except for the top-end. Also the clutch cables being different was a shocker and I think it might be as simple as one being about an inch-and-a-half longer than the other. If that proves to be true I'll just pack the longer one as the spare for the trip probably. Are the TW cables that much better? Seem to be about double $ most places. One of the bikes has a larger Acerbis tank installed but I'll most likely install the yamaha raptor petcocks in both bikes. Vacuum petcocks have never made sense to me and I've only known of a couple failures personally but I have no intention of fighting that battle in the middle of nowhere. |
01-21-2013, 08:52 AM
#14280 |
Oddometer: 480
DR350 vs DR250
Guess you have concidered using two 350s, if the boy can handle it. Might need lowering. Don't think there's a lot of difference in size and weight. Power is a little different. 250 makes power at higher rpms, 350 probably has more grunt.
