01-31-2013, 10:51 PM
#14566 |
Oddometer: 226
I don't know if you could get much of a bulb in there, but maybe something LED or HID? Would be cool to have extra light!
Buncha dirt bikes with license plates. |
02-01-2013, 10:52 AM
#14567 |
Riding Nomad™
Oddometer: 12,718
Can an exhaust from 99 DR350SE(x) fit on 1993 DR350s (kickstart)
Learn to ride. Ride to learn. FS: 1993 Suzuki DR350S (wide ratio 6 speed - street legal kickstart) |
02-01-2013, 11:31 AM
#14568 | |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,086
I don't think you'd even notice the extra light. Just put in a higher output or higher efficiency (HID?) main bulb if that's what you're after. Even a bright bulb in that location will throw very little light where it of use to see by.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
02-01-2013, 12:51 PM
#14569 |
Oddometer: 226
Yes, same exhaust.
02-02-2013, 12:33 AM
#14570 | |
Still a n00b
Oddometer: 149
Remove the valve springs (you need a special c-clamp like thing to do this), put some valve grinding compound around the edge of the valve, slide it back in the head, then with the suction cup tool twist back and forth till you hear the grinding sound change. Lift, then repeat until the sound basically stays the same. You can get all this at advance, though when I called to ask they had no idea what I was talking about. I would also recommend replacing the valve seals since you have everything apart. Since the current suspect is valve leakage I would recommend cleaning everything the best you can. Take a wire wheel to the head, valves, and top of the piston (super dense you won't hurt it). You can also do this for the metal header seal. Just be careful not to scrape the aluminum where a tight seal is needed..... Oh yeah timing. Remove the cover for the top dead center viewer thing. It should be near the front of the left side case cover. Not the cap that looks like it covers the crank. Anyway rotate the engine to TDC or "T" as the indicator will say, Then when you throw the engine back together put the cam on with both "lobes" or whatever you call them, pointing down. Simple. But as someone else said, your cam chain could be over-stretched which caused a link to skip. I don't know how likely this is to happen but check how extended your cam chain tensioner is. Phew. Also check out what happened to my turn signal relay when two badly connected turn signal wires touched. ![]() No but really my turn signals won't work and any tips on the possible culprit would be appreciated. ![]()
02-02-2013, 12:44 AM
#14571 |
Still a n00b
Oddometer: 149
Just now saw the post a few posts back about the flashers. I recently switched over to LED bulbs but got a relay made for LEDs. I had a hard time interpreting the indicator light issue but could this cause my issue with no lights at all even with the proper flasher?
02-02-2013, 12:17 PM
#14572 | |
Single Track Noob
Oddometer: 1,455
Typos and nonsensical words courtesy of fat fingers on a make believe keyboard.
Brian Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa ![]() www.PhotoSupportNW.com |
02-02-2013, 12:25 PM
#14573 | |
Oddometer: 4
02-02-2013, 01:24 PM
#14574 |
Rides a dirty bike
Oddometer: 1,417
Stock location is on a tab under the headlight shroud - on the right looking from the front, on the inside of the headlight bracket.
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
02-02-2013, 04:25 PM
#14575 |
Riding Nomad™
Oddometer: 12,718
Alright, need a confirmation on kicking a hot 93 DR350 with a pumper carb...
It fires on first kick cold. I spent 10 minutes hot kicking until I reverse-engineered the hot start process. I need a verification or if there is an easier way... Cold Start
HOT Start
This worked for me, and I was able to kick start it with 1 kick every time. What is your hot-start secret?
02-02-2013, 05:14 PM
#14576 |
Oddometer: 120
Mine starts first kick when hot. Just use the decomp lever, find TDC and then kick. Fires up on the first kick at least 80% of the time and I can't think of any time it took more than 3 kicks.
Cold start is my problem... I prime with a dozen decomp kicks and then give it two real kicks with the choke on. It rarely starts. I then take choke off and just kick it from TDC until it starts -- takes a lot longer when cold and probably averages 20 kicks to start it for the first time. It often dies after a few seconds of idling for a few times. Then takes a few minutes to warm up before I can give it throttle without dying. |
02-03-2013, 07:54 AM
#14577 |
Oddometer: 4,086
Put something like a 15 or 20 ohmm resistor in parallel with one of the turn signals on each side. The current draw of the signals will still be pretty low but the indicator light will begin working again. Another alternative would be to wire up two indicator lights in parallel with the turn signal circuits, one for right and one for left. These could be 12V LEDs. If you can see the top of the signal lens from the normal riding position, then the indicator light is unnecessary of course.
02-03-2013, 08:56 AM
#14578 |
Oddometer: 573
did you guys having trouble use resistors in the circuit when adding LED's?
dirt bikes, vstrom, cruiser, etc. "what hurts, instructs" - ben franklin |
02-03-2013, 11:38 AM
#14579 | |
Oddometer: 1,462
02-03-2013, 12:14 PM
#14580 |
Riding Nomad™
Oddometer: 12,718
Thanks! I think I like it rich like this.. Easy cold starts are a very nice treat... Since the procedure works for hot start, no need to ruin the cold start ;)
