Old 03-01-2013, 11:47 AM   #14896
Suzuki Phil
Oddometer: 643
I run a stock counter sprocket but on the back I went to a 43 or 45. I can leave it in 2nd or 3rd and just chuck up hills. Before I was always shifting between the two to find the right spot.
That was four years ago and my chain and sprockets are worn so I'm switching to a 14/41 combo. On the high speed highway runs I'm peggin 7K at 65mph. Need to bring the rpm down since I'm turning my DR into a commuter bike with the high price of fuel in California.
SP
1916 Ford Model T
1996 DR350SE
Suzuki Phil is offline   Reply With Quote
Old 03-01-2013, 01:23 PM   #14897
thump!
thump!'s Avatar
Oddometer: 1,503
SP
Keep in mind that Suzuki changed the primary (crankshaft to clutch basket) gearing in 1994 when the DR350S got electric start. The older bikes have a primary reduction of 2.818 and newer ones are 3.200. Hence you can't compare sprockets between older and newer bikes. For instance 14/44 on an early bike is about the same as 15/41 on a newer one. The older bikes are a LOT taller geared. With the same sprockets on both there is about 700 rpms difference at 60mph. Here's a link to a little spreadsheet with all the gearing data in it... makes comparisons easy.
thump! is offline   Reply With Quote
Old 03-01-2013, 02:53 PM   #14898
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
That spreadsheet is awesome!
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 03-01-2013, 06:09 PM   #14899
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,635
Originally Posted by boardforever View Post
Put a new fender and flush mount signals on the DR tonight, they look great, thanks to Jesse @ Kientech.
looks good, what are the dimensions of those Keintech signals?
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 03-01-2013, 08:00 PM   #14900
daverbmxer
Oddometer: 44
Cheap Saddlebags
Does anyone have any recommendations on cheap saddlebags? These seem not too bad for the price.. any thoughts?
http://www.amazon.com/Black-Motorcyc.../dp/B00946BQAO
I would like to get a rack for it also and mount a hard case to that. Do you think I would still be able to take a passenger then? Any thoughts on these cheap bags combined with the rack and hard case?
daverbmxer is offline   Reply With Quote
Old 03-02-2013, 12:09 AM   #14901
mwilliamshs
Oddometer: 232
cheap luggage
Been considering the Bilt saddlebags from cycle gear. They're usually <$30 on sale.
mwilliamshs is offline   Reply With Quote
Old 03-02-2013, 04:58 AM   #14902
markk900
markk900's Avatar
Oddometer: 460
Love the spreadsheet!
Just to add a data point here, owner's manual for my 95 SES lists the newer primary ratio along with the older first gear ratio (2.416) as stock, plus 15/41 stock gearing. I run 15/43 for street riding and drop to 12/43 for tight off road (no need to shorten chain either so I carry the sprocket in my tool bag).
markk900 is offline   Reply With Quote
Old 03-02-2013, 07:46 AM   #14903
Spad
Spad's Avatar
Oddometer: 101
rebuild question
A while back I posted about my winter project, fixing the shift drum on my 99DR350SE with a sheared bolt (mea culpa). I ended up tearing the engine down, sending the drum off to Jesse for the larger bolt (as well as the crankshaft) and putting it back together.
This was my first time doing this so it didn't go like butter, but at the same time nothing else broke in the process and there weren't any parts left on the bench when I finished reassembly. However,...
The engine turns over OK, first by hand and then with the starter. Seems like I got the timing/valves together right. The transmission can only shift between two gears (not sure which two - I'm guessing high, since neither is N and I can roll the bike in gear) and the clutch doesn't fully release. I could rotate the drum OK by hand after I put it into the case and before clutch, etc. went back on.
As I get set to go back in, any ideas on what to look for this time? I've been working from the relevant manuals and replaced the parts they said to replace in the process (for the most part).
- Spad
P.S. I still look at this bike as my correspondence course in motorcycle maintenance, but it'd be nice to get it working again as well.
___________
06 Wee Strom
82 CM450E
99 DR350SE
Spad is offline   Reply With Quote
Old 03-02-2013, 09:50 AM   #14904
Greg Bender
Oddometer: 1,204
- Spad
My guess is that the "L" shaped bracket got bent when you tightened the shift drum bolt. It is very easy to bend and very difficult to see as bent until after you remove it.
Hope this helps!
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 03-02-2013, 10:44 AM   #14905
2old2Bbold
was 2bold2getold
Oddometer: 1,785
Clutch release problem
The clutch not releasing fully is a common problem with some DR350s. There are at least three solutions mentioned on this thread. Some have said that replacing their clutch plates fixed the problem and others have increased the drum spacing by sanding the back side of the drum or adding a washer/spacer to the sleeve-drum sandwich.
http://www.advrider.com/forums/showp...ostcount=11211
http://www.advrider.com/forums/showp...&postcount=133
2old2Bbold is online now   Reply With Quote
Old 03-02-2013, 11:57 AM   #14906
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,639
As stated earlier, new Thrust Washers will certainly help relieve the dragging Inner Hub. I did this, as well as removing a couple thousandths of an inch from the rear gear face of the Inner Hub, and installed a new cable. The clutch works great now.
I Loc-Tited the Shift Drum Bolt and installed a kick-starter while I was in there.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 03-02-2013 at 12:14 PM
Stretch67 is offline   Reply With Quote
Old 03-02-2013, 05:58 PM   #14907
Spad
Spad's Avatar
Oddometer: 101
Thanks for the responses! I'll open up the clutch side and check the L shaped plate (the bolt was torqued to the reduced spec in this thread, so I'm hopeful that isn't it) and relieve the back of the clutch basket. Funny, now that I've had the thing apart I can see how that would help (and may have been the problem in the first place).
Thanks, all (especially those that are repeating the favor of advice for me)
- Spad
___________
06 Wee Strom
82 CM450E
99 DR350SE
Old 03-02-2013, 06:13 PM   #14908
Mick350
Mick350's Avatar
Oddometer: 13
Hi guys, new to the forum.
I'm from Moonan Flat in NSW, Australia.
I have a 1991 DR350, recently pulled down ready for a full rebuild, and am considering buying a 1993 DR250s for commuting/play.
Will upload a photo when I figure out how. . .
Have read all 994 pages of this thread, plus Distech's build thread and Pablo's build thread.
Cheers, Mick.
Mick350 screwed with this post 03-02-2013 at 06:20 PM
Mick350 is offline   Reply With Quote
Old 03-02-2013, 06:22 PM   #14909
2old2Bbold
was 2bold2getold
Oddometer: 1,785
Cheers, Mick.
Welcome, Mick350 and Here ya go.... http://www.advrider.com/forums/showthread.php?t=919 SmugMug is owned by "Baldy", the site owner. I concider the $20 a year fee a contribution to this great free site. ;-D
Old 03-02-2013, 06:37 PM   #14910
Mick350
Mick350's Avatar
Oddometer: 13
Times are GMT -7.   It's 05:50 PM.
