Thread Tools Rating: Thread Rating: 146 votes, 4.94 average. Display Modes
Old 10-15-2012, 06:17 PM   #1756
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,207
Originally Posted by longtallsally View Post
The bypass I've always taken is actually up to the left. It is where I tore off the fender flare and dinged the rear door on the driver's side.
And they didn't cut the tree down, it actually fell from weather conditions:
http://www.pirate4x4.com/forum/rubic...ss-friend.html
Everyone was very sad about it.
Wow, I didn't realize the tree fell last winter. It was in some of the early Little Sluice pics I've seen. I remember sitting next to it back in '98.
I thought they closed the bypass to the left? That's one of the reason they softened the little sluice?
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson
Jeffy is offline   Reply With Quote
Old 10-16-2012, 09:16 PM   #1757
longtallsally
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 4,368
I've never thought I could make it up on the right previously, so I've always gone left.
I didn't see one person go right nor have I other than the gnarly machines...
[quote=Insert witty comment here]
longtallsally is offline   Reply With Quote
Old 10-24-2012, 10:01 PM   #1758
Rogue_Ryder
速 Flat Biller 速
Rogue_Ryder's Avatar
Oddometer: 7,555
Any NP231 Experts?
So my 4x4 wasn't working on my 1995 Wrangler YJ, was hoping it was a Vacuum or CAD issue but after checking everything out, everything was pointing to xfer case issues. So after I dropped it, I could spin the rear output shaft and the front output with spin (4hi selected) but as soon as I grabbed the front output shaft it would stop spinning almost like it was barely engaged and something was slipping inside.
After I opened up the case, I found the large shift fork was missing 2 of the 3 plastic tabs. Everything else inside the transfer case seemed in good shape, none of the gears looked damaged and no evidence of overheating.
Could those broken plastic tabs/pads cause this? Is my chain stretched too much (didn't seem unreasonably loose but I don't know what the tolerances are)?
Any help would be greatly appreciated.
Braaaap!!!!
Rogue_Ryder is offline   Reply With Quote
Old 10-24-2012, 10:26 PM   #1759
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,207
Well, it sounds like the forks aren't moving the shift collar. Those plastic pads are what ride against the collar when shifting. Probably too much slop in the fork to shift the collar.
Old 10-24-2012, 11:16 PM   #1760
Rogue_Ryder
速 Flat Biller 速
Oddometer: 7,555
I'm going to order the rebuild kit and put it back together. Hopefully that'll cure it.
Braaaap!!!!
Old 10-24-2012, 11:18 PM   #1761
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,207
If you need a FSM, let me know.
Old 10-29-2012, 11:21 PM   #1762
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,990
Anyone else with a JK find when they use the auto lever pump thing at the gas station (so you can take your hand off the pump handle) it overflows and comes pouring out? Even if I just hold it there's rarely a heads up click that shes full, its just BOOM gas everywhere.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 10-30-2012, 05:57 AM   #1763
tslewisz
tslewisz's Avatar
Oddometer: 2,374
My JK has never done it but I've heard of it. I'm thinking there may even be a recall. I'll look around and report back.
Okay, I'm back. Looks like no recall, but Chrysler will warranty work on it for the life of the vehicle:
http://www.autoblog.com/2011/02/28/n...pillage-probl/
NHTSA Summary:
ODI found the rate of warranty claims related to fuel spit back on the subject vehicles is lower than other vehicles previously recalled to correct defects related to fuel spit back. Although the rate of complaints reported to the agency on the subject vehicles is higher than or similar to the rates experienced in previous investigations where safety recalls were conducted, ODI suspects that the NHTSA safety complaints submitted by subject vehicles owners may have been influenced by internet related publicity both before and during this investigation. A safety-related defect trend has not been identified at this time and further use of agency resources does not appear to be warranted. Accordingly, this investigation is closed. The closing of this investigation does not constitute a finding by NHTSA that no safety-related defect exists. The agency will monitor the issue and reserves the right to take future action if warranted by the circumstances. See attached report for additional information. In addition, Chrysler is initiating a lifetime warranty program, at no cost to the consumer, to address the fuel spit back problem in approximately 135,000 model year 2007-2008 Jeep Wrangler vehicles built from March 1, 2007 to March 31, 2008. Chrysler will notify all affected vehicle owners of this action. Consumers should refer to the warranty and service bulletins and sample owner notification letter available in the investigative file. The vehicle build date can be found on the certification label located on the driver door or door jamb.
tslewisz screwed with this post 10-30-2012 at 06:55 AM Reason: update
tslewisz is offline   Reply With Quote
Old 10-30-2012, 07:46 AM   #1764
Ven Moto
Ven Moto's Avatar
Oddometer: 177
My '06 LJ tends to spit back like this. I guess I'm just screwed since it was built before 03-2007?
Ven Moto is offline   Reply With Quote
Old 10-30-2012, 08:10 AM   #1765
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,573
Same here, 06 LJ with a 1.25 body lift. I've been told the lift changed the angle of the fill hose causing it to do that.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 10-30-2012, 08:12 AM   #1766
tslewisz
tslewisz's Avatar
Oddometer: 2,374
I just talked to a buddy w/ an '06 Rubi. His does the same thing. He pointed me to this thread:
http://www.jeepforum.com/forum/f176/...recall-974337/
Old 10-30-2012, 08:36 AM   #1767
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 5,061
Mine will do it as well if and only if I insert the fuel nozzle all the way in, if I put it in all the way then slide it back out to the first notch it will shut off correctly.
Mine with a 2" suspension lift which makes no nevermind.....
13 Hyperstrada 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Old 10-30-2012, 09:21 AM   #1768
Ven Moto
Ven Moto's Avatar
Oddometer: 177
No lift on my LJ. Factory suspension with optional 30's underneath, so I'm thinking it might not have much to do with height. I'm just glad to know that it's not just me.
Thanks for the link.
Old 10-30-2012, 09:29 AM   #1769
dox
How much for the ape?
dox's Avatar
Oddometer: 2,647
My 07 JK Unlimited does this. Saw that it might be covered, but haven't gotten around to fixing it yet. I just estimate how much fuel I need in the tank based on the gauge and pump gas a little slower as I approach full tank, doesn't spit if I am paying attention and remember to do this.
dox is offline   Reply With Quote
Old 10-30-2012, 10:05 AM   #1770
RustySpokes
Two-bit throttle bum
RustySpokes's Avatar
Oddometer: 1,048
Here is a fix for the gas overflow problem on 05 and 06 TJ/LJ's.
http://www.jeepforum.com/forum/f9/05...w-fix-1335243/
I haven't done it yet so ymmv but do have the parts at home waiting on some ambition.
"The beauty of fishing on motorcycles is that you’re riding motorcycles in great places whether you catch anything or not." - John Burns
RustySpokes is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:34 PM.
