Thread Tools Rating: Thread Rating: 6 votes, 4.17 average. Display Modes
Old 11-03-2012, 08:58 AM   #1786
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,588
Friend bought a YJ so I offered to pick it up for him if he paid for gas, I had to go there anyway for other business so free trip for me.
I picked up a 99 XJ just over a month ago and have been getting it fixed to resell. Had to tow it home because it wouldn't move on it's own when I bought it. I am now up to 4 Jeep Cherokee's that I own, a '94, two '99's, and a '00.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 11-03-2012, 09:01 PM   #1787
Fred Garvin
Oddometer: 141
tj gas tank fix
My 05 ruby lj just started doing this. My temp solution is to listen for the sound as the tank gets full and note the galon amount, then slowly finish the fill up. JP magazine had a reader write in about this and will be publishing a solution in the JP '13 issue.
Fred Garvin is offline   Reply With Quote
Old 11-05-2012, 05:20 AM   #1788
ducnek
Misadventurer
ducnek's Avatar
Oddometer: 907
Originally Posted by longtallsally View Post
I wouldn't go over 33" with a D35. Was he locked up?
Yep it was locked, the amount of abuse it took to break that shaft was laughable. I have read many a forum horror story about D35 axle failures, and after witnessing this one first hand, I think with any reasonable respect for your rig and a little finesse they are fine for 90% of offroaders.
YMMV
Calmer than you are.
ducnek is offline   Reply With Quote
Old 11-05-2012, 10:10 AM   #1789
longtallsally
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 3,448
YMMV
Yeah, the only time I blew an axle in my YJ with a D35 was going up Walker Hill on the Rubicon while still geared at 4.10 with the 4 banger. I didn't know how to drive very well at the time and just plain gave too much skinny pedal with too high gearing for 33" tires.
This is why I love the 4 to 1 gearing of the T case in the JK as I was actually on the brakes at times during climbs the gearing is so low.
[quote=Insert witty comment here]
longtallsally is offline   Reply With Quote
Old 11-06-2012, 05:41 PM   #1790
wibornz
wibornz's Avatar
Oddometer: 381
splash
Ride ride ride, get gas, ride ride ride ride, get gas, ride ride ride, get gas, ride ride ride ride, get gas, ride some more stop for the nigt.... Repeat.
wibornz is offline   Reply With Quote
Old 11-06-2012, 07:13 PM   #1791
cbolling
Here...Hold my Beer.
cbolling's Avatar
Oddometer: 2,369
Took the Jeep out for a little light off road fun this weekend.
2011 Kawasaki Versys
http://www.advrider.com/forums/showthread.php?t=661436
cbolling is offline   Reply With Quote
Old 11-06-2012, 07:15 PM   #1792
cbolling
cbolling's Avatar
Oddometer: 2,369
Old 11-08-2012, 07:13 AM   #1793
XpressCS
Luminous nut
XpressCS's Avatar
Oddometer: 284
YMMV
I call BS. JF members claim you can run 42's with a welded stock D35 and not break them
sarcasm
Puted the Jeep out to a vantage point this morning for some pictures.
All just to nab this photo:
Can't wait until tonight. Supposed to rain a lot, time to go out Jeeping!!!!!
My current garage:
-2004 Kawasaki KLR650, Rigid Dually LED lamps (DD)
-1996 Jeep Grand Cherokee 5.2L V8 (Donor)
-1989 Jeep Wrangler, stripped to the bone (Transplant-ee)
-A boatload of 80's 3 wheelers
XpressCS screwed with this post 11-08-2012 at 07:20 AM
XpressCS is offline   Reply With Quote
Old 11-08-2012, 07:29 AM   #1794
XpressCS
Luminous nut
XpressCS's Avatar
Oddometer: 284
Originally Posted by Dukeryder View Post
Ended up trading the vintage CJ-5 for something a little more modern.
Needs bigger tires and a lift badly, the stock leafs are flat and the street tires suck out on the trail.
Digging up an oldish post...
They were flat from the factory
My current garage:
Old 11-08-2012, 07:56 AM   #1795
Dukeryder
Dukeryder's Avatar
Oddometer: 6,703
Send a message via AIM to Dukeryder
Damn I did not know that! I should be picking up my BDS 2" Leafs tomorrow. Hopefully it still rides as good as the tired stock leaves and worn out shocks. Either way it should be waaay smoother than the superlifted '66 CJ5
Dukeryder is offline   Reply With Quote
Old 11-08-2012, 08:21 AM   #1796
XpressCS
Luminous nut
XpressCS's Avatar
Oddometer: 284
A lot of people like the BDS leafs. OME and RE are also favorites, good high quality kits that ride like stock.
I plan to upgrade to one of those lifts eventually... (probably an RE lift since it's the least expensive..)
My current garage:
XpressCS screwed with this post 11-08-2012 at 08:26 AM
Old 11-08-2012, 08:32 AM   #1797
longtallsally
Yeah I'm a chick
Oddometer: 3,448
SPRING OVER!!!!!
I went through 2 sets of the RE standard leaves. Very flexy, but I don't think lasted very long as the rears developed an "S" after only a couple years of trail use. And that is with the powerhouse 4 squirrel chaser.
Old 11-08-2012, 08:38 PM   #1798
XpressCS
Luminous nut
XpressCS's Avatar
Oddometer: 284
An "S" shape indicates axle wrap... Have you tried mounting up a Traction (Ladder) bar?
I've seen axle wrap with a 4 cylinder SOA before, so it's not unheard of.
My current garage:
Old 11-08-2012, 09:01 PM   #1799
longtallsally
Yeah I'm a chick
Oddometer: 3,448
Sold the YJ a few years ago. I'm on to the JKUR now. I don't think I could ever go back in terms of comfort.
Old 11-09-2012, 07:56 AM   #1800
XpressCS
Luminous nut
XpressCS's Avatar
Oddometer: 284
You don't buy a Jeep for comfort?
Guess it's all a matter of personal preference, I've driven in a handful of JK's and JKU's... They feel like cheap cheap plastic to me.
My current garage:
Thread Tools
Times are GMT -7.   It's 05:14 PM.
