05-21-2007, 05:32 PM
#31 | |
Infamous
Oddometer: 17,503
"A man can never have too many motorcycles, like any good craftsman you need the proper tool for the job at hand. A man needs more tools than a hammer, the same goes for bikes." ~Mr. Cob~ My Ride Through Roatan |
05-21-2007, 05:49 PM
#32 | |
Infamous
Oddometer: 17,503
Shit!...........................................I think "save of the day" is an under statement
05-21-2007, 06:12 PM
#33 | |
Registered User
Oddometer: 25,006
I have a very low opinion of winch ropes when used in real off road recovery situations. Abrasion will kill them fast, and they're expensive to replace. It's hard to beat a wire rope - just use normal safety precautions. Hydraulic winches driven from a power steering pump (MileMarker) are slower than the Earth turns. Sure, 2 speeds, but the high speed won't pull the stick out of a popsicle. There are different types of electric winches. Just because one is labeled 8,000# doesn't mean it's like another labeled with the same rating. Permanent magnet motor winches are inexpensive, relatively speaking, and do a good job when used within the limits of for what they're designed for. Series wound motor winches are the heavier duty winches. Winch motors build heat when they're under load, and that varies depending on the load. No load = almost no heat, over max capability = much heat very fast. Then there's the in between...where you actually use it. Other than wear and tear, heat is what kills the winch motor. Saying 'x' time on and 'x' time off is correct, but only for a situation when that is correct. That's never an abosolute. A motor will be pulling much greater amps under a 5,000# load when the cable is on top of 3 layers of cable (above the winch drum diameter) than when pulling the same 5,000# just over the bare drum. Winch ratings are calculated and labeled based on pulling power on a bare drum/1st layer. There's also a difference between planetary gear and worm gear winches, holding/bralking capacity being just a part of that. Then we have PTO winches.... I'm gonna stop. You can kill yourself or a friend with a winch..and you can also save lives. I love em, they are the juice... |
05-21-2007, 06:36 PM
#34 |
To young to feel this old
Oddometer: 1,675
Most excellent save!
War doesn't determine who is right, it only determines who is left. |
05-21-2007, 08:36 PM
#35 |
Oddometer: 1,201
boo hooo
![]() Had a '78 CJ5 for a few years in hs and college - still miss that damn thing not enough room in the garage or the budget to have the bike and the Jeep |
05-21-2007, 09:44 PM
#36 | |
The Mayor
Oddometer: 9,000
F800GS R1200RT Ca Stew says "You can't teach a pig to sing. It wastes your time and annoys the pig." |
05-22-2007, 12:02 PM
#37 | |
indupitable
Oddometer: 27,947
Thanks for the tip. After thinking about the winch rope and your input I decided against the winch rope. The times I have used the rope where weight is a concern are few. Also I have seen them bind and become hard to unspool. Well cable also but more on the rope. Decided on this one. It will fit the my existing ARB bumper. Still plenty of cable length. http://www.warn.com/truck/winches/sr...i_MOSFET.shtml
i got pwned by a liberal ask me how |
05-22-2007, 02:07 PM
#38 |
Oddometer: 144
Here's another of the non-Jeep variety.
05-22-2007, 02:51 PM
#39 | |
Oddometer: 2,994
05-22-2007, 03:39 PM
#40 |
Registered Lurker
Love them FJ's
Wanted one of those, but found my Jeep locally.
I would post a phots but for some reason, I can't post attachements here on Jo momma. I can elsewhere but not here?????? Could somebody please tell me why? Thanks JJ
Ride safe!!!! J There are 3 kinds of people in this world: Those that make it happen- Those that watch it happen- And those that stand around sayin---WHAT HAPPENED? 2001 KTM 640 Adventure R (back home in my garage with a fresh brand new engine! She is purring like a kitten! 2002 KTM 520 EXC (plated) BMW MOA #137435 |
05-22-2007, 04:29 PM
#41 | |
indupitable
Oddometer: 27,947
Nice Jeep JasonH Those Toyota's go places.
05-22-2007, 04:32 PM
#42 |
Wageslave
Oddometer: 197
![]() 95YJ, 355TBI, TH350, clocked and twin sticked D300, D60 front with 35 spline outers, welded, ram steer, behind the axle tie rod, 3/8" tube front driveshaft, 14 Bolt (shaved) with Detroit, discs and 1410 driveshaft, hummer wheels with cut down mag runflats, 39.5 TSLs, flat skid, anti-wrap bar, SOA with 44044 fronts and F150 rears, 104.5" WB, gas tank relocated to bed, cutting brakes, 8274, full cage, York OBA had to sell it :sniff: |
05-22-2007, 04:41 PM
#43 | |
Registered User
Oddometer: 25,006
The only negative I can mention, if they haven't changed motors, is that they will 'run on' for a short time after releasing the control switch. It shows more when there isn't a load, like when you're winding by hand. Be especially careful if you're rewinding the cable outside the vehicle and signaling the guy inside the vehicle who has the control. A tight cable will dig into loose lays/winds on the drum. This is the cause of binding when unspooling. It can be so bad at times that you need to hook to a tree or other anchor, and drive in reverse with the winch in free spool mode, jerking it free. Rarely are things perfect during recovery, but if the vehicle gets ahead of the winch and is winding loose cable, it's always best to stop when possible, unspool and rewind by hand. This is when you can get mashed and kinked cable. |
05-22-2007, 05:30 PM
#44 | |
Infamous
Oddometer: 17,503
Good first post.....................except for the last 4 words.
05-22-2007, 06:43 PM
#45 |
Oddometer: 1,595
Here's mine at 2 months old.
| Thread Tools | |
