07-30-2007, 04:55 PM
#61 | |
Potius Sero Quam Numquam
Oddometer: 4,396
08-14-2007, 08:07 PM
#62 |
Rough Rider
Oddometer: 829
updates?
I'm about ready to do the canisterectomy and the sas removal on my 990.
Is there any new information from those who have completed these mods? Are the resistors proving to be the correct ones? Tahoacr how is your monitoring going and do you have any sage advice on tuning etc. Thanks, MAX
Da oggi la strada é senza limiti |
08-14-2007, 10:13 PM
#63 |
Oddometer: 2,169
Resistors are working great for me. Same one in both. As far as tuning, been trying to get some dyno time with no success. The Akra map has killed my mpg. It is faster, but I will go back to stock. Even the guys I ride with have mentioned the fuel smell behind me. Thinking power commander would be good.
tahoeacr screwed with this post 08-14-2007 at 11:22 PM |
08-14-2007, 11:00 PM
#64 |
Oddometer: 1,230
Resistor works well for me 15KOhms
08-15-2007, 05:01 PM
#65 |
Rough Rider
Oddometer: 829
Where?
Where can I order the resistors and plugs to connect them into the electrical
system. I'm ordering a roll of the gold foil to cover the air box and tank insides, it's 3' x 10' for $261 does anyone want to buy half of it. Check it out in the So I did the 15 min. idle trick thread . Thanks MAX
08-15-2007, 05:34 PM
#66 | |
was Steve Lavigne
Oddometer: 418
09-08-2007, 05:49 PM
#67 | |
Lil' Mexican on a 990s
Oddometer: 186
Thanks for the link. Would you mind posting the part #'s please? Also, did this work for both ends, SAS and the Valve up front? Thanks, Eddy |
09-13-2007, 02:50 PM
#68 | |
Bye bye desert
Oddometer: 1,177
Thanks.
FOR SALE: 2008 KTM 530EXC-R Paochow.com - Beginner's Guide to the DRZ-400 Shootout: Buell Ulysses vs. KTM 990 Adventure Tank Bag essentials KTM Valve Adjustment How-To: 530EXC/XC4 motor 990ADV/LC8 Motor __________________________ Current Bikes: 2007 KTM 990 Adventure 2008 KTM 530 EXC-R Old Bikes: ![]() 2003 Derbi Supermoto 2006 Buell Ulysses 2005 Suzuki DRZ 1994 Honda XR650L 1992 Yamaha TW200 |
09-15-2007, 08:51 AM
#69 |
was Steve Lavigne
Oddometer: 418
Here is a copy of my invoice from Eagle Day:
AMP Connectors: 2-Pole ECK-212 1 14.95 Select Wire Gauge = 0.5-1.0 MM2 Male AMP Junior Power (AWG20-18) Timer Connector Kit AMP Connectors: Boots for AMP-CON-BOOT 1 3.95 Select Boot size = Straight 2/3-Pole Junior Timer Amp 37MM/2-pole Connectors Subtotal 18.90 Shipping 7.99 Total 26.89 I used this for the canister valve. I still have stock exhaust so I haven't messed with the SAS valve yet. |
09-15-2007, 09:04 AM
#70 |
Bye bye desert
Oddometer: 1,177
Thanks Steve
![]() I need to order that stuff up so I can rid myself of that octopus at the next service.
09-16-2007, 09:33 PM
#71 |
Oddometer: 186
Parts Ordered =]
Thanks Steve,
Parts ordered. Does anyone know the connector type/brand for the SAS end of sensors? Those who added the resistor(s), how did you secure it inline? Cut and solder, shrink tube? |
09-18-2007, 07:30 PM
#72 |
Oddometer: 66
Lambda sensor resitstors
Hi all,
Thought I would chip in with my experience on a Tiger 955i. I installed a Powercommander III USB and as part of this they sell a device that you plug into the wiring to replace the Lambda sensor. The Tiger is mapped to run lean at about 2,500RPM as a way to get the exhaust emissions low at the testing RPM but this gives the bike a big hiccup in the power output. You just disconnect the Lambda sensor and plug in the Dynojet Oxygen Sensor eliminator kit and tuck it away under the tank. They sell a few different kinds already installed in waterproof plugs. I am unsure which one (if any) will fit the 990 but they only cost US$15. Maybe an option for those not so "do it yourself" with electrics. Look here: http://www.powercommander.com/powerc...cessories.aspx |
09-26-2007, 06:44 PM
#73 |
Bye bye desert
Oddometer: 1,177
Local Radio Shack only had 10,000 Ohm and 22,000 Ohm 1/4 watt resistors when I went there the other day. Should either of these work?
09-26-2007, 09:48 PM
#74 |
Oddometer: 186
My steps to Smog Freedom and Resistors at Both Ends
Hello Team,
I took the advice, collective knowledge and some luck, and figured out the whole process. Following will be the addition of my pictures and how I removed, soldered, assembled, bleed, and put the mighty 990 back together. For starters, I used the resistors from Radio Shack, and the plug for Eagle Day. Here we go... |
09-26-2007, 10:00 PM
#75 |
Oddometer: 186
The parts list -
