Old 10-28-2012, 02:00 AM   #3391
K0m4
K0m4's Avatar
Oddometer: 551
Originally Posted by Scorch_TX View Post
What kind of straps are you using there? Do they have any elasticity? Are you using the straps to hold the gear to the bike, or just to hold the gear together?
Just regular webbing straps with no elasticity, with a metal clamp that you find in any gas staion. I built a rack on the rear seat bottom with bicycle handle bars, on which the duffel rests, and the bakcpacks hang (think I posted it in the make your own farkles thread - edt. I did indeed: my TLs luggage rack). Then run two straps over the duffel to the subframe, and also a short strap low around the backpacks to make sure they don't move.
Suzuki DL1000 -07 || Suzuki TL 1000 S -99 || Suzuki GSX 1100 E -82
Introduction/ride report: what's in an adventure?
K0m4 screwed with this post 10-28-2012 at 02:08 AM
K0m4 is offline   Reply With Quote
Old 11-04-2012, 02:29 AM   #3392
empeg9000
empeg9000's Avatar
Oddometer: 324
Originally Posted by K0m4 View Post
A week of fishing in middle Sweden - lots of fishing gear... 2x30 litre waterproof backpacks as side panniers, a 60l waterproof duffle on top. Dunno how much the tank bag holds.
Found a shelter to set my hammock up, only pictures I took of the set-up were from here:
That my friend is awesome!!
BMW R1200RT
MOA#125237
IBA#35312
Yes, BMW does in fact make Motorcycles!
http://empeg9000.blogspot.com/
empeg9000 is offline   Reply With Quote
Old 11-04-2012, 02:51 AM   #3393
canridertj
CANRIDER
canridertj's Avatar
Oddometer: 172
Question
Taking my first ADVENTURE trip next June 2013 to Labrador-and the ROCK..traded the 2010 r1200rt for a 2012 r1200gsa for this...can anyone recommend the absolute most important pieces of equipment\safety gear to bring?.....forget sleeping bags and the obvious stuff but things that you found later on you should-have-brought but didn't and now your in the s%@t..
thanks
tj
GO LONG, GO HARD or GO HOME
He who makes a beast of himself gets rid of the pain of being a man
canridertj is offline   Reply With Quote
Old 11-04-2012, 05:15 AM   #3394
K0m4
K0m4's Avatar
Oddometer: 551
Why thank you, it was indeed nice! Just to be clear though: I didn't build the shelter or the fire pit, just used it to set up the first two nights!
Old 11-04-2012, 05:20 AM   #3395
4corners14
4corners14's Avatar
Oddometer: 659
Bear spray........without it, you may literally be "in the s%@t?
Personally, I always carry a spare set of throttle cables, you can ride out without a usable clutch lever, not so easy without a throttle. My spare set saved a fellow 990 rider just this last summer.
4corners14 is offline   Reply With Quote
Old 11-04-2012, 05:42 AM   #3396
empeg9000
empeg9000's Avatar
Oddometer: 324
Ha! Why I never would have guessed. Excellent spot. In the Adirondacks you have to hike to lean-tos
BMW R1200RT
MOA#125237
IBA#35312
Old 11-04-2012, 06:49 AM   #3397
canridertj
CANRIDER
canridertj's Avatar
Oddometer: 172
interesting..throttle cable... what about tire repair kit and pump?...
Old 11-04-2012, 07:00 AM   #3398
BigEasy
BigEasy's Avatar
Oddometer: 1,770
Yes, bring them. Best insurance you can by to prevent flats
All who wander are not lost
"Play hard and FLOOR IT" Stevie Ray Vaughan
just remember: the only difference between genius and stupidity is genius has limits
BigEasy is offline   Reply With Quote
Old 11-04-2012, 07:04 AM   #3399
canridertj
CANRIDER
canridertj's Avatar
Oddometer: 172
now, there are so many types of pumps...do those small co2 cartridges really work as well as they claim?..how many cartridges to fill a tire?....as for the tubeless tires I would imagine the plug kit is a worthwhile investment....some pumps are battery operated but if I can downsize to a much smaller unit, I would conserve space for ..other things....hence my reason for the co2 question...
Old 11-04-2012, 07:11 AM   #3400
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Sean-0 is offline   Reply With Quote
Old 11-04-2012, 07:29 AM   #3401
BigEasy
BigEasy's Avatar
Oddometer: 1,770
Check yer pm's
Old 11-04-2012, 02:09 PM   #3402
AUSSIEADV
AUSSIEADV's Avatar
Oddometer: 278
Will be hard mounted under the tank where the ABS unit usually sits.
AUSSIEADV is offline   Reply With Quote
Old 11-04-2012, 04:03 PM   #3403
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
BMW F650GS Dakar Camping/Touring Setup
Dry Wx Touring/Camp without Watershed Dry Bag
x2 OR stuffsacks/ x2 Rotopax/ x2 Wofman Dry Expeditions
Wet Camping (expected)
Same as above w/Watershed Dry Bag
Top: Watershed dry Bag (if needed)
Outdoor Research Stuff Sack w/Eureka 2xt Tent, Thermarest NeoAIR and folding camp chair.
Outdoor Research Stuff Sack w/Sleeping bag, Marmot Precip Rain Gear Pants / Jacket, MTN HDW Insulated pants/jacket, OR hat, OR gloves, Petzl headlamp.
Rt Side: Rotopax 1gal H20, w/Wolfman Expedition Dry Bag w/8-10 Mountain house, Ramen, LG Jetboil, spork, matches, fire paste, headlamp.
L Side: Rotopax 1gal fuel, w/Wolfman Expedition Dry Bag w/4x zip off pants/expedition shirts, flops, shower kit. (rain gear, headlamp on top)
Ogio Vest w:
Front: SPOT Tracker, Camera, GMRS/FRS Radio, Torx/Ratchets, Driver/Vice Grips, Spark Plug, Fuses, Spare GPS, Iphone w/spare juice, Batteries, powerbars, headlamp.
Back: 1LG Camelback, F/R tubes, inflation kit, tire levers, JB weld, clamps, xtra levers, Fork Seals, Head Bearings, Brake Pads, Throttle Cable, Zip Ties and break fluid. Med Kit
Still has room for 2xMSR of fluid/fuel if needed. Spreadloads tools into a comfortable vest/workable platform w/o breaking into the bike bags.
I can go up to two weeks easily on road/trail if not more, just need to replenish food/water/gas ( Easy to come by when empty, unless off road the whole time). Obviously, if I don't need it, well, I don't bring it or replenish at stores. This is a camping setup w/a planned destination. Not a weekend riding setup. Go light whenever possible!
nomad5326 screwed with this post 04-05-2013 at 01:18 PM
nomad5326 is offline   Reply With Quote
Old 11-04-2012, 09:11 PM   #3404
4corners14
4corners14's Avatar
Oddometer: 659
Sorry, I thought that fit under the "obvious stuff"
I carry 3 of the aluminum Motion Pro tire irons with the closed end wrenchs included in the sizes of my bikes axle nuts , and a 12 volt air pump from Aerostich. It's very small and works great. The tire irons weigh next to nothing.
Old 11-05-2012, 03:09 PM   #3405
BTL
WINTER!! UGH!
BTL's Avatar
Oddometer: 420
[IMG][/IMG]
Everything for 10 day trip. Tent and sleeping bag etc. I have Pico camp chair stashed on bike also. I camped for 10 days with this set up. New GSA with boxes is a god send..
BTL is offline   Reply With Quote
Times are GMT -7.   It's 11:37 PM.
