12-19-2009, 03:37 AM
#1606 | |
Lost when found..........
Oddometer: 1,058
![]() jet is good, starts 1-2kicks cold and 1 hot now, theres a bit of a lag in midthrottle but thats cos i havent adjusted the midrange jet to allow for the different pilot. point is, its fkn awesome man thanks! as for the carbs, its a bit of an excessive exercise to find the earlier carbsn aus (not worth getting ones from USA), not to mention how much they would cost. im pretty happy with how the bike is set up at the moment so it shouldnt worry me whether i have an air screw or not. changing all the jets is only a 5 minute job anyway.
- Charlie 125cc Salt Racer - God of Speed Thread 'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.' - '85 XL600R-L-M-PDGSAZ |
12-19-2009, 03:42 AM
#1607 |
Oddometer: 1,058
in a way its probably good that i dont have one because i know that if i did i would be adjustingit all the time, you dont really need that much room for adjustment, there are enough other ways to change the mix, Soichiro was probably trying to just make it simpler for us mere mortals by removing it.
still...... now i feel like mine is the model for idiots and the earlier ones are for the pros.
12-19-2009, 07:05 AM
#1608 | |
¯\_(ツ)_/¯
Oddometer: 1,246
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
12-19-2009, 07:47 AM
#1609 |
Semi-Adventurer
Oddometer: 9,822
mdkm85, before you spend the bux on a new CDI, see whether someone is willing to plug yours into their bike.
When I thought I needed a CDI, Zombie did this for me, and his bike started right up. The good part is I saved the price of a new unit. The bad part is I still don't know what is wrong.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
12-19-2009, 08:02 AM
#1610 | ||
Semi-Adventurer
Oddometer: 9,822
IE: Quote:
12-19-2009, 09:21 AM
#1611 |
¯\_(ツ)_/¯
Oddometer: 1,246
Not only do these engine not like high rpm, it's a waste to twist them like that because the are well out of the power by the stock 7500 limiter. The 250/400 CDIs also have more aggressive timing curves which can be a problem with high compression pistons.
12-19-2009, 04:16 PM
#1612 | |
Bronze Age Fall Guy
Oddometer: 5,116
Its all about that midrange torque. I have a couple of bikes and by far my favorite motor is the XL600 when tooling around under 65 mph. Blasting down rough dirt roads the motor is in its zone and surpasses the suspension very quickly.
Hate gets you nowhere. |
12-19-2009, 04:44 PM
#1613 |
Oddometer: 1,058
aftermarket CDI rev limiter issues
in regards to you guys worrying about the cdi's rev limiter......
I was feeling a rather adventurous and curious so i did a top speed test. This of course included the rpms bouncing off the new CDI limiter and to be honest it did not seem much higher than the stock limiter. Not only that but with the retarding timing the new CDI has the engine feel much smoother at high rpms. If however you are worried about revving after a false neutral well might be an idea to shim that gear lever a bit tighter. I dont usually rev much higher than 6k even when really hunting. Im very cautious about this bike. If i thought something i was doing was not good for it i would stop it straight away and woul never ever suggest something to someone else unless i had tested it thoroughly. You all know how much i love this bike and as much as i hate the notion of a miracle fix.......so far..........this CDI has given the bike a new lease on life. It gives me a whole lot more confidence in the capability of my knowledge of the bike and my riding skills. I guess the same CDI technology was not available in 1983 as what is available now. Im not being paid to say this. It truly is what i believe and even if the cdi blows up and i need a new one in 1 year...........well its still totally worth it. As far as mods go this single thing has made more difference than every other performance mod i havde done PUT TOGETHER.
12-19-2009, 05:13 PM
#1614 |
Oddometer: 1,058
but as it has been said. You dont need to go anywhere near the rev limiter anyway with these engines and the CDI makes so much difference in other areas that the redline really is not something to worry about. Infact with the extra power i find im using lower rpms in general. So even if i miss a gear i am still 3000rpm away from redline. (and a slight tug on the bars away from an envious wheelie in 3rd.).
But anyway you guys make your own choices. Its just good to have all the options on the table. Important thing is that the CDI makes the biggest difference for the cheapest price and the least amount of mucking around. It might blow up tomorrow anyway........then id look like a right fool. But im not too worried as i lost all dignity when i registered with ADVRIDER 2 years ago
12-19-2009, 05:26 PM
#1615 |
Semi-Adventurer
Oddometer: 9,822
Uhh... I was just giving a heads-up on the nature of some CDIs.
I have no reason to accuse anyone of anything, and I certainly am not preaching how to use your bike (especially considering the way I ride mine. I just wanted to pass along a little information.
12-19-2009, 05:35 PM
#1616 | |
Oddometer: 1,058
And the CDI mod suits me cos im too lazy and poor to get a cam set or stroke/bore kit.
12-19-2009, 09:39 PM
#1617 |
Oddometer: 1,058
your quote mentioned something about making your own ignitions? how would one go about that i wonder. maybe it is possible to reprogram the other CDIs to have a lower redline?
12-20-2009, 09:40 AM
#1618 | |
Semi-Adventurer
Oddometer: 9,822
12-20-2009, 02:31 PM
#1619 | |
¯\_(ツ)_/¯
Oddometer: 1,246
2.) AFAIK, stock CDIs are not the least bit easy to reprogram. They are sealed and potted in epoxy and have chips inside that were never available to anyone outside of Honda. Ford did the same thing with the earlier EEC-IV by having Intel build the 8061 processor. It took a lot of reverse-engineering before the aftermarket got it sorted out.
12-20-2009, 09:14 PM
#1620 |
Oddometer: 169
Xr suspension
Got my remote res mounted up where my crank case breather/separator was.[IMG]
[/IMG][IMG] [/IMG][IMG] [/IMG]
