Old 01-16-2010, 09:12 AM   #1711
mcma111
mcma111's Avatar
Oddometer: 12,062
CDI Plug
Doug,
I dug through my wiring box and all I have is the 4 prong part of the harness. Can't find/don't have the 2 prong plug. Perhaps a trip to the local Honda dealer to see if they have any old harnesses to harvest from. Take the CDI with you. Don't limit the search to XL600. The XR harness will work also.
EDIT: I found this post. Check for a harness: http://sandiego.craigslist.org/nsd/mcy/1551425711.html
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 01-16-2010 at 09:18 AM
Old 01-16-2010, 01:50 PM   #1712
mdkm85
uni-cycler
Oddometer: 65
magic beans
Originally Posted by mrfixit54016
OK, I will say it....
The Ricky Stator IS the magic pill. Spend the money and be a happy man.
magic pill huh? alright i guess im just going to have to suck it and get one of them here real soon, ive been kinda dreading it for a while
mdkm85 is offline   Reply With Quote
Old 01-16-2010, 01:54 PM   #1713
mdkm85
uni-cycler
Oddometer: 65
Originally Posted by crag antler
Anybody have a spare wiring harness from a 85-87 XL600 laying around they want to get rid of??
I'm putting a newer CDI on my '83 and don't want to butcher the harness too much to do the install.
Here is a pic of what I am looking for. Thanx to Greg for the photo.
New style on left,83 on right.
I also have it posted in the "flea market".
Thanks as always.
I know you said you didnt want to butcher the wiring harness to much but i just went through this process and had to cut the old six prong wires and then used speaker wire connectors to attach to the new cdi, It actually looks clean with the speaker wire connectors its a perfect fit. nice and snug l
Old 01-16-2010, 04:38 PM   #1714
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Strip the wires about 1/2 inch from the end. Put a 3/4" long piece of heat shrink tubing on the wires and slide them away from the end of the wire so soldering heat doesn't prematurely shrink the tubing. With the plug's and the harness' wires stripped, push the strands into each other, intermixing them, then twist them together, keeping the wires parallel. Twist thoroughly so that they stay together. If this is difficult, try stripping more wire insulator so you have more wire to work with. Once the wires are thoroughly and securely twisted, solder them with a nice hot iron and rosin-cored solder. Heat the wire until solder will melt on the wire. It should "wick up" the solder until the wire strands are all soaked thoroughly in solder. Once all wires are soldered in this fashion and have cooled, slide the shrinkwrap tubes over each splice and heat the tubing, ensuring a good insulating seal. Either wrap the works in tape, or get a bigger sleeve of heat shrink and slide over the bundle of wires, for a nice tight, neat package. There. Your wiring harness doesn't need to be "butchered", and now you have the commonly available XR600 plug style, the only one you will need, wired into your XL600 harness. Cheers! Good job.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 01-17-2010, 08:25 AM   #1715
crag antler
In the woods lurking
crag antler's Avatar
Oddometer: 506
You couldn't get a photo of that,could you??
That sounds like a possible if I can't locate a plug. I have a lead on a complete wiring harness from a 96 XR600 with a plug that looks like what I need but....
Dealers around here are almost useless for parts, especially from leftovers.
Not like in the old days.
Example, went to get some new jets,122's and a 60 pilot. Doesn't carry pilot jets and quote " main jets only come in .5 size increments".
Doug aka crag antler
Florida Cracker in Southern Maine
2011 DR650
2000 Kawasaki Concours
1976 Yamaha DT400
crag antler is offline   Reply With Quote
Old 01-17-2010, 09:05 AM   #1716
mcma111
mcma111's Avatar
Oddometer: 12,062
CDI Plug
Doug,
Yesterday at the Honda dealer I looked through the box of harnesses and I could not find anything. I have the 4 point plug if you want.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-17-2010, 04:18 PM   #1717
mdkm85
uni-cycler
Oddometer: 65
Wire harness
try to get that pic later tonight or tomorrow, I still need to melt the wire covers around the wire so yea i need take off the tank anyways. I also bought some Di electric tune up grease ( stuff you put inside the boot of a spark plug) to ensure good insulation. I never put it there though, which I guess I will tonight or tomrrw. Once again, the speaker wire connectors is an extremely snug fit.
Old 01-17-2010, 04:54 PM   #1718
XLMadman
Oddometer: 4
XL600R camshaft
Hey fellow XL fans.
Anyone with good good camshaft? I have a 85 xl600r in need of a cam.
craig.white84@yahoo.com
Craig
XLMadman is offline   Reply With Quote
Old 01-17-2010, 05:49 PM   #1719
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
If the contact terminals inside the plug are the same size and type, you could pop them out of the original round plug and put them in a newer square one for a truly "factory" install. If you get a whole square pigtail and have a truly dead round-plug CDI, you could cut up the CDI and do some soldering to make a converter.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 01-17-2010, 10:10 PM   #1720
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Adequate for now, yes, maybe in a pinch if he is without soldering facilities. But a soldered splice with adhesive lined shrinkwrap is the only way to go if you want to never have to worry about it again. The method I described is impervious to corrosion, which cannot be said for any type of crimped-on splice. If you have acess to a soldering iron and solder, it is well worth the effort and shrinkwrap costs less than the connectors you'd be crimping. Do it right the first time and forget about it: solder-clad all the way!
Note: the above suggested procedure if done right is also in fact the ideal solution.
Old 01-18-2010, 05:25 AM   #1721
crag antler
Oddometer: 506
This is the way I will be connecting the wires. Right now it is just the hunt for the plug I am at.
2011 DR650
1976 Yamaha DT400
Old 01-18-2010, 12:16 PM   #1722
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Originally Posted by XLMadman
Hey fellow XL fans.
Craig
Mine is out of spec by a couple... thousandths? I think it is off by a couple points on at least 2 lobes. What I learned is that this is not enough to keep it from still being a total bad ass beast of a bike nonetheless. If you are looking for one that isn't scarred up after an injury-caused rebuild, this wouldn't be the case of course. Sorry, I usually have a pretty good inventory of XL and XR parts. Anyone else?
Old 01-18-2010, 12:17 PM   #1723
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Atta...boy?
Old 01-18-2010, 05:58 PM   #1724
XLMadman
Oddometer: 4
85 xl600r camshaft. Will a other xr cams work in this head?
Having trouble getting a camshaft for my xl600r.
I know the xr500r cam is the same. Will other cams work in this head. the xr650l looks close to the cam that I have.
Can anyone give me some options?
Honda has discontinued this cam-Bummer
let me know.
There has been plenty of stuff about compatibility of engine parts.
Old 01-18-2010, 06:17 PM   #1725
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
If I needed a cam i wouldn't even go wit OE Honda except for maybe a good used one off of ebay. Megacycles sells a higher performance cam as well as Webcams and I'm sure XR's Only has one.
Hate gets you nowhere.
Times are GMT -7.   It's 03:52 PM.
