Old 05-10-2009, 09:32 PM   #256
badweatherbiker
badweatherbiker's Avatar
Oddometer: 648
Clayjars or anyone else that may have pics of where you ran the oil lines from or that could tell me where I would very much appreciate it .
I also had some weird things going on today, every time I made a hard left turn the bike would cut off until I straightened her up again. Any suggestions?
badweatherbiker is offline   Reply With Quote
Old 05-10-2009, 11:57 PM   #257
God of Speed
Lost when found..........
God of Speed's Avatar
Oddometer: 1,058
make sure the manual decomp cable isnt fouling on something.
where to run the oil lines from is very obvious, theres a steel line coming from under the frame where the dipstick is, plumb the cooler into that then into where the same line goes into the oil pump is on the right side of the engine. thats it.
because they werent built with one orignally there isnt really a perfect spot to put it, mine is on the frame, so i had to cut the guard back to fit it. thats only because i didnt wanto have to deal with oil lines that would have go up past the steering head and move around.
- Charlie
125cc Salt Racer - God of Speed Thread
'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.'
'85 XL600R-L-M-PDGSAZ
God of Speed is offline   Reply With Quote
Old 05-11-2009, 04:48 AM   #258
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 511
Oil Cooler
Badweather,
If you read Zombies thread about reviving his XL600, you will find all sorts of info including these pictures of plumbing the oil cooler:
http://www.advrider.com/forums/showt...50#post8373450
Here are the pics from that thread...
mrfixit54016 is offline   Reply With Quote
Old 05-11-2009, 09:33 AM   #259
Easy-Z
Underinteresting
Easy-Z's Avatar
Oddometer: 3,267
Another Revival
I picked up an '85 XL600 a couple of weeks ago as a project. The engine had the common problem of worn lobes and rocker arms. The PO had the engine out of the frame and in pieces so I figure while I'm at it I would like to repaint the frame. I'm running into a problem taking everything off that I was hoping I could get some suggestions with.
There's a nut on the airbox assembly that won't come out. I can feel the nut turning in the plastic behind it. There's no way that I can see to get behind it and hold the nut because it's completely enclosed. Is there a way to split the box? I don't see it if there is.
Any one have any suggestions?
Middle bottom of this picture.
Oh, and this project is a first for me. So in the response feel free to talk to me like I'm an idiot. Because well.....I am!
Easy-Z is offline   Reply With Quote
Old 05-11-2009, 11:01 AM   #260
mrfixit54016
Oddometer: 511
Sawzall!
Seriously, I have one on my airbox that does the same thing as yours. Can't think of anything to hold that nut still.
Old 05-11-2009, 11:24 AM   #261
ktmmark
have bike must travel
ktmmark's Avatar
Oddometer: 290
Thumb try this
Best way is to drill the head off the bolt ,then you can remove the air box & bond a new nut in
ktmmark is offline   Reply With Quote
Old 05-11-2009, 11:29 AM   #262
mcma111
mcma111's Avatar
Oddometer: 8,167
Drill It
+1 on Drilling the head off.
Once the airbox is free then you can attempt to fix the stuck blot shank.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-11-2009, 11:30 AM   #263
badweatherbiker
Oddometer: 648
We have a winner! Wqterscm, the decomp cable was binding when I made a hard left causing the bike to shut down, shouldn't have hurt anything right?
I was adjusting my controls a few days ago, must have moved it too far out.
On another note, can the emissions cannister be removed?
Old 05-11-2009, 02:19 PM   #264
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,180
Once the airbox is free then you can attempt to fix the stuck bolt shank.
I used a dremel when that happened to me. I have yet to fix it. I'll probably find some similar filler plastic and melt it in with a torch until there is a block of plastic. Then I'll drill a nice hole and insert a heated, knurled threaded tube. Still not sure where I'll find that. I've got carb tuning higher on my priorities.
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 05-11-2009, 04:22 PM   #265
crag antler
Viva Moosehead
crag antler's Avatar
Oddometer: 376
So while organizing my bench for when my parts get here
I came across some gaskets from the motor. It seems that the valve cover gasket is aluminum or tin.
Is this OEM?
It looks to be in great shape and wonder if I can re-use it.
The cylinder gasket looks tin also and in good shape but I have one on order.
Thanks.
Doug aka crag antler
Florida Cracker in Southern Maine
2000 Kawasaki Concours
crag antler is offline   Reply With Quote
Old 05-11-2009, 05:09 PM   #266
Reposado1800
Bronze Age Fall Guy
Reposado1800's Avatar
Oddometer: 5,234
Is this OEM?
Thanks.
Yes you can reuse it. it is actually a precise shim. Use a thin bead of RTV on it or use copper coat spray. I have had my motor out about 5 times now and done both rtv and copper coat with no issues. The head gasket should be replaced.
Hate gets you nowhere.
Reposado1800 is online now   Reply With Quote
Old 05-12-2009, 01:01 AM   #267
God of Speed
Oddometer: 1,058
2 things happened today:
tacho stopped working, oil has been leaking out of where it goes into the head for ages so i dont know if its the tacho cable or the mechanism itself. i hope not the latter.
also i realised that a strange clinging noise when going over speed bumps is not the chain guard hitting the chain. it sounds like 2 pieces of metal banging together and i think it might be the broken subframem but its not broken in such a way that that noise might be possible...........
- Charlie
God of Speed screwed with this post 05-12-2009 at 07:55 AM
Old 05-12-2009, 06:04 AM   #268
God of Speed
Oddometer: 1,058
http://thekneeslider.com/archives/20...engine-update/
i cant think of anything witty to say about this link. just look.
INSANE...........
there we go.
- Charlie
Old 05-12-2009, 12:52 PM   #269
MaXYaX
MaXYaX's Avatar
Oddometer: 94
INSANE...........
there we go.
Umm...wow, just...wow
"This is a threshold moment Johnny...STEP THROUGH!" - The Toecutter
'72 CB500
'78 GS1000
MaXYaX is offline   Reply With Quote
Old 05-12-2009, 01:59 PM   #270
scrminbanshee
Awsome
scrminbanshee's Avatar
Oddometer: 801
INSANE...........
there we go.
some things just get me all hot and bothered...
scrminbanshee is offline   Reply With Quote
Times are GMT -7.   It's 09:58 PM.
