Old 05-12-2009, 02:59 PM   #271
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
Originally Posted by scrminbanshee
some things just get me all hot and bothered...
Think of all the poor bikes that had to die for that thing to be made.
Hate gets you nowhere.
Old 05-12-2009, 03:45 PM   #272
JStory
JStory's Avatar
Oddometer: 2,855
There's an OEM XL600 luggage rack on eBay right now.
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is offline   Reply With Quote
Old 05-12-2009, 05:21 PM   #273
crag antler
In the woods lurking
crag antler's Avatar
Oddometer: 533
Shhhh ,been watching and waiting.
I'll probably wait until I get the motor back in and runnig before I spend any more $$.
Doug aka crag antler
Florida Cracker in Southern Maine
2011 DR650
2000 Kawasaki Concours
1976 Yamaha DT400
crag antler is offline   Reply With Quote
Old 05-12-2009, 06:01 PM   #274
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
I got my idle situation straightened out. It was a too-tightly-adjusted valve.
Before:
After:
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 05-12-2009, 07:58 PM   #275
scrminbanshee
Awsome
scrminbanshee's Avatar
Oddometer: 816
does anybody know if i could put my 85 engine in a p1 xr600r frame? do you what will work and what won't...
scrminbanshee is online now   Reply With Quote
Old 05-12-2009, 08:31 PM   #276
scrminbanshee
Awsome
Oddometer: 816
also does anybody know if i can get a mso for the bike and then get it titled her in washington.... if so how do i get a mso? thanks
Old 05-12-2009, 08:37 PM   #277
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 676
The 85 has dual carbs which will not fit into the 91 bike without major headaches. Check out Zombies thread where he tried the opposite switch.
mrfixit54016 is offline   Reply With Quote
Old 05-12-2009, 09:10 PM   #278
Zombie_Stomp
Aspiring human
Oddometer: 2,231
It's a '91? I thought he said "p-1", but I was confused by that.
In all that I've been through with these bikes and their engines and accessories, I say do what you must, but keep the single carb/dual carb heads in their appropriate frames. Switch heads/carbs if you really want to. It's another case of "anything's possible for a certain amount of money".
Old 05-12-2009, 09:16 PM   #279
scrminbanshee
Awsome
Oddometer: 816
thanks for the info i will just try nd keep the frames and engines with the rite ones....i am trying to get some title issues figured out ....
Old 05-13-2009, 06:54 AM   #280
God of Speed
brrraaaaAAAAAAAP
God of Speed's Avatar
Oddometer: 1,105
Joel:
was glad to have the difference illustrated in a poorly running bike and a good one, thanks. im even gladder that my bike sounds exactly the same as the second video, except for my noisy timing chain. i always feel lucky that although ive regularly checked the clearances they were always perfect and ive never had to touch them in 15000ks of riding.
im looking at the moment for a moderately priced timing chain so i can get it over and done with. so far on the list:
-timing chain
-yoshi gsxr exhaust
-subframe
-custom sump guard with engine protector bars
-bigger tool box
and the illusive, if somewhat too tall, xr suspension.
and a question about the timing chain:
if im going to pull it apart for the chain, should the tensioner thingy be changed aswell? i remember you saying that it was the weakest part of these engines.
- Charlie
125cc Salt Racer - God of Speed Thread
'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.'
'85 XL600R-L-M-PDGSAZ
God of Speed is offline   Reply With Quote
Old 05-13-2009, 08:19 AM   #281
mcma111
mcma111's Avatar
Oddometer: 12,550
Cam Chain
Waterscm,
If your going to change the timing chain you may as well do the chain tensioner. Never had any problems with mine back in the day but who knows. The way to tell if the chain is bad is to put the engine at TDC and check the cam timing marks. Unfortunately it requires the rocker cover being off. There are 3 marks on the cam gear. 3, 9 and 12 O'clock. The 3+9 line up with the head and 12 o'clock is at well 12 o'clock. If the marks line up at 3:30 or 8:30 then the chain is streched.
It will involve taking the rocker cover off which requires either the engine out of the frame or completely loose so it can be tipped to the right to get the cover off. Also the clutch cover comes off to access the crank end of the chain.
Parts required: Cam chain,tensioner, rocker cover and clutch cover gaskets. Depends how good you are at spinning the wrench's but it's about a days work.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-13-2009, 06:56 PM   #282
God of Speed
brrraaaaAAAAAAAP
Oddometer: 1,105
Originally Posted by mcma111
Waterscm,
after watching zombie's video im pretty sure the timing isnt out. i just dont like the noise of the chain slapping into the engine casing, but obviously the tensioner does enough too keep it in time?
provided thats what the noise is.
ive been googling this problem on xls and found that a semi-popular mod is to install a manual tensioner. but even the useage of that sounds too copmlicated for a mechanical luddite such as myself.
- Charlie
Old 05-13-2009, 07:38 PM   #283
Zombie_Stomp
Aspiring human
Oddometer: 2,231
I've known it is possible to specially machine the head to have something adjustable behind the place the cam chain tensioner spring rests in order to re-tension it. I don't know how effective this could be though.
I'd be very interested in any photos or anything you've found on this subject.
Old 05-13-2009, 07:49 PM   #284
Plink
Dual Sport Junky
Plink's Avatar
Oddometer: 43
XL600 Luv
Ok I been on here for awhile...never post just read. I've owned my XL for about two years now....LOVE IT! Wish I would have bought one years ago. Here are a few before and after pix...enjoy!
BEFORE
After
2000 CBR1100XX Super Blackbird
Corbin Seat
Plink is offline   Reply With Quote
Old 05-13-2009, 10:08 PM   #285
God of Speed
brrraaaaAAAAAAAP
Oddometer: 1,105
well ive only found about 3 mentions of it on the entire interweb so far:
one with pics in dutch:
http://www.motor-forum.nl/forum/list...938729#4938729
another person said they had done it:
http://www.motorcyclesurvey.com/revi...r596/comments/
(check the scond last comment) and for some reason the person who wrote the last comment thinks the xls weigh 180kgs? i dont think so! its 134 dry.
and number three was someone saying they were going to do it.
- Charlie
Times are GMT -7.   It's 03:12 PM.
