01-30-2012, 09:48 AM
#5461 | |
Semi-Adventurer
Oddometer: 9,839
![]() I have never run across this. On the rare occasion, it might push back about as hard as I kicked, but nothing more. Maybe I am just lucky.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
01-30-2012, 10:14 AM
#5462 |
Olds Cool Adventurer
Oddometer: 2,680
I've been luck too. I always made sure I had something stronger than tennis shoes on when kicking it, though. The hardest it ever kicked back on caused my knee to hit my chest, and took a chunk of rubber off the bottom of my High Tec hiking boot.
01-30-2012, 10:38 AM
#5463 |
¯\_(ツ)_/¯
Oddometer: 1,246
I got kicked the one time I gave my (then new-to-me) XR some throttle when trying to start it. One time. Luck isn't involved; it's technique. Now I can kick mine in flip-flops without fear....maybe even barefoot.
![]() XLs have a shorter kickstarter, though, so I don't think I would try that barefoot....
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
01-30-2012, 12:03 PM
#5464 | |
Oddometer: 467
when i first got the bike i got kicked HARD 3 times..after that i figured out its own personal quirks..like NEVER touching the throttle...if you want to pull the throttle be prepared to have your foot in orbit! sh0rtlife screwed with this post 01-30-2012 at 05:18 PM |
01-30-2012, 04:49 PM
#5465 | |
Oddometer: 640
01-30-2012, 05:19 PM
#5466 |
Oddometer: 467
im just shy of 200lbs myself at 6'4 ...my gearing "was" 13 41 now its 15 41..i lost the "sky high" be carefull or your going over and replaced it with hey were hovering the wheel in comfort not crazyness...and thats with me nut hugging the tank
01-31-2012, 07:54 AM
#5467 |
Originally Posted by High Country Herb Oh, they kick back pretty hard. ... I have heard stories about people getting the kick starter poked through their shoe into the bottom of their foot. ... Really? ![]() It`s all in the technique I guess. I start my XL in thongs/flip flops all Summer:-)
Iain (master of disaster) Moto Guzzi 850 le mans 11 1981 Moto Guzzi 850 le mans 11 1982 Moto Guzzi 1000 SP 1980 Ducati 900 SD 1982 Simpson 50! DT 175 x 2 TS 185 KLR 650 GT 250 HD 1200 Shovel `72 93 " Evo (Delcron S&S) Lowrider Triumph T150V 1974 Triumph T150V 1972 Kreidler 50 1962 HONDA XL600R !!! |
01-31-2012, 01:10 PM
#5468 | |
Fearless of Falling
Oddometer: 873
01-31-2012, 03:12 PM
#5469 | |
Oddometer: 820
I ruined a pair of shoes kicking the XL600 when it had a bad CDI. The lever did actually poke through the bottom of my shoe.
Brandon Reed 2009 Husqvarna TE610 |
01-31-2012, 05:43 PM
#5470 |
Oddometer: 64
There's one thing I haven't had problems with.. My pig kickin me into oblivion. I really do think it's all about the technique and like everyone else says: Finding TDC then kicking past an inch or so. I for one always have my knee slightly bent and try not to extend it completely when I kick, so if it does kick me back I won't go flying. I 'm 5'10" and weigh 160 lbs. One thing I can remember when I first got my bike is sweating balls and a sore sole. She never kicked back though. I'm guessing that was the auto decomp working like it was supposed to. I recently removed the auto decomp entirely from my bike. She fires up so much easier without it, but I wouldn't allow anyone inexperienced to attempt to turn her over without completely explaining and demonstrating the technique, first. Unless it was my brother-in-law
haha jk
When life throws you curves, aim for the apex 1986 Honda XL600R |
02-08-2012, 10:07 PM
#5471 |
Oddometer: 2
Need Help with 84 XL600R
Not sure where to post this... but just inherited an 84 Honda XL600R that doesn't start. Was told by a motorcycle mechanic that motor was stuck and not worth the trouble. Wanted to turn this into a learning experience and was hoping that someone would like the challenge of helping me through this
Manuel213 screwed with this post 02-12-2012 at 06:52 PM Reason: Image |
02-08-2012, 11:06 PM
#5472 | |
Oddometer: 467
first thing i can sugjest is check the oile..ie pull the drain plug and see if any actual oil comes out..if none..worry a lil but not alot..if water comes out...well..worry alot....next pull the spark plug and GENTLY try and push the kick start over and see if she is actualy stuck...if it wont...put it in gear and rock it back and forthe somewhat gently ...she might break free...if this all fails pour in some CAR automatic transmission fluid..the cheepest stuff you can into the spark plug hole(this is all going by what id normaly do on micro car engines as well as big v8s even diesels)...let it sit for a week..come back and try getting her to crank over via tire or kick start..if still nothing..rip the engine out and tear her down..more than likely the slug is stuck in the jug...now mind you i just had an old 1950s 2cyl 4stroke that was stuck..ive got an ODD combination that will eventualy free the slug in a SAVEABLE form...pull the head and hose the cracks with croil..next add a bit of diesel as well as some trans fluid..let soak....if your impatiant heat the jug wth a torch on low ..yes you will light the stuff on the top on fire...thats not a big deal and the heat HELPS force the fluids past the rings breaking it free...and you may have to do this over sseveral days....tho idealy your trying to heat only the jug and not the slug....some whacks to the slug with a rubber mallet wont hurt none and will help too...eventualy it will break free...i SAVED even the rings on an the 2cyl that was frozen solid....as there was zero damage to anything..it was simply stuck from a bit of rust in the top of the bore but nothing a good scuff with the hone didnt clean up....its the nature of an engine..it doesnt take much in the jug to get a slug stuck now if its rolling over just fine its a whol nother can of worms looking for electrical gremlins which can be quite fun just send it my way ill give it a good home...so i can part with my xl500 |
02-09-2012, 03:36 AM
#5473 | |
from the land of OZ
Oddometer: 253
Stu in FNQ The early bird catches the worm, but the second mouse gets the cheese. Growing old is mandatory... growing up is optional. 1985 XL600R 1988 XR600 |
02-09-2012, 05:25 AM
#5474 |
Location: Cairns ,Australia...soon to be North Carolina
Oddometer: 65
85 xl600r paris-dakar
![]() My Xl600r engine pulled out ready for rebuild hopefully painting frame this weekend |
02-09-2012, 03:34 PM
#5475 | |
Oddometer: 2,680
If the motor turns out to be toast, you could always swap in something else. I always thought it would be cool to squeeze in a Honda GL500 sideways v-twin. Not your cup of tea? How about an e-start XL650 motor? |
