Old 03-07-2012, 05:01 AM   #5551
Reposado1800
Bronze Age Fall Guy
Reposado1800's Avatar
Oddometer: 5,134
Originally Posted by Edouard_Bracame View Post
Just got the information today that cmsnl.com got camshaft available again in their stock.
It says only one left!
Hate gets you nowhere.
Reposado1800 is online now   Reply With Quote
Old 03-07-2012, 05:22 AM   #5552
mcma111
mcma111's Avatar
Oddometer: 8,011
And at the current currency rates that cam comes out to $275.0. May as well get a Mega Cycle cam.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-07-2012, 08:54 AM   #5553
jgrady1982
jgrady1982's Avatar
Oddometer: 760
Xl600R rear suspension link
Hey,
I am looking for a rear suspension link for my XL6R. The link links the rear shock to the swingarm...I think. There are two zerk fittings on it, and it looks kind of like a dog bone. If anybody has an extra and is willing to part with it, I would be happy to pay for it.
Thanks,
Jack
jgrady1982 is online now   Reply With Quote
Old 03-07-2012, 09:32 AM   #5554
mcma111
mcma111's Avatar
Oddometer: 8,011
Originally Posted by jgrady1982 View Post
Hey,
Thanks,
Jack
I'll look when I get home today but I kinda don't think I have one. I'll check anyway. Ya never know.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-07-2012, 10:27 PM   #5555
Watcher
Oddometer: 40
The Hot Cam stage one arrived today as well as the 1989 XR600 cylinder head cover. Just doing a cursory fitting on the 1986 Xl600R, the only snag is that I'll need the XR bearing that goes on the sprocket end of the camshaft, as the Hot Cam shaft size is a bit smaller than the XL. It is also necessary to flip the sprocket over to get the cam chain alignment right. Red1 in his posts had indicated that he had to mix and match rockers but as far as I can tell everything lines up fine. Pics tomorrow.
I know about when the ride begins, I just don't know when it's going to end.
Watcher is offline   Reply With Quote
Old 03-08-2012, 12:14 AM   #5556
lookfar
from the land of OZ
Oddometer: 253
Question need some help
Having a problem with my XL6.
Lately, when started, it has developed a miss, right off the idle, quite often it will just stop. It will start again immediately on the first kick, sometimes keep running, often just stop again.
The problem is just off idle, plenty of power and no hesitation when throttle is applied.
Have pulled primary carby apart, blown out all the passages that I could see, cleaned the jets with compressed air.
Bike has a new ricky stator, coil, CDI and spark plug.
I have replaced the fuel and cleaned out the lines....
Got me confused...any ideas???
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL600R
1988 XR600
lookfar is offline   Reply With Quote
Old 03-08-2012, 05:20 AM   #5557
Reposado1800
Bronze Age Fall Guy
Oddometer: 5,134
Got me confused...any ideas???[click to show pic]
Did you clean out the emulsion tubes right under the main jets? They will collect fine grit over time.
Old 03-08-2012, 10:34 AM   #5558
sh0rtlife
Oddometer: 467
tear the carb down blow it out with carb clean and then blow it out with 120psi from the air compressor..make sure you hit EVERY port..odds are youve got a lil something in there well hidden
sh0rtlife is offline   Reply With Quote
Old 03-08-2012, 06:35 PM   #5559
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 643
Not when you consider the cost recommended spring kit and rocker face hardwelding for the Mega Cycle. It's over $600 when you include all that jazz.
Carter Pewterschmidt is offline   Reply With Quote
Old 03-08-2012, 08:31 PM   #5560
hateithere
anytime now
hateithere's Avatar
Oddometer: 2,353
Hey,
Thanks,
Jack
If it's the same as an 84 xl250r, it looks the same compared to my 600 (if anyone knows for sure, chime in) then I have one and I'm in Akron it'd be a cheap, reasonable price let me know-kevin
hateithere is offline   Reply With Quote
Old 03-08-2012, 09:48 PM   #5561
Humboldt Brad
new Adventure rider
Oddometer: 20
holy metal crap in my oil batman
ohhh boy I'm in trouble..... I was riding and that noise(see my photobucket) got louder I checked my oil its ugly it wasent before I drained it and took out all the screens and in the screens there are some serious metal flakes... do you guys think I could get more for it parting it out or just selling it. it still runs and drives good I'm just not sure what to do...
talk about depressing I love this bike
pavement, dirt or water as long as I'm going fast enough to do something stupid
http://s1070.photobucket.com/albums/u487/humboldtbrad/
85 xl 600r frankinbike
Humboldt Brad is offline   Reply With Quote
Old 03-08-2012, 09:52 PM   #5562
sh0rtlife
Oddometer: 467
why not rebuild it?...so long as its not the cam its relitively cheep bottom end..its the head up that has the heafty cost of NLA parts
Old 03-08-2012, 10:56 PM   #5563
Watcher
Oddometer: 40
That's one of the reasons to look for an alternative.
1989 Rocker Cover from E-bay
The Description when purchased said it was a 1989 Hot Cam, The box it came in said 93 XR650L.
Installed in cylinder head cover with sprocket reversed. Also the sprocket end of the camshaft is larger on the XL600R so to make it work a 1989 XR600 Bearing was ordered. This was my best guess to how it would fit when in the head.
One extra large rocker.
The rocker cover and cam sit on the 1986 head and so far there doesn't appear to be any obvious problems other then the center journal seems a bit off center. The camshaft bearing will be here Wednesday.
Old 03-08-2012, 11:32 PM   #5564
Watcher
Oddometer: 40
+1 for rebuild or at least tear it down to see what the damage is.
Old 03-09-2012, 07:27 AM   #5565
mcma111
mcma111's Avatar
Oddometer: 8,011
Brad,
Do the olde screw driver Stethoscope trick. Get the biggest screw driver you have and put the handle to your ear and the tip at different places on the motor to try to locate where the noise is coming from. You can also remove the rocker inspection covers and look at the cam and rockers. Check if one or more rocker arms has a lot of play. That will tell you right there what's wrong.
I'd wash the engine and frame above the engine first to keep dirt from getting into the motor
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 06:32 PM.
