03-09-2012, 09:32 AM
#5566 | |
¯\_(ツ)_/¯
Oddometer: 1,246
It sounds like your bike lost a rocker and the cam for whatever reason.
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
03-09-2012, 07:26 PM
#5567 | |
looking for bionics
Oddometer: 594
Thank you very much for posting on this cam/valve cover swap. I had been wondering what I would do to fix my 83/4 if I had to replace these parts. Could you take some more photos and elaborate further on the timing chain alignment and cam bearing differences when you get the rest of the parts? I understand you are using the older timing chain sprocket but mounted on the other side of the cam. Does that cause any centering problems with the camshaft? Is the back of the sprocket flat enough to to match the cam and spin without wobble? How good is the chain alignment with the crank sprocket? I thought you might have to change cam chain/sprockets to the newer style as well to make this work. Glad to see that appears not to be the case. Did you plug up the auto decomp oil hole in the cam shaft? Or did the aftermarket cam not have that extra hole? Lastly, the valve covers on my 83/4 XR does not have the half moon journal for the center of the cam. I think Honda added that in 85? to allow more oil to reach the leftmost two cam lobes. At least I couldn't think of any other good reason to add that journal to the valve cover when the original design didn't appear to need it. |
03-09-2012, 07:30 PM
#5568 |
¯\_(ツ)_/¯
Oddometer: 1,246
'88+ Hot Cams don't even have a provision for a decompressor, so there's nothing to plug.
(There are no HCs for pre-'88 engines.)
03-09-2012, 10:26 PM
#5569 | ||
Oddometer: 40
This is the Cam in a used E-bay head ( the center journal in the old head was pretty chewed up ) with the sprocket reversed. ![]() A better angle. There is duct tape wrapped around the end of the cam forming a bushing for the original bearing. It's pouching out past the end of the cam some, but I wanted an idea of how well it would all line up too. It looks to me to line up exactly, right on with the original. ![]() The only difference in the bearings seems to be that the sprocket end of the XL600 camshaft is 20mm in diameter with the 1988 and later cams being 18mm. Both are 20mm on the opposite end. The length with bearings against the dowel pins is identical. Perhaps a 1mm bushing would allow using the original bearing though. The sprocket sits flat on the Hot Cam when reversed and it looks solid. There are shearing forces on the bolts but it's hard to see how they would be any less if mounted traditionally. I don't anticipate any wobble though. ![]() Quote:
I wanted to add that there is a used 1985 XR600 cam currently on E-bay, three day auction, 20 bucks and 0 bids ( so far ), the description says in good condition.
I know about when the ride begins, I just don't know when it's going to end. |
03-10-2012, 05:57 AM
#5570 | |
Oddometer: 1,626
http://humboldt.craigslist.org/mcy/2890589560.html But if you are, my offer still stands to come by and have a look at it for ya. I left a voice mail for you a couple weeks or so ago. Let me know.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
03-10-2012, 10:10 AM
#5571 | |
looking for bionics
Oddometer: 594
To sum up what I've learned: 1) New style cams take bearings with smaller ID requiring a new bearing. 2) Old style cam chain can be retained if the chain sprocket is reversed and mounted on opposite side of cam chain mounting flange on new cam. More questions: Is the hot cam a requirement to do it this way due to the sprocket mounting flange? I see that the hot cam is machined flat on both sides of the mounting flange. I don't think the stock Honda cam is that way, at least my old style cams are cast with only one side machined. Best close up photo I could find of my mounting flange: ![]() I suppose one downside to mounting the sprocket in reverse is that the alignment marks aren't visible in the normal fashion, making gauging cam chain stretch harder? |
03-10-2012, 12:36 PM
#5572 |
¯\_(ツ)_/¯
Oddometer: 1,246
Here's something to look at until I take a better-aligned photo in a little while.
03-10-2012, 01:32 PM
#5573 |
Oddometer: 7,986
Parts
Anyone looking for XL600 parts. I have a bunch of XL600 stuff that I am tired of looking at and would like to see it leave.
Various engine bits, rear wheel complete, wiring harness complete, almost a full set of 83 plastic. No cam, front wheel, seat or exhaust. A couple sets of later XR600 forks. PM me if your looking for something.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
03-10-2012, 07:43 PM
#5574 | |
Gittin' Along
Oddometer: 81
Looking for a front brake caliper. Also, if anyone knows what years the front brake caliper was used.
02 DRZ400E - slightly totalled 96 VFR 750 97 BMW F650 78 BMW r60/5 |
03-10-2012, 08:23 PM
#5575 |
Oddometer: 7,986
I have two calipers but both are stick. I can compare it to a later XR600/XR650l caliper.
03-10-2012, 08:35 PM
#5576 | |
new Adventure rider
Oddometer: 20
so where is the best place to get parts(gaskets and such) and I'm going to need to seriously clean out the oil system any suggestions
pavement, dirt or water as long as I'm going fast enough to do something stupid http://s1070.photobucket.com/albums/u487/humboldtbrad/ 85 xl 600r frankinbike |
03-11-2012, 12:21 AM
#5577 | ||
Oddometer: 40
Here are the two cams, the one on the left (with the duct tape) is the Hot Cam, the other is the original XL600 cam. They both have a similar profile just reversed. ![]() The sprocket mounted on the Hot Cam the way it seems to be on the 1988+ cams. Mounted this way the chain alignment is moved to far towards the center of the engine. ![]() With the sprocket turned around the alignment is spot on. ![]() The sprocket on the XL600R Cam for comparison. ![]() I went with the Hot Cam because it was specifically mentioned in one of the two references found when researching this mod. Not having a 1988+ cam to compare to the original from the XL600 made it a bit safer bet from the stand point of keeping the original timing chain. In this post from HeadTrauma the 1988+ cam looks similar to the profile of the Hot Cam. The same 1988+ sprocket bolts to the camshaft of both the Stock and the Hot Cam. The XL600 camshaft bolts to the Hot Cam. Without actually having a stock cam to compare it's impossible to say with absolute certainty, but at this point I am planning on pulling the engine out of my 83 XL600 and going with a stock 1988+ cam. Quote:
The reversed nature of the the Hot Cam and sprocket offset each other so that the timing marks are visible in their normal position.
I know about when the ride begins, I just don't know when it's going to end. Watcher screwed with this post 03-11-2012 at 01:04 AM Reason: typos |
03-11-2012, 09:23 AM
#5578 | |
Oddometer: 553
PM sent.
03-11-2012, 10:28 PM
#5579 |
Oddometer: 42
i finally got back to work on my 83 XL... it had a leaky rocker cover gasket and it was cutting out at high rpms
did a compression test 175 psi! ![]() pulled the beast of a motor ![]() cam chain looks stretched, bearings were replaced at one point ![]() looks like it was getting lube ![]() can you tell if the tensioners maxed out?
83 XL600R |
03-11-2012, 10:32 PM
#5580 |
Oddometer: 42
old rocker box, one of thems badly worn. i have a 85 rocker box that looks like it will work the only difference i can see is that the kickstart decomp thing works differently, doesnt matter for me though i took off the kickstart decomp.
anyone know what would cause this damageÉ ![]() ![]() 83 and 85
83 XL600R |
