Old 03-12-2012, 07:45 AM   #5581
brucifer
brucifer's Avatar
Oddometer: 2,429
Originally Posted by randylahee View Post
old rocker box, one of thems badly worn. i have a 85 rocker box that looks like it will work the only difference i can see is that the kickstart decomp thing works differently, doesnt matter for me though i took off the kickstart decomp.
anyone know what would cause this damageÉ
83 and 85
You're going to want to replace your camshaft as well. Look at the lobes where the damaged rockers were riding. There's probably some scoring going on.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 03-12-2012, 12:49 PM   #5582
randylahee
Oddometer: 79
^^^ good thing i have a 85 cam thats still in spec, ill have to take a good look at the old one when i pull it
2001 XR650L
2006 CRF450R
randylahee is offline   Reply With Quote
Old 03-13-2012, 04:54 PM   #5583
randylahee
Oddometer: 79
pulled the head and jug today
looks like some corrosion in the cylinder , it still has good cross hatching, should be fine with just a re-hone??
plan on relapping the valves, will i be fine with just new stem seals? or will i need guides too?
2001 XR650L
2006 CRF450R
Old 03-13-2012, 04:59 PM   #5584
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
My rule of thumb is just spend money where it is needed. A hone, stem seals and maybe a valve job if there is a good shop near by. The guides only need to be replaced if there is play between the valve and the guide.
Hate gets you nowhere.
Old 03-13-2012, 05:05 PM   #5585
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,081
Petcock Leak
The XL has begun a slow fuel weep at the petcock valve. Is this something that can be typically remedied by installing some new seals or is it the type of valve that you just replace entirely?
Carter Pewterschmidt is offline   Reply With Quote
Old 03-13-2012, 05:08 PM   #5586
Reposado1800
Juicy J fan!
Oddometer: 5,785
Just replace it.
Old 03-13-2012, 06:29 PM   #5587
jgrady1982
jgrady1982's Avatar
Oddometer: 782
Here is what I would do...
Order a set of OEM HONDA gaskets, dont buy anything other than Honda gaskets.
Take the head apart, keep the hardware together for each cylinder, sandblast the head and the outside of the cylinder, the cylinder looks good, in the manual are the specs for the roundness and the O.D. limit, check those. Obviousley get new rings, and also get a new CAM chain, don't cheap out and re-use it. I would bet for about ~$300 you will be ready to go.
Just my $0.02, let me know if you need any help. O yes...PM me or MCMA111 with any questions, he is the RVFC expert.
jgrady1982 is offline   Reply With Quote
Old 03-13-2012, 06:44 PM   #5588
mcma111
mcma111's Avatar
Oddometer: 12,096
Randy,
Before you do anything take the piston and cylinder to a good machinist and have both measured. If the parts pass have the cylinder lightly honed. With the head upside down fill the combustion chamber with solvent and let it sit. Look in the intake and exhaust ports to look for leakage. When you see the leakage (it WILL leak) have a valve job done on the head. Order a set of rings, valve guide seals and the correct OE top end gaskets. Put it all back together and it will run better than it has in years.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-13-2012, 06:47 PM   #5589
brucifer
brucifer's Avatar
Oddometer: 2,429
That cylinder doesn't look any good to me at all. It looks like someone has been in there with a hone before--doesn't look like factory hone marks to me. That rusty spotting is terrible. I'd be willing to bet a lot of your oil burning issue is because of this.
Old 03-13-2012, 07:18 PM   #5590
sh0rtlife
Oddometer: 796
depends on where its weaping......generaly replace it(im looking for a few "bad" or weaping stock units to see about making replacement seals for)
sh0rtlife is offline   Reply With Quote
Old 03-13-2012, 07:21 PM   #5591
randylahee
Oddometer: 79
im defienetely getting a new cam chain, tensioner spring and o ring, stem seals and rings
might get a new cam chain guide if it looks worn out
my guess was that this motor got a new piston and bore a long time ago and hasnt been used much since, it has 175 psi. i have had it since may 2011 but have only ridden it up and down the street a few times... cant wait to get out on it!
i noticed theres three headgaskets stacked when i pulled the head, anyone know whats up with that?
where do you guys buy OEM parts?, i bought from partspitstop.com but it was pretty expensive last time...
2001 XR650L
2006 CRF450R
Old 03-13-2012, 07:24 PM   #5592
randylahee
Oddometer: 79
also im having trouble getting the jug off, all the bolts are out, i tapped it with a rubber hammer a few times but dont want to break off the cooling fins. any tips/tricks?
2001 XR650L
2006 CRF450R
Old 03-13-2012, 07:31 PM   #5593
mcma111
mcma111's Avatar
Oddometer: 12,096
The latest cheapest parts place:
http://www.westernhonda.com/fiche_se...cles&mfg=Honda
Keep tapping the side of the cylinder. It will pop
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-14-2012, 11:03 AM   #5594
sh0rtlife
Oddometer: 796
stacked gaskets isnt uncommon when someones trying to lowwer the comp ration or slow it down for a beginer
Old 03-14-2012, 11:33 AM   #5595
jgrady1982
jgrady1982's Avatar
Oddometer: 782
Randy,
Whatever you do do NOT take a picture of the gaskets that you are describing so that we can all better inform you of what they are, PLEASE DO NOT TAKE ANY PICTURES AND POST THEM HERE...dont do it Randy.
I bet they are Honda gaskets, enless the PO was a moron and put in non Honda gaskets. Also get a ricky stator, stator enless you already have one. Ground that extra green wire to the air box upper frame mount.
-Jack
Times are GMT -7.   It's 08:41 AM.
