Old 04-10-2012, 11:22 PM   #5671
Doncolberto530
Greasy and confused
Doncolberto530's Avatar
Oddometer: 84
So... where is everyone hooking up that extra ground wire to the frame when they put in these infamous Ricky Stators?
Doncolberto530 is offline   Reply With Quote
Old 04-11-2012, 01:37 PM   #5672
Watcher
Oddometer: 59
Originally Posted by mpenalver View Post
Does anyone know whether the flywheel puller should be M22 x 1.5 or M20 x 1.5?
I've found both advertised as the appropriate puller.
Hi mpenalver,
The puller on my 83 is a 22 mm
I know about when the ride begins, I just don't know when it's going to end.
Watcher is offline   Reply With Quote
Old 04-11-2012, 03:36 PM   #5673
mpenalver
Oddometer: 17
Ricky Stator Ground
I hook the new ground to the gas tank bolt. It's slightly smaller, but it fits with just a little persuasion.
mpenalver is offline   Reply With Quote
Old 04-11-2012, 03:36 PM   #5674
mpenalver
Oddometer: 17
[QUOTE=Watcher;18432553]Hi mpenalver,
Old 04-12-2012, 09:18 PM   #5675
INTMD8
Oddometer: 124
After taking mine out for a few times this year, just have to say I absolutely love this bike. After a few more jetting changes (leaned it out a bit) throttle response is super crisp and 2nd and 3rd gear wheelies are a lot of fun.
FMF exhaust is a bit on the loud side under throttle but comfortable during cruising and has a nice burble on overrun.
I've been looking around for a cruiser/street bike but I think I'm just going to skip that idea entirely and just put more miles on the xl600.
86 xl600r.
INTMD8 is offline   Reply With Quote
Old 04-13-2012, 10:08 PM   #5676
BRPtourer
Oddometer: 158
If it runs near as good as it looks, you got yourself one sweet ride there!
BRPtourer is offline   Reply With Quote
Old 04-14-2012, 07:25 AM   #5677
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,067
I love riding mine as well. We got in an DRZ400SM at my work and I've always liked them until I sat on it. The seat is far worse than the XL. It's like half as thick and half as wide. No way that's happening.
BTW: What FMF pipe is that? Is that for an XR600 or 650L?
Carter Pewterschmidt is offline   Reply With Quote
Old 04-14-2012, 07:40 PM   #5678
randylahee
Oddometer: 73
ring gap
i took my cylinder and piston to a machine shop, asked him to hone it and measure the bore so i could order the right rings... he said its standard bore. so i ordered std rings
went to put the new rings in and checked the end gap and its aroung 1mm the service limit is 0.5mm
i put the old rings in and the end gap is tighter than the new ones, just noticed the old ring has "N25" and the new, wrong one says "N"
would this mean that the piston is 0.25mm over and bore too or is it just a larger ring to make up for a worn cylinder ???
PLEASE HELP
2001 XR650L
2006 CRF450R
randylahee is offline   Reply With Quote
Old 04-14-2012, 11:55 PM   #5679
Billtr96sn
Flange Furtler
Oddometer: 393
Sounds to me like your bore wasnt measured properly!
Billtr96sn is offline   Reply With Quote
Old 04-15-2012, 04:32 PM   #5680
randylahee
Oddometer: 73
i just measured it and its 100mm ... does "N 25" mean 0.25 over?
2001 XR650L
2006 CRF450R
Old 04-16-2012, 09:34 PM   #5681
INTMD8
Oddometer: 124
It was for an XR600 but needed to be cut up and lengthened to fit correctly.
86 xl600r.
Old 04-17-2012, 09:28 PM   #5682
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 782
Proper decomp adjustment...*
*yes, I did a search and came up with nada...
The bike is an '85.
Is the decompression lever properly adjusted when the shaft is just about to contact with the rocker at TDC? (the shaft that is attached to the mechanism at the right side of the head, it has a little cut away on the end which pushes the rocker/valve down) The book seemed fuzzy on this. Any help appreciated.
Thanks.
-Chobro
Chobro is offline   Reply With Quote
Old 04-17-2012, 09:28 PM   #5683
Oddometer: 1,067
Looks nice. I can belive that work is involved. I have an 88-90 supertrapp and header setup I'm trying to fit to mine but needs the muffler mount relocated. I can't count how many time's I've heard people on forums say that any XR600 exhaust will bolt right on to a XL600. Not the case.
Old 04-17-2012, 09:56 PM   #5684
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
I just picked up a NOS Honda 0.5 mm over sized piston and rings for my third XR500R engine (1984). The rings are indeed stamped with N 50.
For what its worth.
Ghost_Mutant is offline   Reply With Quote
Old 04-17-2012, 10:02 PM   #5685
INTMD8
Oddometer: 124
Yes, "fits" is a subjective term and varies greatly between those who want something done right and those who are ok with "good enough"
86 xl600r.
Times are GMT -7.   It's 07:51 AM.
