Old 10-01-2007, 01:36 AM   #46
oldxr
oldxr's Avatar
Oddometer: 1,126
my 87 xr600r at coco's in baja last march-a fun ride
oldxr is offline   Reply With Quote
Old 10-01-2007, 11:31 AM   #47
ere109
Ride On!
ere109's Avatar
Oddometer: 2,946
I just saw a guy on an '86 XL600 riding through the Cherry Creek area in Denver this weekend. Awesome!
'13 BMW R1200GSA 90th Anniversary, '03 Honda XR650R, '83 Honda XL600R Supermoto (Project)
XR600 rebuild http://www.advrider.com/forums/showthread.php?t=188797
XL600 rebuild http://www.advrider.com/forums/showthread.php?t=224984
ere109 is offline   Reply With Quote
Old 10-03-2007, 01:53 AM   #48
rayleon1
rayleon1's Avatar
Oddometer: 11
XL600R advice.
Hi,
I recently bought an XL600 (1984) and was thinking of doing a few upgrades on it, can you recommend any? I have the rear shock from an XR600 to go on, shall i do something with the front suspension?
Cheers
Ray.
rayleon1 is offline   Reply With Quote
Old 10-07-2007, 10:43 AM   #49
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,040
I've got the front end, but need the rear for my '85 XL600.
Originally Posted by rayleon1
Hi,
Cheers
Ray.
The gurus on Thumpertalk recommend using the front end off an XR600 (much more robust and taller forks) and installing emulators. That will match the front end to the XR rear shock. The other possibility is putting modern USD forks on the XL--but that's much more expensive and doesn't offer much improvement (experts say--I don't know).
I bought the forks and triple tree from an '86 XR600 on eBay shipped for $70. I will need to replace the trashed fork seals and then install the emulators. A nice winter project.
Another option is to install a post '91 XR front end to take advantage of the cartridge forks Honda went to. (I looked but couldn't afford this option.)
But I want to know where you sourced the XR shock. I am looking but would benefit from your advice.
Cordless is offline   Reply With Quote
Old 10-08-2007, 02:23 PM   #50
rayleon1
rayleon1's Avatar
Oddometer: 11
Hi, thanks for the advice, i got my XR600 shock from the guy i bought the XL from, he's a UK ebay seller.
Old 10-11-2007, 12:43 PM   #51
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,779
Hi,
Cheers
Ray.
XL600's are very simple to set up to do what you want. Agressive knobbies and low gearing make it work really well off road. A street tread with stock 15:43 gears work very well on the road. Some add a small windshield.
I like the stock squishy suspension though and I have added progressive suspension springs up front. The shock is on rebound setting #1.
Hate gets you nowhere.
Old 10-12-2007, 10:09 AM   #52
MotoChris521
MotoChris521's Avatar
Oddometer: 603
I have a set of forks('85 XL600) with new seals,if any body want's them.I'm in So Cal.
MotoChris521 is online now   Reply With Quote
Old 03-14-2009, 06:15 AM   #53
kobra011
ENDRO RIDER SERBIA
kobra011's Avatar
Oddometer: 56
Here is my 1985 XL600R
1985 Honda XL600R (sold)
1995 Kawasaki GPZ 1100 (sold)
1986 Honda XL600R
GIRLS CHOICE ENDURO BOYS
kobra011 is offline   Reply With Quote
Old 03-14-2009, 06:17 AM   #54
kobra011
ENDRO RIDER SERBIA
kobra011's Avatar
Oddometer: 56
1986 Honda XL600R
Old 03-15-2009, 12:21 AM   #55
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,976
Within the past three months, we have become the owners of two XL600's. We love these bikes. They are both in splendid condition.
Here is our 1983 that belongs to my 18 year old son....
And here is our 1985 that belongs to my 17 year old son....
John
2004 KTM 950 Adventure S
2004 BMW R1150RT
Pointing the Way http://www.gracemotoadv.com
Big_John is offline   Reply With Quote
Old 03-15-2009, 09:10 AM   #56
apex
Oddometer: 323
Originally Posted by Flood
Big singles have the problem that with huge intake diameters, you will either have weak low-down response or not enough top-end power. A single carb might produce good power at full throttle, when gas velocity is high, but may stall at low rpms when you whack the throttle open. To overcome this, Honda designed the RFVC engine with radial valves, a centered spark plug and two carbs, opening one after another. The same concept was used on the early XRs and on Yamaha's XT600 (with a joined floatbowl, IIRC). Gilera's big single (Nordwest/Northcape) had the same system.
In short, it didn't really work. Comparing the RFVC-XL600 with the earlier XL500, the older had far more low-end power and there wasn't a lot of difference at full throttle.
Another solution is the use of pumper carbs, who squirt a small amount of fuel directly into the intake to avoid a lean mixture when the throttle is suddenly pulled open (basically, the inertia of fuel is higher than that of air, so opening the throttle fast will result in the fuel coming a bit "late"). Hope this is somehow understandable.
it didnt really work? wrong.. all the dual carbed bikes when tuned correctly will nearly run circles arround similar displacement single carb bikes. thats been my experience with them and Ive had several. if you try to match a huge carb to a certain displacement to get max power then you have a machine that wont idle and not smooth at low to mid revs, with the dual arrangement you can have cake and eat it too! what would otherwise be way overkill is now tamed and ridability doesnt suffer. Ive got a 250R thats a perfect example, lots of mods including 350 carbs. with stock gearing the 100mph mark is not out of reach, havnt been able to get there on any other 250s Ive had. and the induction roar the dual-carbed thumpers make is awsome too.
apex is offline   Reply With Quote
Old 03-15-2009, 12:40 PM   #57
brucifer
brucifer's Avatar
Oddometer: 2,385
^^ +1! And I might add having owned two '82 XR500s and one '79 XR500 as well as ridden '79-'82 XL500s, the dual-carb XL600 has more power everywhere including low RPM torque. It will out run ANY of those bikes.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is offline   Reply With Quote
Old 03-15-2009, 10:12 PM   #58
TDBiker
TDbiker
TDBiker's Avatar
Oddometer: 21
I am looking for an original frame rack for the xl600r. if you can help me or know a website where they sell them it would help.
Thanks,
TDbiker
TDBiker is offline   Reply With Quote
Old 03-16-2009, 07:50 AM   #59
CNRED
It'll be OK
Oddometer: 573
Over the last year I've aquired three XL600r's. I bought an '86 to rebuild, it has 10K on the speedo, it came with an '85 parts bike. I then found an '87 that had some minor front end damage and picked it up as well, it only has 4K on the clock. My plan is to rebuild the '86, I like the gold anodized wheels and swing arm, then move on to the '87. Amazingly, they all run well.
2011 WR250r
2007 BMW f650GS
1988 Honda NX650 - X2
1982 Honda GL1100 - X2
CNRED is offline   Reply With Quote
Old 03-16-2009, 04:17 PM   #60
lvdukerider
Las Vegas Nevada
Oddometer: 523
I had a 1986 XL600R red white and blue with the gold rims, forks and swingarm with the bright red motor. I loved that bike, way more power than the 1993 XR650L I had years later, Rejetted and with a Supertrapp it would wheelie through the first 3 gears. The suspention wasent the best but for its day it was a hell of a good bike, with a rear disk and better suspention it would still be a great bike today I still miss it.
lvdukerider is offline   Reply With Quote
Times are GMT -7.   It's 09:55 PM.
