Old 10-19-2012, 11:30 PM   #6211
lookfar
from the land of OZ
Oddometer: 627
[QUOTE=ret1614;19858827]Sad to say, every site I've tried takes my order, then refunds my payment and cancels my order... Powersports plus was my first try, then Ron Ayers. After that, I started calling around, and nobody has them anymore. QUOTE]
These guys have them, They are in New Zealand, but I got one from them recently for my 1985 XL600.
http://www.smebike.com/carburetor,%2...rdre-xr500rdre
HTH
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 10-20-2012, 01:52 AM   #6212
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 380
Originally Posted by ret1614 View Post
Sad to say, every site I've tried takes my order, then refunds my payment and cancels my order... Powersports plus was my first try, then Ron Ayers. After that, I started calling around, and nobody has them anymore. The people that run the websites that have them listed as available tell me that I could order one, but when I ask them to confirm availability, they come back with something to the effect of, huh, our supplier says they don't have them anymore. So... By the sound of things, if I remove the spring and the diaphragm, block the vacuum port, and seal the cavity with an o-ring, the only problem I'll encounter is heavy backfiring?
That will not work . The Spring and the Pin in the middle of the diaphragm keep the Air cut valve at normal riding condition open .
If you remove the spring and/ or the diaphragm the Air cut valve will close , that let not enough Air to the Slowjet and the bike run to rich . You get massive starting problems if the Engine is warm .
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 10-20-2012, 01:12 PM   #6213
ret1614
Oddometer: 23
Crap.
Anyone know if the diaphragm diameter is different between the XR and XL series?
Also, there isn't any contact information for SMEBIKE... I'd like to check availability before I make an order...
ret1614 is offline   Reply With Quote
Old 10-20-2012, 02:30 PM   #6214
ret1614
Oddometer: 23
Thing is, all those are for the '87 version of the XL600R... If the diaphragm is the right diameter, I'm 100% in business, because Honda still makes the parts for those carbs. 16048-KG0-891 seems to be still in production, and if the only difference is a spring pressure calibration difference, I can work with that. The parts fiche looks identical from '85-'87, but I can't know just by looking.
Maybe I'll order one, take the measurements, use it if it's right, send it back if it's wrong, and tell you guys if it works.
Unless somebody knows already...?
I mean, even bikebandit has the air cut valves for '86 and later...
http://www.bikebandit.com/houseofmot...1999#sch543909
Seems like the parts fiches look identical for the entire bike, but I know minor differences make for go/no-go.
Old 10-20-2012, 02:33 PM   #6215
lookfar
from the land of OZ
Oddometer: 627
Crap.
The Guy's name is Alec
Email is smebike@ihug.co.nz
HTH
Stu in FNQ
1985 XL250R
Old 10-20-2012, 05:57 PM   #6216
ret1614
Oddometer: 23
Alright, so I just ordered a diaphragm for an '86...
I'll see if it fits and report back.
Old 10-20-2012, 06:45 PM   #6217
tractor4play
Oddometer: 108
carb
they are all the same accross the range.
n.r.p uk stock them at a cost of 12 pounds each.
if you have any problems pm me and i will get one to you.
tractor4play is offline   Reply With Quote
Old 10-21-2012, 11:39 AM   #6218
ret1614
Oddometer: 23
That's what I wanted to know. Thanks. I kinda thought the part interchange was fairly certain, but now I know for sure.The difference in part numbers probably has a lot to do with the operating characteristics of the valve, as in how much vacuum it takes to open it. Anyway, I'll report back about it.
Old 10-22-2012, 04:03 PM   #6219
terrordaktyl rexxx
Oddometer: 18
do xr600r seats interchange with the xl600 seats?
maybe dimensionally different but like is the pan the same? bolt on the same?
terrordaktyl rexxx is offline   Reply With Quote
Old 10-22-2012, 04:16 PM   #6220
Schrauberklaus
***ifyer
Oddometer: 380
No , they are differnt . Have both , no change to interchange the seats .
Klaus
Old 10-23-2012, 12:42 PM   #6221
GSBruce
Oddometer: 132
Timing Chain Tensioner O-ring job
It appears that my timing chain tensioner shaft o-ring is weeping a tiny bit, tiny bit being more than I can tolerate. So this winter (about 2-3 weeks long in Houston) I will pull the engine and fix that.
Like my clutch lifter seal, this o-ring sat high and dry while my bike rested from 1989 until I put it back online in August 2012. My bike had 8000 miles on it when I parked it; I've ridden another 1100 miles since August, now at 9100 miles.
Other than the o-ring and a new rocker box gasket, what else should I do while I have the engine out? Don't mind spending a few bucks to avoid pulling the engine again anytime soon.
I will do something with the exhaust header while it's apart - $200 for a jet coat job seems excessive compared to flat black header paint from Autozone...
Suggestions and advice always most welcome ....
2000 BMW R1150GS / 1983 Honda XL600R
GSBruce screwed with this post 10-23-2012 at 01:56 PM
GSBruce is offline   Reply With Quote
Old 10-23-2012, 01:38 PM   #6222
Billtr96sn
Flange Furtler
Oddometer: 393
I would change all rubber seals including valve stem etc as they more than likey have dried out and gone hard.
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 10-23-2012, 01:39 PM   #6223
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Suggestions and
Yes:
All of the shaft seals. Anywhere there is a shaft coming out of the engine. All of them. You mentioned your clutch lifter- that's one, the driveshaft, shifter lever shaft, and the decompression one in the rocker box. They can be pried out with a variety of tools. There is usually hollow space behind them, and they're made of brass and rubber, just try not to scratch the shafts. The stator cover will need to be removed for the clutch one, and the rocker box for the decompressor shaft. I've had leaks happen in all those places. Once they are replaced, there will be no more oil leaks. I say that since you are getting the rocker box- good idea. I like to use copper coat in the spray can- nice and tacky, a sure seal for that particular gasket in my several assembly attempts trying a range of different products.
I think you must hate oil leaks as much as I do from the sound of it.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 10-23-2012, 01:42 PM   #6224
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Valve stems seals!
That's a good idea too! I forgot about that!
Old 10-23-2012, 02:48 PM   #6225
JimRidesThis
Local celebrity
JimRidesThis's Avatar
Oddometer: 293
Originally Posted by Oil-Burner View Post
Just thought I would share my new project a 1986 XL600r. Just needs a good cleaning and a few missing parts replaced.
That looks like a really nice 'light' project I really do like that colour scheme... and I've just painted my frame, tank and side panel (still need to find a right hand one) red .
1985 XL600R "Tamworth"
1992 TDM850 "Ivy" A work in progress
JimRidesThis is offline   Reply With Quote
Times are GMT -7.   It's 04:10 AM.
