Old 12-09-2012, 05:31 AM   #6466
Stretchah
Oddometer: 123
Originally Posted by crobox View Post
Here you can see the frame-brace / seat mount thing welded into place. That particular frame component in stock form just seemed really under-engineered to me, and probably not able to prevent much flex in those rear frame spurs. Lots of cracking near the welds sorta supported that hypothesis. That's the only reason I replaced it.
Also visible here is the sub-frame reinforcing I did last night. I was able to tie the triangulation elements into various pre-existing frame elements, such as those threaded-nut-ears that drop down from the main frame about 4 inches forward of the rear-most holes. I am not even sure what those nuts are for, other than a rear rack (which I may well use them for at a later date.) I think this reinforcing will really increase the amount of weight I can hang off those rear-most holes.
You can also see the flanges that I added lower down on the rear, angled tube of the sub-frame. These each have three holes with nuts welded behind them, so three places to attach stuff. Probably used in the future for frame-mount rear pegs and the forward mounting point for pannier racks.
Does anyone on here have an XL600 with a center-stand? If so, any chance of snapping a picture of the mounting points and spring configuration?
And lastly, that blue and orange color scheme looked really perfect in my mind. But as I look at my photoshop mockup, I am not quite so sure of it anymore. Gotta keep thinking about it.
Looking good :)
I think the centre stand normally mounts where the pegs do - I'm sure someone will correct If I'm wrong. I did win one on ebay, but, then the breakers that were selling it couldn't locate it :( Still searching for another....
Still, here's a photo of the stand in case that's any help :)
Stretchah is offline   Reply With Quote
Old 12-09-2012, 06:57 AM   #6467
Billtr96sn
Flange Furtler
Oddometer: 393
My centre stand was stolen!!. It fits between both front footrests and a bracket in the middle. If you breaker finds another I hope it aint mine!
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 12-09-2012, 10:28 AM   #6468
Sierra Thumper
Oddometer: 641
Originally Posted by Moparmanpete View Post
Yea I dig that bare Aluminum and black cover look, The black and white color scheme looks good but would be hell for me to keep clean.
Actually the white sidecovers and fenders are great at hiding scratch damage, and clean up extremely well with some soft scrub, waay better then other colors. The only prob is white plastic tanks suck, because they turn birdshit yellow over time from the gas fumes leaching through. I had a blue and white 88 banshee that I owned for years, it looked like new when I sold it because the white was so easy to clean and so good at hiding scratches.
As long as he has a white metal tank, NOT plastic, he's golden
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 12-09-2012, 10:33 AM   #6469
crobox
crobox's Avatar
Oddometer: 324
Originally Posted by Billtr96sn View Post
Gold?? Superb, my 84/85 XL6 has gold rims,gold forks,gold swingarm all as standard. Also the rims are tubeless which is very useful.
OK, OK, all you gold guys are making me think twice! But what color scheme goes with Gold??? Red white and blue I guess, if you're a 1980's Honda designer guy! Those tubeless style rims you're talking about are very cool, but as far as I can tell they are not available around these parts.
Thanks, that does help. I think I'm gonna do mine a little differently; probably hang it off the BACK of the main engine box part of the frame, as opposed to the BOTTOM, as it looks like that one does. There seems to be plenty of room back there, and ground clearance would remain unchanged.
But it's great to see the stand itself and the arrangement of the springs.
OK, off to the shop!
Christian
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 12-09-2012, 10:39 AM   #6470
crobox
crobox's Avatar
Oddometer: 324
CONVERSATION CROSSOVER ALERT!!
That's good to hear, because my white plastics are pretty dirty. I was lamenting the idea that I might have to get new ones.. but now I'll try cleaning them up first!
Old 12-09-2012, 01:14 PM   #6471
Stretchah
Oddometer: 123
That's bad news..I hope not too, he doesn't have another one :( so, I'm going to keep trawling ebay until one turns up either that or get someone to make one up. I'm guessing it shouldn't cost too much. If I do go that route at some point I'll let you know, but, the centre stand is a way down my list at the moment ;)
Glad the photo was of some use Christian looking forward to seeing how the stand turns out :) Plus the rest of the bike :)
Old 12-09-2012, 02:45 PM   #6472
crobox
crobox's Avatar
Oddometer: 324
Just got back from the shop... mostly because it's suddenly too darn cold to work in there!
But I did get my center stand mounts done. For some reason none of the pictures turned out very well.... This one is the best...
We're looking at the back of the bottom corner of the engine compartment. Swingarm linkage mount area is sort of in the center of the image, kick-stand mount flange is at top left.
Just to the right of the kickstand pivot bolt you can see a piece of 5/16" round stock with a necked down collar near the end; this will be the spring mount for the stand.
Now I know I'm getting ahead of myself here... and this might be a little crazy... but I've been brainstorming some ideas about an electric start for this thing that would be totally external to the engine, and here is what I am thinking:
Mount a starter motor for a motorcycle (I happen to have one hanging around) below the carbs, like this:
The crankcase breather would have to be modified somehow to make room, but otherwise I think it would fit. Then mount a one-way over-running clutch (like McMaster-Carr item number 4752N4, for instance) onto the output shaft of the electric motor, and a small sprocket on the other side of the clutch. Mount a larger sprocket (as big as you could get away with for gear-down, and these sprockets could be much smaller pitch... like 25 or 35) next to the main output drive sprocket of the engine, and connect the two with a chain.
If you were to engage the starter motor, it would spin the drive sprocket of the engine, thereby turning over the engine, as long as you were in gear. I'm guessing 5th gear would be the way to go. The implication, however, is that your rear tire would be spinning too... hence the center stand. This is another reason I went ahead and positioned my center-stand mounts pretty far back, to get the rear wheel off the ground. Now... once the engine is started, you pull in the clutch, shift down to first, roll off the center stand, and ride away. While riding, the smaller chain connecting the engine output drive sprocket to the starter motor would be spinning like crazy, but the overrunning clutch would prevent the starter motor from spinning.
Yes, it's a crazy idea. And I'm not sure yet if I will try it. I would need to probably go with individual air filters and make a bigger battery box for a bigger battery. More weight. There are several other challenges, too, like mating the little clutch to the starter motor and mating a second sprocket to the engine output sprocket (hard to do because those sprockets are hardened; no welding, no machining)
We'll see what happens. More food for thought, for now.
Christian
Old 12-09-2012, 06:34 PM   #6473
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,980
I think black seat, white bike, and gold anodizing. With that combo, the natural color Clarke tank would look good, and be clear enough to check fuel level. A white painted metal tank would look even better, but with less capacity obviously.
High Country Herb is offline   Reply With Quote
Old 12-10-2012, 02:17 PM   #6474
Tomodan
Oddometer: 2
Why has my XL600LMF got a red frame?!
Hi all, I’ve recently bought an old (86) XL600 LMF and am loving it! What a cracking bit of kit, relaxed, bullet proof (I hope!) and cheap!
I’m sure I will have loads of questions coming up but for now there is one thing that I am really trying to work out……..
Why has my LM got a red frame?
It’s a UK bike & has the twin headlights, big tank & red engine (which has been re-painted but was also originally red judging by the paint underneath)
I have seen loads of pictures of bikes just like mine but never with a red frame!
Having stripped the tank & body work off to sort a leaky carb I am 90% convinced the paint is original as the bits under the tank, round the headstock & under the seat all look original?
Also the frame plate is in-tact & I can’t see any trace of overspray or re-fitting and when I was changing the oil a flake of paint cape off the down tube fight down to the bare metal & there is only red paint in the flake (no white underneath)
I am guessing it is one of 3 things.
1. I am a Muppet with the observational skills of a mole & it has had its white frame re-sprayed (with a bear metal strip hence no white under the red)
2. It is a super mega rare “red framed special” which collectors will sell their first born child to buy & my £600 hack has now become my retirement plan
3. Red frames were perfectly normal & its coincidence that Google images does not return any on the first few pages.
Any help working this out would be gratefully received!
I’ll try to upload a pic once I work out how!
Tomodan is offline   Reply With Quote
Old 12-10-2012, 03:05 PM   #6475
mcma111
mcma111's Avatar
Oddometer: 12,277
How much oil does each fork tube take?
15.4oz or 455cc of ATF. Oil level is 150mm or 5.9"
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-10-2012, 03:40 PM   #6476
mcma111
mcma111's Avatar
Oddometer: 12,277
Each
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-10-2012, 06:23 PM   #6477
crobox
crobox's Avatar
Oddometer: 324
I'm setting the "outside-the-engine-electric-start" idea aside for now. With the exhaust mocked up into place it becomes clear the electric starter motor I have will not fit. If I could locate a smaller electric motor I think the idea could be made to work, but I'm not gonna focus on it for now.
Last night I was perusing older sections of this thread and I came across the part about the reed valve in the head that goes between the intake ports, and the way that valve was superseded by a different intake manifold with a passage milled out between the intakes.
It turns out my engine has neither....
I'd rather not spend the $50.00 or more that the later stye intake manifolds are going for on eBay. And, I've thought about how to modify the intake to create a passage there, but it's not a particularly easy thing to do.
Any thoughts? How critical is this "cross-flow" issue? Anyone have a later-style manifold they don't need? (I guess I would need the spacer too) Any other insights into the topic?
Thanks,
Christian
Old 12-10-2012, 06:52 PM   #6478
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Thanks,
Christian
Run what you have, the carbs are progressive. I wouldn't worry about it.
Was there any issues before the tear down?
xladv.com
MentalGuru is offline   Reply With Quote
Old 12-10-2012, 07:20 PM   #6479
crobox
crobox's Avatar
Oddometer: 324
Well, the teardown was initiated because of a no-spark issue. It mushroomed from there into a much more ambitious project.
But the bike did run OK, several years ago. The truth, however, is that I have only ridden this bike about 4 hours TOTAL, and 95% of that was off-road. And it was 4 years ago. So, if it had issues related to this lack of cross-flow between intakes, I'm not sure I would have recognized them / don't really remember.
Old 12-10-2012, 08:50 PM   #6480
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Thanks,
Christian
I think neither is the wrong answer for any year XL6 Someone must have replaced the original cross port carb intake boot with an 83 version? Easy mistake to make esp. when ebay sellers list items as fitting multiple years.
Looking at the 83 Honda Manual copy I have under the technical information chapter, ch19, it says:
...........This cross-port allows some fuel mixture to cross from the primary port to the secondary port to cool and lubricate the secondary intake port's valve.
If you idle the bike for any length of time, you might want that cross port. It might be a bigger requirement in the Desert as opposed to Canada.
On the other hand, just keep it at WOT and the right intake valve will be plenty cooled and lubricated.
Edit/addition: you can look for intake boots for 84 up XL6s, 84 XR5s, and 85-87 XR6s. The 84s have the larger insulation plate port holes. Later years are stopped down a tad. Just stay away from the 83s, you already have that one.
Ghost_Mutant is offline   Reply With Quote
Times are GMT -7.   It's 02:49 AM.
