Old 02-13-2013, 12:47 PM   #6931
davek181
davek181's Avatar
Oddometer: 961
I have had the best luck with liberal usage of high temp moly paste on the back of the pads and all other moving parts. don't forget to lube the caliper pins
davek181 is offline   Reply With Quote
Old 02-16-2013, 04:14 PM   #6932
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,067
Hey guys I got another question. I just ordered a gasket kit for and new rubber seals for my XL. I'm wanting to pull the engine and stop all those damned leaks on the rocker cover and such.
How much time should I set aside to do this? leaking oil is the ONLY problem this bike has
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 02-16-2013, 07:57 PM   #6933
crobox
crobox's Avatar
Oddometer: 324
Where is it leaking from specifically?
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 02-17-2013, 02:17 AM   #6934
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,067
e
Should be easy fixes, Its just not gonna be fun pulling the engine. I just want an idea of how long it might take. I use my XL for trail riding and commuting and I want to be prepared when I do this so I have minimal downtime. I ordered a kit and I'm going to use as much of it as I can
RFVC600R screwed with this post 02-17-2013 at 02:22 AM
Old 02-17-2013, 04:34 AM   #6935
mcma111
mcma111's Avatar
Oddometer: 12,869
At least six hours.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-17-2013, 09:10 AM   #6936
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Originally Posted by mcma111 View Post
At least six hours.
Or six days when you add in the "25 year old bike might have other broken/worn out things you find inside after you open it up" factor.
Carter Pewterschmidt is offline   Reply With Quote
Old 02-17-2013, 09:17 AM   #6937
mcma111
mcma111's Avatar
Oddometer: 12,869
No, That was six hours to get the engine out of the frame.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-17-2013, 09:47 AM   #6938
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,067
At least six hours.
just to pull the engine? I could see that.
Well the engine is fresh, only about 5k miles on it since last rebuild. it just leaks a lil bit of oil and its quite annoying. The compression test was excellent, the cam chain didn't look stretched when I was chaning the clutch cover a while back. So hopefully I don't run into another problem. I was talking to a mechanic at my local bike shop a while back and he claimed to have a XL600 back in the late 80s in which the compression ring was broken in six places and it ran like a champ before he tore into it
Damn, I'm gonna have my work cut out for me. My brother in law is a certified small engine technician and I will have his assistance in taking these leaks on. I think I might just wait til I get my taxes and build up this engine since I gotta pull it anyway.
RFVC600R screwed with this post 02-17-2013 at 10:06 AM
Old 02-17-2013, 10:05 AM   #6939
mcma111
mcma111's Avatar
Oddometer: 12,869
No it shouldn't take six hours to pull the engine. I was just kidding. Since I don't know your wrenching capabilities I don't know how long it will take you. I can get the engine out in about an hour.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-17-2013, 10:10 AM   #6940
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,067
Lol okay good. I'm an okay/average home mechanic. You're an RFVC expert and I'm not. I had a good read on your XR650L engine rebuild thread. Takes you an hour, So I'm gonna put down 3 for me After that it's just changing gaskets and thats not a problem. I've rebuilt the carbs, changed the clutch cover and rebuilt the forks with no real problems. Not scared to take this on, I'm just scared of not riding for a little bit lmao
Any special tools needed for this? I think I might just need a torque wrench, right?
RFVC600R screwed with this post 02-17-2013 at 10:18 AM
Old 02-17-2013, 10:54 AM   #6941
mcma111
mcma111's Avatar
Oddometer: 12,869
The only thing I use a torque wrench for is the cylinder and head bolts. I have a calibrated wrist...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-17-2013, 07:41 PM   #6942
crobox
crobox's Avatar
Oddometer: 324
Well, Steve pretty much covered everything.
Having just done much of this stuff myself, I would say that if you are focused, and have all your tools and parts lined up, you could get the engine out, gaskets and seals replaced, and engine back in, in a day to a day-and-a-half of work.
Of course that's just an estimate, actual results may vary.
Good luck! It's actually not too hard.
-Christian
Old 02-18-2013, 04:10 AM   #6943
Sierra Thumper
Oddometer: 641
I wouldn't pull the motor unless its leaking oil like the Exxon Valdez. Not worth all the work over a few drops of oil imo unless you also build the motor up or do something else worthwhile at the same time. But then again I'd rather ride than wrench
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-18-2013, 07:45 AM   #6944
Oddometer: 1,105
Lol. Their is a certain dance you have to do with the engine to get it out. It has to be tilted a certain way, lifted out a certain direction, and one of the valve adjustment caps have to come off. The whole procedure is almost as obnoxious and just as particular as getting the airbox out.
Old 02-18-2013, 07:52 AM   #6945
Oddometer: 1,105
My problem is with oil leaks is the smell. My head cover gasket leaked oil into the spark plug well and when you'd sit at intersections all you could smell was burning oil. To me it's a terrible smell because of certain memories it brings back. I used to work on cars as a kid and every whiff of that I get reminds me of all the leaky old shitboxes I had to deal with.
Times are GMT -7.   It's 03:52 AM.
