Old 02-20-2013, 05:30 PM   #6961
amf4399
amf4399's Avatar
Oddometer: 63
Originally Posted by mcma111 View Post
Stock bore for the XL600 is 100mm.
101 is an overbore kit.
Honda overbore kits are 100.25 and 100.50
Great thanks.
amf4399 is offline   Reply With Quote
Old 02-22-2013, 05:31 AM   #6962
davek181
davek181's Avatar
Oddometer: 940
If you are thinking big bore, the largest I know of without doing major mods and using still using original sleeve rebored is the Wiseco 102.4. I ran one in my XL for many miles and years with no problems. I ran it with stock cam and springs etc. It made a noticeable difference in power, with no changes in mannerisms. As they say, there is no substitute for cubic inches.
davek181 is offline   Reply With Quote
Old 02-22-2013, 12:24 PM   #6963
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 134
Hi. Im in the process of a rebuild on my '86 and have purchased a Wiseco 101 11:1 kit. With the higher compression i was wondering about the need to look at jetting to get the most out of it.
I live at sea level, temperature range about 5 - 30 deg C. The jetting I have is 108, 65 main carb and 105 in the other.
Any advise would be appreciated so I can do it while the beast is in bits!
M2H
m2h is offline   Reply With Quote
Old 02-22-2013, 01:03 PM   #6964
joexr
Oddometer: 3,773
M2H
If you dont change anything airflow-wise [ filter , airbox or exhaust ] your bike will run richer due to the increased compression.
Old 02-22-2013, 01:06 PM   #6965
MartiniUp
Oddometer: 1,929
Originally Posted by amf4399 View Post
I hate to ask this question because for those that know what they are doing will know this answer. I omit that I don't know what I am doing but I am learning as I go.
Is 101.00mm the stock rings for the 83 600r?
Hey, we all started out ignorant. When I was born I knew nothing. Now at 67, I know even less!
MartiniUp is offline   Reply With Quote
Old 02-22-2013, 03:56 PM   #6966
mcma111
mcma111's Avatar
Oddometer: 12,571
And it's all down hill from here on.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-22-2013, 08:32 PM   #6967
davek181
davek181's Avatar
Oddometer: 940
M2H
I live near sea level too, but have much larger jets in my 87 XL. 125 primary carb, 118 secondary.
Bigger bore usually doesn't need drastically different jets, but yours sounds too lean to start with from my experiences.
Old 02-23-2013, 04:46 AM   #6968
lookfar
from the land of OZ
Oddometer: 653
Hmm, I'm a bit more conservative...I started off with nothing, after careful budgeting, I found that I still have most of it left
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 02-23-2013, 12:39 PM   #6969
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
And higher compression will make a lean mixture more likely to ping.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 02-23-2013, 04:44 PM   #6970
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 134
Thanks all, for the replies I guess I will need to research the thread for some more on jetting . It sounds a bit of a mine field !!
M2H
Old 02-23-2013, 04:50 PM   #6971
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
I wanna rejet mine but I don't know anything about it. I'm pretty sure I can get more power out of this thing if i changed the jets
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 02-24-2013, 04:21 AM   #6972
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
So basically I go WOT and shut the engine off and pull the plug for a reading?
Mine kinda looks like this when I check/change it once in a while
Old 02-24-2013, 04:50 AM   #6973
Edouard_Bracame
Oddometer: 86
Seal on the tank
Anyone knows where I could find the white seal wich is installed on the edge of the fuel tank on a XL600 LM?
Many thanks,
Edouard_Bracame is offline   Reply With Quote
Old 02-24-2013, 05:10 AM   #6974
mcma111
mcma111's Avatar
Oddometer: 12,571
Many thanks,
How about automotive door edge protector?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-24-2013, 06:13 AM   #6975
joexr
Oddometer: 3,773
Many thanks,
Car door edge trim at an autoparts store. They usually have it in black , chrome and clear.
Times are GMT -7.   It's 07:08 AM.
