Old 03-26-2013, 09:25 AM   #7201
doc.heckle
Oddometer: 38
Check the earths before anything else
doc.heckle is offline   Reply With Quote
Old 03-26-2013, 10:59 AM   #7202
terrordaktyl rexxx
Oddometer: 18
yall know off hand where the headlight grounds?
also, shameless plug here, trying to scoop up a cheap aftermarket exhaust, just the muffler bit, stock one is a but roached. Thanks yall.
terrordaktyl rexxx screwed with this post 03-26-2013 at 11:08 AM
terrordaktyl rexxx is offline   Reply With Quote
Old 03-26-2013, 12:11 PM   #7203
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,066
there is only a couple grounds for the whole system. I know there is one by the ignition coil and your turn signals. there is a dummy by the turn signal relay.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 03-26-2013, 12:31 PM   #7204
INTMD8
Oddometer: 125
My Xl keeps blowing the headlights, seems to happen when the revs at up. Any known fixes? I'm thinking grounds, haven't Had a chance to track it all down .
I had another bike do this when I ran it without a battery. Not sure if the XL would do the same.
86 xl600r.
INTMD8 is offline   Reply With Quote
Old 03-26-2013, 12:36 PM   #7205
davek181
davek181's Avatar
Oddometer: 961
My headlight quit on dark night on the trail. I grounded the headlight to the frame temporarily to repair, and it is still that way today. I guess next time it quits I will chase the original ground path.
davek181 is offline   Reply With Quote
Old 03-26-2013, 07:56 PM   #7206
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Need a stock upper triple clamp to send to a guy for measurements, anyone have one for sale? Doesn't need to be that pretty just intact.
TIA!
Carter Pewterschmidt is offline   Reply With Quote
Old 03-28-2013, 05:49 AM   #7207
davek181
davek181's Avatar
Oddometer: 961
I have one but not for sale. What measurements do you need? I can make some and send pics if that will help. Or I can send the whole thing if you want to send it back when done.
Old 03-28-2013, 10:06 AM   #7208
Oddometer: 1,105
Thanks, but I found one.
Old 03-28-2013, 12:32 PM   #7209
JStory
JStory's Avatar
Oddometer: 2,899
Originally Posted by cam14 View Post
Just shareing, so happy, after being in a non-running state for over a year, I finally got my 85 XL600R back up and running again. I've upgraded to a big fin head with a custom mid cam from CycleWizard, and only had to take the carbs apart three times to get it close enough to run. Need to do a nut and bolt check and change the oil then go for a long missed long ride.
While I had the engine out, really should have repainted the frame but too late now, it's time to ride.
Could you please post some pics of your big-fin head? I'm curious
how the de-comp chamber cover was dealt with during the big
fin installation.
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is online now   Reply With Quote
Old 03-28-2013, 03:17 PM   #7210
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,066
Finally fixed those damned oi leaks. piece of mind now I dont gotta put oil in it every other day. the leaks were getting worse too. The whole process wasn't nearly as hard as I anticipated.
Those gaskets I got on ebay fit perfectly. OEM was just too damn much.
Old 03-29-2013, 09:47 AM   #7211
JimRidesThis
Local celebrity
JimRidesThis's Avatar
Oddometer: 317
Originally Posted by davek181 View Post
What spring weights do they have available?
If you're talking about Hagon' they'll make 'em to your spec and give advice on rates and so forth. Top guys! I put Hagon springs and shock on my FJ1200, 10% stiffer at both ends. It transformed the bike :-)
1985 XL600R "Tamworth"
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 03-29-2013 at 09:53 AM
JimRidesThis is offline   Reply With Quote
Old 03-29-2013, 09:56 AM   #7212
JimRidesThis
Local celebrity
Oddometer: 317
Nice to know that you don't have to go with OEM gaskets. I've taken the chance with aftermarket ones, they seem to be excellent quality items.
1992 TDM850 "Ivy"
Old 03-29-2013, 10:06 AM   #7213
Oddometer: 1,105
I thought you English all used the term "Pattern"
Old 03-29-2013, 03:09 PM   #7214
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,802
Never use a paper or cardboard rocker cover gasket. That one is a metal shim which gets the right clamping force on the cam, bearings etc. Some gasket makers screw this one up.
Hate gets you nowhere.
Old 03-29-2013, 04:15 PM   #7215
cam14
Oddometer: 197
fin installation.
PM me your e-mail and I send them, don't mind posting pics here but do not have a hosting site and cannot post pic directly to this site.
cam14 is online now   Reply With Quote
Times are GMT -7.   It's 01:28 PM.
