Old 04-23-2013, 05:33 PM   #7381
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,776
Originally Posted by mcma111 View Post
Good fucking luck getting the old collars out of the swing arm.
Thanks for the positive reinforcement. Sounds like a chisel might be invited to the party.
Hate gets you nowhere.
Old 04-24-2013, 07:17 AM   #7382
davek181
Oddometer: 840
A trick I use to remove bushings from swingarms, or lower control arms, or similar things is to thread a hacksaw blade through the bushing and very carefully slice the bushing lengthwise. Cut very carefully and the arm will not be touched. Once you get a saw blade width slot cut in the bushing it will collapse inward a little and be easier to drive out.
davek181 is offline   Reply With Quote
Old 04-24-2013, 07:35 AM   #7383
mcma111
mcma111's Avatar
Oddometer: 11,881
Your quite welcome.
This is what's needed:
Swing Arm/Rising Rate Linkage Bearing Install Tool
  • Designed for installation of the swingarm bearings on late-model Japanese off-road motorcycles
  • 200 mm long threaded installation bolt
  • Puller draws bearing into the swingarm
  • Includes three drivers for use with common bearing sizes
  • Kits includes driver sizes I.D. 20mm / O.D 26mm, I.D. 21mm / O.D. 26mm & I.D. 22mm / O.D.27mm
I have one in the tool box.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-24-2013, 09:05 PM   #7384
Reposado1800
Juicy J fan!
Oddometer: 5,776
Your quite welcome.
I ordered one.
Old 04-25-2013, 09:49 AM   #7385
Reposado1800
Juicy J fan!
Oddometer: 5,776
fried rocker arms
I am going to assume the gray/white coating on the rocker arm pads is the hard plating. When that wears through and it hits shiny metal it is going to wear fast. Does it seem the exhaust rockers have a shorter life than intakes? A and B rockers from the intake side can be swapped over to exhaust side?
Old 04-25-2013, 03:56 PM   #7386
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
What would cause my bike to sound like a barrel full of nuts and bolts rolling down a hill?!?!
I was on a day trip desert loop in the natl park with my buddy on his v-star. mile 44 my bike starts making a racheting noise, i stop. It increased with revs and got really loud (i thought it was about to blow!) so I shut it off, smoke a bowl and a cigarette, and I go start the bike back up and noise is gone! WTF!! I rode the remaining 40 miles home with no problems and now I'm worried?? it starts fine, no loss of power or anything, I can't seem to make the noise reoccur either.... I couldn't figure out where it was coming from though it sound like the stator side
Atleast I didn't have to ride home on the back of a cruiser, the Honda loves me enough to make it home.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 04-25-2013, 07:28 PM   #7387
Carter Pewterschmidt's Avatar
Oddometer: 1,064
Well just how big of a bowl was it? Because that may make a difference.
Carter Pewterschmidt is offline   Reply With Quote
Old 04-25-2013, 07:34 PM   #7388
Reposado1800
Juicy J fan!
Oddometer: 5,776
dropping a valve seat.
Old 04-25-2013, 07:36 PM   #7389
Reposado1800
Juicy J fan!
Oddometer: 5,776
That bearing race is extremely hard. Hacksaw is a no go. I dropped the swingarm out and am using a sawzall. Even that is barely getting a bite.
Old 04-25-2013, 08:28 PM   #7390
davek181
Oddometer: 840
Hate that when that happens.
When in doubt add lots of heat.
Old 04-26-2013, 03:25 AM   #7391
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
Well put another 25 miles on it going to and from work and such. seems to be fine now but I don't want to write it off as a fluke, probably be ordering the stuff for a top end soon and see what I find.
Old 04-26-2013, 03:48 AM   #7392
Homerb
Oddometer: 455
Well I couldnt wait any longer. After rebuilding my XL600RMG from the ground up I took it around the block half a dozen times today to get it hot and check for oil leaks. Front brake yet to be fitted and back brake shoes still bedding in, but, holy shit, how hard does this thing go???!!!
Running 0.5mm oversize 11:1 Wiseco piston, Kibblewhite valves, guides and springs, and a Staintune muffler from a VTR1000. Goes much, much better than before the rebuild. Clutchless wheelies in first and second gear. I was wondering if any other XL600 owners here are running the 11:1 Wiseco piston and if you've found it made a huge difference to the power the engine produces.
Homerb is offline   Reply With Quote
Old 04-26-2013, 04:15 AM   #7393
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
Yeah they can move. When I put the 13t front sprocket on and go offoad, I often find myself getting into a mess before I know it, and I can climb the gnarliest hills around here without even thinking about it. Accidental wheelies if you're not used it :) I don't know what ratio mine is but the receipt from last rebuild just says "WISECO HI-COMP" as one of the parts. Me and my friend were racing around after work one night. he has some v-star 950 thing, and he said his speed was reading 105+ and I "flew by him" Don't know how accurate his speedo is and I wasn't looking at mine either, but I have no business to go nearly that fast on anything again that was with stock gearing
RFVC600R screwed with this post 04-26-2013 at 04:21 AM
Old 04-26-2013, 06:59 AM   #7394
davek181
Oddometer: 840
Compression is the first wakeup call for sure on these big singles. I have run Wiseco 11:1, 102.4mm which worked well, though it actually calculated out to 10:1 when measured on install which is fine because that is about the upper limit for fuel availability.
After a crankshaft breakage issue I opted for an XR crank which necessitated a new piston. I went with a JE 11:1, 102mm which also calculated out to 10:1. It also works well and runs great, but it is noisier than the wiseco till it warms up.
Old 04-26-2013, 07:31 AM   #7395
brucifer
brucifer's Avatar
Oddometer: 2,377
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is offline   Reply With Quote
Times are GMT -7.   It's 11:37 PM.
