Old 05-08-2013, 07:38 AM   #7531
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
I got it as close as it was going go. The two slash marks are still visible from the flat of the head. One is just a hair higher than the other at T1. At F1 they are flat. The difference in T1 from F1 is a gnats pube hair.
Hate gets you nowhere.
Old 05-08-2013, 07:42 AM   #7532
mcma111
mcma111's Avatar
Oddometer: 12,928
By having the cam gear not being in alignment shows that the chain has stretched. At -l l anway.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 07:48 AM   #7533
Reposado1800
Juicy J fan!
Oddometer: 5,803
It has 14,000 on it. I bought a CDI from regulatorrectifier.com and a pulse generator from service honda.
It has a variable idle which it was doing before teardown. Carbs look great so hopefully it is the ignition pooping in the punchbowl.
The Engine Dynamics head is saaaaweet.
Old 05-08-2013, 07:50 AM   #7534
mcma111
mcma111's Avatar
Oddometer: 12,928
Try going up a size on the pilot jet. Can't hurt.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 07:54 AM   #7535
Reposado1800
Juicy J fan!
Oddometer: 5,803
I might try that. I think the ignition advance is jumping around and cutting out all together intermittantly. About time to replace 27 year old parts that have been roasted in hell from time to time.
Old 05-08-2013, 08:18 AM   #7536
davek181
davek181's Avatar
Oddometer: 965
A timing light trained on the timing marks while running will show if it jumping around on timing.
davek181 is offline   Reply With Quote
Old 05-08-2013, 12:23 PM   #7537
Reposado1800
Juicy J fan!
Oddometer: 5,803
Engine Dynamics Bling Bling
Here is my engine head all fixed up.
Note oversize exhaust valves.
Old 05-08-2013, 01:35 PM   #7538
mcma111
mcma111's Avatar
Oddometer: 12,928
How about these valves?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 01:42 PM   #7539
Reposado1800
Juicy J fan!
Oddometer: 5,803
What is the secret handshake for that bling?
Old 05-08-2013, 01:45 PM   #7540
mcma111
mcma111's Avatar
Oddometer: 12,928
CASH BABY....Lots of CASH
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 02:59 PM   #7541
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Head work rules
Carter Pewterschmidt is offline   Reply With Quote
Old 05-08-2013, 03:04 PM   #7542
mcma111
mcma111's Avatar
Oddometer: 12,928
Oh Yeah??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 03:06 PM   #7543
mcma111
mcma111's Avatar
Oddometer: 12,928
OK, last one
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-08-2013, 03:24 PM   #7544
Homerb
Oddometer: 471
If the gear on the crank is out of position/time even if you find another gear tooth that is CLOSE to where it should be the balancer WILL be OUT OF TIME with the crank.[/QUOTE]
Thats what worries me Steve, I'll have a look at the crank this morning, and compare tooth positions with the photo Davek posted, and thanks Davek that photo is going to be a great help. I had no idea where the original mark was in relation to the crank.
Homerb is online now   Reply With Quote
Old 05-08-2013, 03:48 PM   #7545
davek181
davek181's Avatar
Oddometer: 965
I looked at the photo you posted way back at the start and it looks from that angle that you may be almost half a tooth off to the nearest one.
I don't think that will make any difference. I know that working on Honda cars with balance shafts one tooth can be felt if you really know the car well. I have had cars come in for their second timing belt and you find that it was off since the last one and there is no complaint of vibration. Their balancer spins at a 3 to 1 ratio and has to be phased on the right third or it shakes too.
I just did a tooth count and the balancer on a 600 is 1 to 1, 41 teeth each.
Times are GMT -7.   It's 12:24 AM.
