Old 08-11-2009, 07:07 AM   #766
crag antler
In the woods lurking
crag antler's Avatar
Oddometer: 535
Originally Posted by mrfixit54016
The charging issue is your stator. Call Ricky Stator and spend $130 for a new one. It will be the best money spent on your XL. Almost everyone on this thread will agree with that...
Good Luck.
-Eric
+1 on the stator. Put in a Ricky and life will be good again
Doug aka crag antler
Florida Cracker in Southern Maine
2011 DR650
2000 Kawasaki Concours
1976 Yamaha DT400
crag antler is offline   Reply With Quote
Old 08-11-2009, 09:47 AM   #767
rickjames
RIP rickjames.
Oddometer: 322
I just went through almost the same deal with my bike.
The oil leak may simply be your drain plug on the left side of the engine by the foot shifter. Make sure you get a fiber drain plug washer and put it on there. It cleared mine right up. Another tip is to use a very thin coat of Hondabond or Threebond on your gaskets. Don't use RTV. The Hondabond is simply a miracle product.
The kickstarter is almost trickier than the cam chain tensioner! Read the manual carefully about 12 times to try and grasp what they are instructing you to do. It won't make sense the first time you read it, but it works.
Good Luck.
-Eric
Used the threebond.
I didn't want to spend the dollars on the stator but I will agree I'm best of to just stop being cheap and just do it
Thanks for the advise mate
rickjames is offline   Reply With Quote
Old 08-12-2009, 06:46 AM   #768
scrminbanshee
Awsome
scrminbanshee's Avatar
Oddometer: 816
Anybody know if the xr600 (what years?) gas tank and the xl is the same....
2000 KTM 640 enduro
1997 KTM 620 adventure
scrminbanshee is offline   Reply With Quote
Old 08-12-2009, 07:03 AM   #769
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 676
Nope, totally different mounting.
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is online now   Reply With Quote
Old 08-12-2009, 10:02 AM   #770
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
He's right, the seat is also specific to the tank, and then the side panels are specific to the tank/seat lines. That's not all, the left side panel for the xr600 is integrated into the airbox as an airbox cover. Then you have no battery compartment. The frame also has different metal for mounting these things. I've thought about doing the whole swap, including making my own fiberglass clone airbox so I could make a battery compartment into the XR one, but I'd need a car first so I have transportation during what would be a huge project.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 08-12-2009, 03:09 PM   #771
mdkm85
uni-cycler
Oddometer: 65
What size tires recommend? I was about to buy a Kenda 130/80/17 but then used my brain and realized that my old cheng sin rubs on the chain guard and is 1/2" more narrow. Anyone running their XL without the chain guard? Im using my brain again and it says this is a bad idea. So yea what size tires do yall run? Another question, when I give my bike gas the headlight gets quite a bit brighter and when it idles it dims, stator problem? I just charged my battery and it is brand new but some electrolyte spilled out when I was driving in my truck (battery wasnt in yet obvisiouly but it ate through my carpet) Electrolyte level is on the lower red line. thanks in advance!
mdkm85 is offline   Reply With Quote
Old 08-12-2009, 06:19 PM   #772
uniter
anti-n00b
Oddometer: 41
Well I was relieved when my freshly rebuilt engine fired up and I was expecting to break it in. I let it idle for a minute or 2 and then turned it off to recheck the oil. It needed more so i put it in.
Went to start it up again, no dice. I noticed the engine was actually quite hot for such a short run-time. I let it cool down, it started up again, this time right when I was about to grab my helmet and take off, it slowed down, I gave it a bit of gas but it still died. Let it cool down again and it fired up again. I gave it some gas but I could tell it wasn't solid, it gave me a couple pops from the exhaust and then died.
I think it's running lean. it's still got the stock pilot, jets are in the mail. When I was rebuilding the carbs I noticed that my jet needles had normal notches and clips; I had read these machines weren't adjustable in this department. I also noticed that the clip was in the richest position. I thought this might be why it was lacking in power before the rebuild so I put it in the 4th groove. I'll change it back to the 5th and I might need to put a washer underneath it.
So much work and money put into this. I was relived when it started up, but I'm ticked that I still can't ride it. It also didn't get the greatest first moments of life. Not the greatest break-in :(
uniter is offline   Reply With Quote
Old 08-12-2009, 07:52 PM   #773
gaspasser
gaspasser's Avatar
Oddometer: 48
hey here are some pics of my 86 xl600r.
gaspasser screwed with this post 08-15-2013 at 06:36 AM Reason: C:\Users\Tim\Pictures\2009-08-12 003
gaspasser is offline   Reply With Quote
Old 08-12-2009, 08:23 PM   #774
mcma111
mcma111's Avatar
Oddometer: 12,571
Start Up
[quote=uniter]
Do you have oil flow to the top end??? Loosen the bolt at the bottom of the oil feed line to the rocker cover and at start up you should have oil very quickly. If not the system needs to be bled...
I noticed that my jet needles had normal notches and clips.
The early XL's had the normal, multi position needle I believe. The later had only one place for the clip. Smog stuff coming into play. OK
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-12-2009, 09:01 PM   #775
uniter
anti-n00b
Oddometer: 41
Does this actually happen? I've never heard of it. I guess I'll check it next time but I did definitely notice that after the first start up that the oil went from top line on the stick to not touching the bottom of the stick.
Something I forgot to mention is that the needle in the secondary carb is really fat and the one in the primary carb is really slender. In my shop manual it says the XR600 needles are set at different notches. The primary is in the 4th groove (from top) and the secondary is in the 2nd.
I'm not sure what to go with. I'll have to put them back in the 5th groove on the primary at least, I wonder what the secondary should be set at. This business of jetting 2 carbs is tricky.
You don't happen to know what they're set at do you?
BTW mine's a 1987 XL600, so it's definitely not an early model. I'm just wondering whether I have to get new needles or if I can use these and just figure out the adjustment.
uniter screwed with this post 08-12-2009 at 09:08 PM
Old 08-12-2009, 10:20 PM   #776
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Originally Posted by uniter
1.) Does this actually happen? I've never heard of it.
2.) BTW mine's a 1987 XL600, so it's definitely not an early model. I'm just wondering whether I have to get new needles or if I can use these and just figure out the adjustment.
1.) It can if the oil pump has been removed and disassembled. Several years ago Honda let a small batch of 650Ls leave the plant with oil pumps that had not been primed and the engines burned up in short order.
2.) I can't be sure if they are orignal or not, but the needles in my father's '84 XL600 are not adjustable. As a baseline, I would start at the 3rd or 4th clip down from the top.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 08-12-2009, 11:45 PM   #777
God of Speed
brrraaaaAAAAAAAP
God of Speed's Avatar
Oddometer: 1,105
im guessing you cant really run the aux lights, main light, indicators and horns at the same time.
unless youve got different rectifier/regulator AND new stator?
sweet ride man.
out of interest why do you need so much illumination and decibels? lots of wildlife round your parts?
- Charlie
125cc Salt Racer - God of Speed Thread
'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.'
'85 XL600R-L-M-PDGSAZ
God of Speed is offline   Reply With Quote
Old 08-13-2009, 12:47 AM   #778
God of Speed
brrraaaaAAAAAAAP
Oddometer: 1,105
and why does you spark plug lead go back to near the carbs rather than up to the cdi?
- Charlie
Old 08-13-2009, 03:49 AM   #779
gaspasser
gaspasser's Avatar
Oddometer: 48
hay the killer deer are out all over pluse back roads are dark,i'm running a 200w stater. 100w for the bike (lights,horns,blinkers) 100w for road lights. the two horns are for city,hwy,lets them know your there. the spark plug wire is a nology hot wire,it is longer than stock, gos with nology high out put coil, got sick of weak spark so put some extra volts. starts first kick most every time. i'm running 142pri 140 sec shimed both carbs,65slow jet,2 1/4 tuns out on mixture. 40 over 11 1/2 to 1 wiseco
uniter, mcma111 is wright ckeck bango fittings top and bottom,and the bolts, had some metal chips in my oil pump (new pump). as far as the carbs make your main jet adjustments first,then mess with the needles. i end up puting my bike on a dyno.
Old 08-13-2009, 04:07 AM   #780
jgrady1982
jgrady1982's Avatar
Oddometer: 783
That suspension link looks sweet! It looks like the one that I made and documented here on advrider. Great looking bike! How much shoter than the origional did you make it? I think that mine came out to about .900 inches smaller.
-Jack
jgrady1982 is offline   Reply With Quote
Times are GMT -7.   It's 06:48 AM.
