Old 08-24-2009, 01:27 AM   #841
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Originally Posted by rolosmoneypit
i need to find a post i saw some time back with a link to an oil temp dipstick. Not the xr only brand one ive heard too many bad things about that one... tahnks
I saw a more recent one in a photo here and it was much improved. It appears to be adequately sealed from oil now, has a knurled body, and a set screw for positioning the dial face to 12 o' clock. Also if you look in my XL600 blog (linked below in my signature) I took mine apart and the oil cleaned out no problem, and I re-sealed it and it has stayed oil-free, leak-free.
As for the other one, I have only seen Waterscm's, and his is in Celsius, I think. I like knowing the ambient temperature of the weather when I fire up the bike in the morning. Helps me remember to grab an extra layer if I need to. If I had one in celsius, the best I'd be able to manage is remembering a safe oil operating temperature range.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 08-24-2009, 01:32 AM   #842
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Originally Posted by UncleDirt
Is that white and black thing right behind the "A" in Honda a cup holder? Coool.
No, I think they had a little aluminum clipboard. This was a race model, remember. This reminds me, I was going to do the little aluminum clipboard too, the size of one of those small notepads for directions. My own little GPS. I could devise a rain cover for it as well for the winter weather up here.
Old 08-24-2009, 05:39 AM   #843
JStory
JStory's Avatar
Oddometer: 2,816
Originally Posted by handirifle
Nice work. Sounds like my kind of "engineering". Did you use the stock headlight switch?
My stock head light switch is long gone. I used an aftermarket switch that gives the option of turning the light off as well as high and low beams.
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is offline   Reply With Quote
Old 08-24-2009, 07:24 AM   #844
Waldo308
Grouchy Olde Pharte
Waldo308's Avatar
Oddometer: 294
Headlight brackets
Originally Posted by JStory
The brackets are made of 3/4 x 3/4 x 1/8 aluminum angle, and 1/8 aluminum plate. I cut the side plates on a band saw, and cleaned them up on a belt/disk sander.
Don't mean to be a killjoy but if you don't mind a little suggestion?
When I fab something up for my bike I always assume that some day I'm going to go down and that part is going to attack me. If it were me, I'd round off the corners on those brackets to at least a 3/8" radius so there ain't no pointy parts to hit you if you ever are in that situation. Hope you don't mind me pointing that out.
Otherwise, I like the simplicity of your engineering. Very strong and functional and the setup looks great.
Waldo
AMA member since 1989
Waldo308 is offline   Reply With Quote
Old 08-24-2009, 12:59 PM   #845
JStory
JStory's Avatar
Oddometer: 2,816
Good idea. I was going to do that. I got in a hurry and had a brain fart. Don't mind the suggestion at all.
Jeff
Old 08-24-2009, 03:03 PM   #846
Bun-bun
Bun-bun's Avatar
Oddometer: 624
I need to replace the chain and sprockets on my '85 XR600R. Does anyone happen to have the torque specs for the sprocket bolts. I found the torque for the rear axle (80-100NM), but can't find the specs for the front and rear sprockets.
Any help is appreciated.
Thanks,
Jeff
Bun-bun is offline   Reply With Quote
Old 08-24-2009, 08:39 PM   #847
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Thanks,
Jeff
Just tighten them. Don't have to "Super-Man" tighten it... more like Super-boy... or Batman.
Old 08-24-2009, 08:46 PM   #848
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,399
Thanks,
Jeff
My 1988 manual says 22 ft/lb. But, it has the 10.5mm bolts; some years have 8.8mm bolts.
It also says to oil the bolts before tightening (I always thought threads were supposed to be dry for torquing.)
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 08-24-2009, 09:04 PM   #849
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
My late '80s XR600 manual shows 33ft-lb for 10mm rear sprocket bolts and the '83-84 XL600 manual shows 20-24ft-lb for 8mm sprocket fasteners. The front sprocket bolts probably fall under the "standard torque values" by fastener size. The spec for 6mm bolts and nuts is 6 to 9ft-lb.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 08-24-2009, 09:11 PM   #850
Zombie_Stomp
Aspiring human
Oddometer: 2,231
You mad rocket scientists.
The XR600 ones are probably tighter because it lacks a cush-drive.
Old 08-24-2009, 09:16 PM   #851
MortimerSickle
Semi-Adventurer
Oddometer: 12,399
This formula is probably as good as any. It is what I used before I finally broke down and got a torque wrench.
G.H.W.S. 1878-1962
Old 08-24-2009, 11:27 PM   #852
UncleDirt
Uncivil to idiots.
UncleDirt's Avatar
Oddometer: 11,748
Cool2
I thought I was the only one who did things by feel around here! Tighten them until they are about to break, then stop. Always been my motto.
_______________________________________________
"I'll say it again: I'll consider corporations individuals when Texas executes a board of directors." ~RandyB
WW/Snoid 2014
UncleDirt is online now   Reply With Quote
Old 08-25-2009, 05:15 AM   #853
crag antler
In the woods lurking
crag antler's Avatar
Oddometer: 519
I use to tighten them until my wrist clicked then I knew I was good
Doug aka crag antler
Florida Cracker in Southern Maine
2011 DR650
2000 Kawasaki Concours
1976 Yamaha DT400
crag antler is offline   Reply With Quote
Old 08-25-2009, 07:56 AM   #854
Bun-bun
Bun-bun's Avatar
Oddometer: 624
Thanks for the help.
Here's a pic of the bike
Old 08-25-2009, 03:37 PM   #855
Waldo308
Grouchy Olde Pharte
Waldo308's Avatar
Oddometer: 294
At my advanced age that takes about 3 inch/lbs and it's going clickety-click, click click.
Got a good laugh outa that one.
Waldo
Times are GMT -7.   It's 05:51 PM.
