Old 11-13-2013, 04:12 AM   #9421
Edouard_Bracame
Oddometer: 86
Originally Posted by Aaron from Texas View Post
Gifted my XL tonight with a set of Renthal RC High's, Full Waffles, and Cycra's...
Aaron,
Can you take a close picture of your engine?
Edouard_Bracame is offline   Reply With Quote
Old 11-13-2013, 07:28 AM   #9422
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,064
Originally Posted by dgman1991 View Post
Hey guys, I just rebuilt the engine on my '84 xl and have about 32 miles on it. Last night as I was riding back from work, I noticed that my left boot was getting wet, but it was dry out. So when I got home I inspected the front side of my engine and it is pouring oil out of it! I have narrowed it down to around the spark plug, it's not coming from the head bolt there and it is not coming from the valve cover gasket... Are there any other areas that I could be missing besides a hole in the head?
If oil is wetting your leg when you ride, you probably have a head gasket leak. A casual leak doesn't really spew over the place as you ride, but when oil is getting forced out by engine compression, that's when things get messy.
Carter Pewterschmidt is offline   Reply With Quote
Old 11-13-2013, 07:30 AM   #9423
crobox
crobox's Avatar
Oddometer: 324
Nice looking bike Aaron. I can't remember if you've posted a picture of it before.
Regarding taller bars... I put on Rox Risers and a set of standard-rise aluminum bars and love the setup. Getting the grips up a few inches higher really seems to help.
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 11-13-2013, 08:00 AM   #9424
AlpinaE24
Oddometer: 561
Found a set of 89 USD CR500 forks/triple on Craigslist for pretty much free. Gonna pick them up just because....I can? I know these are like the worst USD forks ever, but the stem/triple that bolts in to the XL could prove useful eventually.
2001 YZ250f - Plated
1995 Husqvarna WXE250
1985 XL600R - Sold
1994 XR650L - Sold
2000 XR650R - Plated - Sold
AlpinaE24 is offline   Reply With Quote
Old 11-13-2013, 08:07 AM   #9425
mcma111
mcma111's Avatar
Oddometer: 11,865
Good luck getting the brake to work. And the triple stem has a bigger bearing than the XL so it doesn't fit.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-13-2013, 08:17 AM   #9426
AlpinaE24
Oddometer: 561
The stem is the same size though right? So just a lower XL bearing and I
am good? That is what I thought I read in all the pages of BS I sifted through. Only the 89-90 have the straight stem after that it was larger. As for a brake no big deal I can get a complete CR setup for dirt cheap along with the front wheel.
1985 XL600R - Sold
1994 XR650L - Sold
Old 11-13-2013, 08:25 AM   #9427
mcma111
mcma111's Avatar
Oddometer: 11,865
Here's what you do. Look up a Honda parts fich for both the CR and XL stem and bearings and get the bearing # which you will search and get it's spec's. I just went through this with a XR600 I have. PITA!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-13-2013, 08:51 AM   #9428
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
What would you like to see?
I've posted one in the past, when I first "took delivery" of the bike from my dad's garage. Broken turn signals and all...
I just rode to work this morning (39*, by the way ) and didn't really get up on the pegs, but did notice a better feel on the bars. I'll get a good feel when I take her off road next...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 11-13-2013, 09:04 AM   #9429
mcma111
mcma111's Avatar
Oddometer: 11,865
AAron,
I see that you have the auto decom cable installed and not the manual handle bar one. Back in the day we all threw away the auto one and just used the manual one. Made starting after a tumble easier when it loaded up and also to clear it out.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-13-2013, 09:38 AM   #9430
Aaron from Texas
Oddometer: 489
AAron,
That pic was just in the middle of re-assembly. You can see the manual cable hanging down there next to the oil return line. I have since removed the auto cable, as it makes finding TDC thoughtless...
1987 Honda XL600R
Old 11-13-2013, 09:45 AM   #9431
davek181
Oddometer: 838
it's coming from under the valve cover, the bolts are all torqued to spec, the inspection covers are nice and tight, and the clutch mount area is not suspect, but is bone dry. I will get some pictures up shortly
edit:
Uploaded with ImageShack.com
these are the best I can get due to the location.. The grey gasket material is from me when I was applying gasket to the valve cover when I remembered I didn't do it with the engine out of the frame. It got a little messy, but it's sealed along the valve cover mating surface.
The oil has to be coming from the rocker box area somehow. There is no oil near the spark plug. Oil can creep in from remote places. Try the baby powder trick and determine where it comes from. I would then pull the engine and very carefully inspect the cover and head and carefully reseal it.
davek181 is offline   Reply With Quote
Old 11-13-2013, 10:33 AM   #9432
AlpinaE24
Oddometer: 561
Ok so 84-89 CR500s use the same upper/lower bearing as the XL/XR and bolt right on. 87-88 bikes had 43mm conventional cartridge forks(same as later 600/650l) and the 89-92 got 45mm USD showas. 90+ had the thicker stem base.
The forks are not very good, but I bet with a rebuild and new oil they will do better than the 39mm moped specials. They will look cooler at the very least
1985 XL600R - Sold
1994 XR650L - Sold
Old 11-13-2013, 01:50 PM   #9433
KT1
RD07A Adventure
KT1's Avatar
Oddometer: 204
On any Sunday! ;-)
http://www.panoramio.com/photo/99178395
Africa Twin Owner's Club Hungary
Honda MTX-125 -1983
Honda XL600LM -1987
Honda XRV-750 -1998
www.balkanbistro.hu
KT1 is offline   Reply With Quote
Old 11-13-2013, 06:00 PM   #9434
INTMD8
Oddometer: 124
So today I unloaded the xl from my buddies truck (from the Moab trip) onto the lift for our dyno. Then I got the idea to dyno it. Wasn't sure how it was going to work out since it's an automotive dyno. Didn't work great as it spun the tire when I initially hit it, and I didn't have the rpm lead hooked up but at least I got to check the jetting with the wideband. This was with 13/44 gearing, 17psi tkc80 in 2nd gear.
86 xl600r.
INTMD8 is offline   Reply With Quote
Old 11-13-2013, 07:08 PM   #9435
Oddometer: 1,064
34 hp doesn't sound bad. All you have in the bike is a piston and exhaust correct?
Times are GMT -7.   It's 12:24 PM.
