Old 07-28-2007, 07:21 AM   #1
chrishsu OP
Oddometer: 501
Kendon dual standup trailer?
Just bought an used '98 Kendon Dual. I was wondering if I can trailer only one bike, the GS,. I have read/heard that you can have one bike on the Dual but am not sure if it works the same way on the '98 model.
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
chrishsu is offline   Reply With Quote
Old 07-28-2007, 10:52 AM   #2
FlagRS
Gone to the Dogs
FlagRS's Avatar
Oddometer: 1,185
Thumb
Hey Chris,
You got it!
Yes you should be able to trailer one bike at a time as long as it has that Torsion suspension. I have trailerd both the K12RS and the GS alone on one side on my '05 Kendon Dual. I can't tell a difference in the trailer's handling between one bike and two bikes loaded other than the overall weight of the trailer.
But as you know I'm no expert on the '98 model.
Kurt
FlagRS is offline   Reply With Quote
Old 07-28-2007, 02:17 PM   #3
chrishsu OP
Oddometer: 501
Originally Posted by FlagGS
Hey Chris,
You got it!
Kurt
Hi Kurt,
yes, I got it last weekend. It trailered very well behind my SUV. I had to look in the rear view mirrors just to make sure it was still there. It sure is a big differenece from the Uhaul trailer. Really appreciate your help!
I'm just not sure if the '98 model has the Torsion suspension. I put a call into Kendon last week but no one was able to answer that question and the receptionist didn't know either.
I would also like to get a wide ramp that I can ride the GS onto the trailer too. It's not always to be able to find slope to upload the bike.
Anyone knows where to get a wider ramp for the Kendon?
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 07-28-2007, 02:37 PM   #4
FlagRS
Gone to the Dogs
FlagRS's Avatar
Oddometer: 1,185
Does the axle look like this:
There are no leaf springs, just the square axle under the deck and those small arms attaching the wheels. Dexter Axle is the manufacture and the name is stamped on outside of those arms. If your axle looks like that is must be Torsion.
Old 07-28-2007, 02:53 PM   #5
chrishsu OP
Oddometer: 501
Went to the garage to check and it's exactly the same as yours and has Dexter written on it :-)
I also notice on your picture that you have a full-size spare. Mine is a skinny spare :-(. The previous owner did put two new tires on. He also has two pivot wheel chocks.
Do you need to do any maintenance work such as wheel bearing greasing..etc?
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 07-28-2007, 05:53 PM   #6
FlagRS
Gone to the Dogs
FlagRS's Avatar
Oddometer: 1,185
Laugh
From the manual:
  • Wheel nuts and bolts should be checked periodically - 60 ft pounds.
  • Repack wheel bearings after the first 1000 miles and every 2000 miles thereafter. You do not need to remove the hub to re-grease using the EZ Lube System.
EZ LUBE SYSTEM
Lubrication of the wheel bearing is easily applied to the inner bearing which travels to the outer bearing providing ultimate lubrication protection.
1. Remove rubber dust cap. You do not need to remove the hub to repack bearings.
2. Zerk fitting inside.
3. Pump lube grease into fitting until overflow appears on the outer bearing. Do not overfill excessively, inside bearing may push out causing grease to escape and spill into inner wheel.
4. Stop pumping-clean off excess.
5. Replace rubber dust cap.
Old 07-28-2007, 07:14 PM   #7
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 35,372
I have pumped some grease through the bearings of mine a couple times and have never had a problem.
Towing one or two bikes is not a big deal, but when I only tow one, I do rotate from side to side to share the wealth.
The only problem I had was tires - original ones I had weren't right. I replaced them and had the wheels balanced, which isn't common, but makes a big difference when towing unloaded and now you don't even know it's there when you are pulling it.
PhilSpace is offline   Reply With Quote
Old 03-30-2012, 01:15 PM   #8
mudslngr
mud .....a necessity
mudslngr's Avatar
Oddometer: 55
Any one repack their bearings and can provide some guidance? One of my wheels looks to have a runny nose. I need to check if mine is a dexter or tiedown .
There is no greater search in life better than finding fresh mud!
mudslngr is offline   Reply With Quote
Old 03-30-2012, 02:17 PM   #9
chrishsu OP
Oddometer: 501
What year is it? I had a '99 before and '04 currently. Both are Dexters. I have been repacking mine every year or 1000 miles. It took me about 3 hours the first time since I did not know what I was doing. Now I can repack both and wash my hands in under 1 hour.
You will start from removing the hub by using a flat screw driver and rubber hammer to pry the dust cap off. I did take the wheels off the trailer. Your next step would be to take the cotter pin off the Castle nut. After that point, you can slide the entire unit out. I always lay old newspapers on the ground so the grease won't drop on the floor. You can inspect the bearings at this point. I would then clean the entire unit, apply a light layer of grease on before I put the unit back in. The entire assembly can be put in in the reverse order. I would then put the castle nut back on and secure it with the Cotter pin. At this point, I would pump new grease in with a grease gun.
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
chrishsu screwed with this post 03-30-2012 at 02:26 PM
Old 03-30-2012, 02:36 PM   #10
mudslngr
mudslngr's Avatar
Oddometer: 55
2005... thank YOU!
Where did you source your parts?
mudslngr screwed with this post 03-30-2012 at 02:52 PM
Old 03-30-2012, 02:57 PM   #11
chrishsu OP
Oddometer: 501
2005...
Have not had any issues yet that requires parts. The only thing I added to it is the center rail kit for $160. I use the center rail when I only have one bike loaded. It's also much easier with one person loading/unloading only.
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 03-30-2012, 03:02 PM   #12
chrishsu OP
Oddometer: 501
2005... thank YOU!
I just noticed that you are in D.C. I'm in Rockville, MD.
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 03-31-2012, 06:45 AM   #13
Sanders
Stogiesuckingsinglemalter
Sanders's Avatar
Location: Confluence of the Mississippi and the St. Croix
Oddometer: 666
I had one with a Condor chock mounted center. When I hauled the GS thats where I put it.
Just sold the trailer last weekend for exactly what I paid for it 6 years ago. I am regretting it...after 27 years maybe I should have just gotten rid of her
Last edited by Temporal Security Agency: 8-25-2026 at 10:31 AM. Reason: Deleted unlawful reference to future history
Sanders is offline   Reply With Quote
Old 03-31-2012, 06:47 AM   #14
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
You might have my old trailer.
Does it look like this?
[IMG]
From March 31, 2012
[/IMG]
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 03-31-2012, 06:52 AM   #15
Sanders
Sanders's Avatar
Oddometer: 666
Niiiiice!
Times are GMT -7.   It's 12:42 AM.
