Old 03-31-2012, 06:00 AM   #16
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,092
Originally Posted by Sanders View Post
Niiiiice!
Thanks.
I had aluminum blocks machined to fit under the wheel chocks and in the groove of the trailer.
The wheel chocks were too wide to fit in the groove without raising them.
Drilled the blocks and secured it with grade 8 hardware.
Used it a few times (when I had a Harley), but it was really taking up space in the garage.
Sold the Harley and found I just wasn't using it...more riding...less trailering.
Eric B
'06 R12GSA/Hack
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 03-31-2012, 06:25 AM   #17
Tsotsie
Semi-reformed Tsotsi
Oddometer: 776
No need to take the bearings apart if they are fitted with the zerk grease fittings in the center of the axle of the Kendon before each trip. Just a few pumps on the gun is enough to add grease. I always remove excess grease before re-fitting the rubber end plug. Allows for heat expansion (leaks throught the seals) and bearings dont need to be packed solid.
Also, found that it is not wise to carry a full size spare under the trailer if you have two full size bikes (HondaGW and BMW K1200GT) on. You wil drag it at most gas stations!
I had the wheels re-balanced too. The original Kendon balancing was far out.
Apart from that, they are great trailers!
Tsotsie screwed with this post 03-31-2012 at 06:30 AM
Tsotsie is offline   Reply With Quote
Old 04-01-2012, 07:16 AM   #18
chrishsu OP
Oddometer: 445
right, definitely not a good idea to have the spare mounted under the trailer. Can't get it easily if you need the spare with your bike(s) on the trailer.
Chris
09 K1300S
05 R1200GS
04 DR650SE
chrishsu is offline   Reply With Quote
Old 04-01-2012, 08:06 AM   #19
Ride-a-lot
Oddometer: 140
I don't have any trouble with the spare dragging on my Kendon. But then again the two bikes that are on my trailer don't weigh anywhere near what a BloatWing and LightTruck weigh together.
Tom M.
Salem Or.
'93 K1100LT '09 F650GS '08 TE-610
Ride-a-lot is offline   Reply With Quote
Old 04-01-2012, 01:29 PM   #20
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,406
Anyone need one?
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 04-01-2012, 04:12 PM   #21
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,092
Originally Posted by Xeraux View Post
Anyone need one?
Might try taking some pics and posting it on the Flea Market.
Good luck.
Eric B
'06 R12GSA/Hack
Old 05-01-2012, 07:36 PM   #22
RFLIVES
Oddometer: 70
Anyone need one?
pm sent
RFLIVES is offline   Reply With Quote
Old 05-03-2012, 11:04 AM   #23
Twohondas
Twohondas's Avatar
Oddometer: 1,093
I have the new model and I bump the spare even with light hah "KLR" bikes when getting to remote sites.
I installed the factory center rail as well but I did not experience even handling issues when towing my """"BloatWing"""" on a side rail.
Twohondas is offline   Reply With Quote
Old 05-03-2012, 01:03 PM   #24
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,092
My bad.
The trailer I showed in post #14 was a H&H SM2 trailer.
Apologies.
Eric B
'06 R12GSA/Hack
Times are GMT -7.   It's 05:54 AM.
