06-05-2011, 04:59 PM
#1756 |
Oddometer: 402
I reckon the left side of my bike is ideal for expanding the fuel capacity, I have a Supertrapp which makes the whole left side under the seat and sidecover empty. If you fitted a single muffler of whatever type you would have a heap of room on the left side. You could try and fit a Safari rear tank
06-05-2011, 05:03 PM
#1757 |
Dinosaur Pirate
Oddometer: 358
Thanks for that Bounder, I am planing to fit a xr single header and a single muffler, but I plan to use the space left over from the other muffler for tools/spares. The other thought is to build a bash plate that can take tools in it and use the spare muffler area for some water. Undecided on this bit as yet.
Life is an adventure.....live it while your alive....this is not a dress rehearsal Whatever you dream do it now If you love your motorcycle, let it go. If it comes back to you, you've high sided |
06-05-2011, 07:00 PM
#1758 | ||
Sleep, Wrench, Ride
Oddometer: 4,449
If anyone finds a link to that bike (with the DR650 tank), please post it. [EDIT] info from a search: http://www.thumpertalk.com/forum/sho...d.php?t=639720
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
06-05-2011, 07:36 PM
#1759 |
Dinosaur Pirate
Oddometer: 358
Thanks for that pablo83, looks like I am back to contemplating the DR tank. I'll borrow my mates one and have a look.
06-06-2011, 07:49 AM
#1760 |
Sleep, Wrench, Ride
Oddometer: 4,449
Post some pictures if you could.
06-06-2011, 04:02 PM
#1761 |
Oddometer: 8
Hello from Tasmania
Hello to all domi owners out there.
Heres a pic of my domi which I bought a few years ago for my son to ride to get his motorcyle license- but he lost his car license which meant his motorcycle learners was cancelled, and the bike was smoking badly so it sat in the shed for several years. Ive decided to rebuild it and give ita basic makeover, splash some paint about and repair the fairings. Im ready for a dual sport bike, the physical effort of keeping up with the young guns on the twisty stuff is getting too much, sadly there comes a time when I must acknowledge reality. |
06-06-2011, 04:06 PM
#1762 |
Oddometer: 402
Looks like a nasty wheelbarrow crash behind your Dommie
![]() Stick some grippier rubber on the Dommie and you will surprise yourself how well they handle bends. I have Avon Distanzias now and might try the Michelin Anakees next. |
06-06-2011, 04:53 PM
#1763 |
Dinosaur Pirate
Oddometer: 358
I sure will, it'll probably be in a couple of weeks when I fully finish this semester at uni.
06-07-2011, 07:57 PM
#1764 |
Oddometer: 17
Bike stall when stop
Hi, do Anyone encounter this problem.
My is dominator 2000 model. Has been stall at least 5 time whatever I stop. I did the vavle clearance but still Can't solve. Can I check what's the air Screw tune that your have done or what's the standard tune. Pls advice me. Thank you! |
06-07-2011, 11:35 PM
#1765 |
Oddometer: 71
For '00 model air screw initial opening is 2 turns out. Maybe your run too lean.
If it's keep stalling check for any cracks on insulator - put there cigarette and see if it sucks smoke. |
06-08-2011, 12:42 AM
#1766 | |
Oddometer: 17
How to do whether is run on too lean. Where to check any cranks on insultator. Sorry I'm too new on this bike. Thank alot on your advice. |
06-08-2011, 12:56 AM
#1767 |
Oddometer: 71
Insulator (is it correct word for this? manual says insulator..) is the black part between carburetor and engine. If it have a crack, then when you put there lighted cigarette, the smoke will go inside this crack and you will see this. If There is no crack and everything is sealed as it should be, the smoke will go without distortion.
It's hard to say if it's running too lean. You can always richer the mixture by turning out the screw. Try 1 turn out from actual position. The mixture screw is located on carb exit, on downside, similar to this picture: tthis carb is not ours but the location is the same. Try to use just a hand and flat driver bit to turn it out (anticlockwise direction)
06-08-2011, 04:04 AM
#1768 |
Oddometer: 17
hi, Madart
thank for all your info i will try it. |
06-08-2011, 07:23 PM
#1769 |
Dinosaur Pirate
Oddometer: 358
I have been having a bit of a look at frames and the tank mounts
NX650 frame ![]() xr650L frame (I think this is the closest match for the NX) ![]() xl600 frame mounts look to low and forward ![]() xr500 frame (not even close) ![]() I will still borow a dr 30L tank to look at but I think that it will sit to far forward to clear to the oil filler on the NX. I am thinking that the xr650L will probably be the closest match, looking like the original NX front mounts will have to be relocated further forward.
06-08-2011, 07:40 PM
#1770 |
Dinosaur Pirate
Oddometer: 358
DR frames
looks like the big DR tank could be a prob as it does sit much more forwad than the standard DR tank 1990 ![]() 1998
