Old 08-27-2011, 03:35 PM   #1906
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,002
Originally Posted by Bigbird View Post
Got any photos of your set up with the HB mounts and Caribou cases?
Many. I'm still looking for ones with the bags off so you can see the mounts.
Note that I have the horrendously huge and ugly top-loader cases.
Brad Felmey is offline   Reply With Quote
Old 08-27-2011, 04:22 PM   #1907
Bocephous
Bitter Clinger
Bocephous's Avatar
Oddometer: 346
I just got an '88 NX650 and so far I love it. My local Honda dealer has no interest in ordering any parts, etc for a bike that's 20+ years old - tried to talk me into buying a new Honda cruiser ! So, any recommendations on an online vendor that handles service items for this bike? Stuff like oil and air filters, spare key blank, just the basics.
You can get oil and air filters on ebay, Tom. Oil filter is the same as the current XR650L if I remember correctly.
'04 DL1000
'11 GSX-R750
John 14:6 Jesus saith unto him, I am the way, the truth, and the life: no man cometh unto the Father, but by me.
Bocephous is offline   Reply With Quote
Old 08-28-2011, 03:18 AM   #1908
Bounder
ExternallyDisplaced
Oddometer: 922
The oil filter is standard through lots of the Honda singles, HF112 is one code for the filter.
Keyblanks are standard as well.
Airfilters are unique to the NX650, I bought a BMC filter that works well. although K&N make one as well, and I have seen people make foam ones out of foam filter sheet wrapped around the steel inner gauze.
Bounder is offline   Reply With Quote
Old 08-28-2011, 06:59 AM   #1909
Bigbird
"Dog Is My Co-Pilot"
Bigbird's Avatar
Location: The Point of No Return, in the Adirondacks, NY
Oddometer: 440
Question Ortlieb Dry Bags
Bocephus: You can get oil and air filters on ebay, Tom. Oil filter is the same as the current XR650L if I remember correctly. .
Thanks, guys. Any suggestions on a tank bag? Also thinking on using the Ortlieb Dry Bags, if I can rig a rack to keep them off the hot exhausts. Anyone try these?
[http://www.pinterest.com/dudones/
"Keep yer stick on the ice" Red Green
Bigbird is offline   Reply With Quote
Old 08-28-2011, 07:13 AM   #1910
Bigbird
Bigbird's Avatar
Oddometer: 440
Wolfman Expedition Dry Saddlebags for the NX?
Another option might be this:
Wolfman Side Racks
Aerostich lists the side rack for the Honda XL650L only. Work on the NX??? Or make up my own rack
Old 08-28-2011, 10:23 AM   #1911
Bounder
ExternallyDisplaced
Oddometer: 922
Curtis Keyblank # HD75 fits the NX650
Old 08-30-2011, 12:59 AM   #1912
xrsonly
Oddometer: 8
Starting problem
Just today noticed a starting problem. Hit the starter button, hear a click under the seat and no power anywhere. Wait a few minutes and power comes back on and it starts normally. Happened twice today when Dominator was cold. Any ideas?
Triumph Trophy 900, Honda NX650 Domi, 3 X Honda XR250R, 3 X Suzuki RV90
xrsonly is offline   Reply With Quote
Old 08-30-2011, 01:03 AM   #1913
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Check if light and horn works with ignition ON.
Check battery connections. Also, look below the carb: there's a wire connected to the starter motor. Big one, with a rubber boot covering the connection. Remove the rubber boot (DON'T PRESS STARTER WHILE AT IT) and check for rust and/or proper connection. Clean and tighten if necessary. Do the same with the battery connectors.
If no issues then try to wire the starter (the connection under the carb that I told you about) directly to the battery +12. Use a thick wire and MAKE SURE BIKE IS IN NEUTRAL. If it turns the slightest, it's the starter relay. If it doesn't, it's likely the starter motor itself. You'll have to clean it, perhaps replace some innards (innards that you can buy for about $5 at your local hardware store).
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Old 08-31-2011, 07:35 PM   #1914
crashman44b
crashman44b's Avatar
Oddometer: 216
http://cgi.ebay.com/ebaymotors/1988-...item19c8595a17
found this guys on ebay a ilttle down south of me.
crashman44b is offline   Reply With Quote
Old 09-22-2011, 04:34 PM   #1915
mxwalker
Oddometer: 7
Its been quiet on here. Any one seen this custom nx650 http://feedproxy.google.com/~r/Bikee...m_medium=email I quite like it. My 1999 nx650 is in need of some attention in cosmetics. This has given me a few ideas.
mxwalker is offline   Reply With Quote
Old 09-22-2011, 08:52 PM   #1916
madart
madart's Avatar
Oddometer: 72
I love those wheels with TKC's on them (it's TKC, right? ). Rear light and overall 'clean' look.
But does anyone ride them on the street as normal commuter? I'm worried about so small lights and blinkers..
madart is offline   Reply With Quote
Old 09-23-2011, 08:23 AM   #1917
burbansk
Exit222
burbansk's Avatar
Oddometer: 230
Awesome
I love it to! Wish I could put the rear wheel and disc brake set-up on my 88 Domi. Going to try and put a CR 500 front suspension ( USD ), wheel and brake on mine over the winter months. Had a 88 XR 250 R front end on it but it is to soft and not much in the brake department.
Bruce Urbanski, 2000 BMW GS 1150, 2004 Polaris 330 Magnum 4x4, 2000 Honda 350 Rancher.
burbansk is offline   Reply With Quote
Old 09-23-2011, 10:45 AM   #1918
beat
Double Dutchie
beat's Avatar
Oddometer: 88
have a look at this guy
http://www.honda-dominator.nl/Site_p...ide%20Down.htm
he fitted a honda cr upside down in a nx650
beat is offline   Reply With Quote
Old 09-23-2011, 11:06 AM   #1919
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,522
? Please,
Does the NX650 and the NX250 share the same front fender ?
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 09-23-2011, 11:55 AM   #1920
beat
Double Dutchie
beat's Avatar
Oddometer: 88
no, the 650 has a 21" wheel and the 250 a 19"
Times are GMT -7.   It's 01:02 PM.
