Old 01-27-2012, 01:11 AM   #2116
Sherwood
Sherwood's Avatar
Oddometer: 6
Originally Posted by AJ.. View Post
The headlite was done by the previous guy.twin headlite mods and fibreglass onto the oiginal front fairings.
That looks excellent, what bulbs does it use? How are they wired? Cheers
Sherwood is offline   Reply With Quote
Old 01-27-2012, 05:01 AM   #2117
AJ..
AJ..'s Avatar
Oddometer: 1,644
Hi Sherwood,
ok,i've actually just asked he previous owner about the headlens as i am planning to do a project on my XRR.
He told me that the headlens was actually car's foglite.the bulb was modified frm H1 to H4.However,I've yet to go out for any ride with this new purchase.
So the performance of the lighting are yet to be known.
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 01-28-2012, 11:17 AM   #2118
Sherwood
Sherwood's Avatar
Oddometer: 6
Thumb
Hi Sherwood,
Many thanks, keep us posted.
Old 02-01-2012, 12:52 PM   #2119
McVick
McVick's Avatar
Oddometer: 234
Hi guys,
Well I'm planning to tear into my '88 and get her running this weekend, that is if the pulse generator replacement is the solution!
If she get's going I'm the next project on the list is to replace my existing auxiliary lighting.
I'm planning to install some WARN HID lights, one flood and one spot.
Does anyone know what the limitations of the '88 NX650 electrical system are?
- How much does it generate
- How much does it use
- How much does it have to spare for auxiliar add ons....
Brian
Brian McVickers
'88 Honda NX650, '05 KTM 950Adventure, '01 Land Rover DII
www.overlandjournal.com, www.expeditionportal.com, www.overlandrally.com
McVick is offline   Reply With Quote
Old 02-01-2012, 03:12 PM   #2120
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
At 5000 RPM:
NX650 should produce 13.5-15.5 V @ 12 A which would be 180 Watts max
XR650L should produce 14.7-15.5 V @ 13 A, 201 Watts max
These are theoretical numbers based on the bike specs. I have not measured the actual output of the systems. And I don't know what the bike's power usage is.
Other stators that should be the same size as the NX650's:
XR650L, VLX400, VLX600 Shadow, 1983 and up VT400C/Shadow, '83-'86 VT500C/Shadow, '83-'84 VT500FT Ascot, '88 and up VT600C, '89 and up XRV750 Africa Twin, '98 CBR900RW
I don't know the output of these stators, but with enough searching I think you could find a few with higher outputs. The bigger issues is, I don't know if the wiring is compatible. If you found one of these for cheap on eBay, it might be worth a gamble, but I would not spend a lot of money trying to get one of these because there is no guarantee they would work. If they did work, and produced more juice, you might want to use the regulator from the same bike that you got the stator from.
Pablo83 is offline   Reply With Quote
Old 02-01-2012, 03:46 PM   #2121
McVick
McVick's Avatar
Oddometer: 234
Thanks Pablo!
As always you are a master of information!
Brian McVickers
Old 02-05-2012, 04:14 PM   #2122
McVick
McVick's Avatar
Oddometer: 234
Replacing Pulse Generator.
Need to remove the right crank case cover
- Should the gasket be replaced with new or reused?
- Can a liquid gasket be used, like Permatex?
Brian
Brian McVickers
Old 02-05-2012, 05:07 PM   #2123
jgrooms
jgrooms's Avatar
Oddometer: 490
Brian
Replace the gasket so you don't have to mess with it again. How much is a gasket?
jgrooms is offline   Reply With Quote
Old 02-05-2012, 05:48 PM   #2124
FLICKIT
FLICKIT's Avatar
Oddometer: 881
Acerbis
I think I read the later model 1995 onwards (RD08) Acerbis tanks will fit on a earlier 1992 (RD-02) Dominator with no issues..
I can't find the post now, does anyone know if this is right?
FLICKIT screwed with this post 02-05-2012 at 06:09 PM
FLICKIT is offline   Reply With Quote
Old 02-05-2012, 08:09 PM   #2125
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
I try to remove the gaskets carefully because it's a real pain to clean off torn pieces of gasket without marring the metal surface underneath. The most common cause of tearing is when part of the gasket sticks to the case and part sticks to the cover.
If the gasket comes off clean I reuse it. I've never had a re-used paper gasket leak on me. Although I did try and reuse a torn gasket that I reinforced with liquid gasket and it leaked real bad. If the gasket tears at any point I would replace it, particularly if the tear is near the bottom of the engine where it will have lots of oil on it.
I shy away from liquid gasket. When you put it on heavy, so you know there is a good seal, a lot of it squeezes out and that makes me nervous thinking about it coming loose on the inside and maybe blocking an oil passage somewhere.
When I've applied it real light, so you know there will me minimal excess, I've had problems with it not sealing completely. If you do go down this route, use a non-hardening sealant (like Permatex #2). With non-hardening sealant there is less of a chance that excess sealant will plug a passage. Also, really take your time to make sure you have complete coverage with minimal excess.
http://www.permatex.com/products/Aut..._2_Sealant.htm
Old 02-05-2012, 08:39 PM   #2126
McVick
McVick's Avatar
Oddometer: 234
It's running!!
I was going to order a new gasket before starting the job but got impatient!
I went for it and the old gasket came off with the cover completely intact.
I used the old gasket and so far no leaks.
I figure that I'd like to replace the clutch plates sooner than later so I can do a new gasket then.
Thanks for all the help!
Brian
Brian McVickers
Old 02-05-2012, 09:00 PM   #2127
FLICKIT
FLICKIT's Avatar
Oddometer: 881
Honda-bond & Three-bond are good, I think they're actually the same stuff... They peal off nicely, pretty easy stuff to clean up.. (unlike a lot of gasket sealants)
I avoid high temp silicon sealants... The excess always seems to peel off inside the engine... I always cringe when I find slithers of it in oil strainer.... It cant be good when bits make their way through the oil passages and bearings...
With crank case cover gaskets I like to use a decent sealant like Honda-bond on the cover side, and nothing on the crankcase side... The gasket stays glued to the cover and they tend survive a few removals with no issues...
Old 02-06-2012, 06:44 AM   #2128
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
It's running!!
Are your problems fixed?
Old 02-06-2012, 08:00 AM   #2129
McVick
McVick's Avatar
Oddometer: 234
I think so!
I replaced the pulse generator and it fired right up.
I rode it to work this morning and it did just fine.
A little bit more time on it will tell more
Brian McVickers
Old 02-06-2012, 08:38 AM   #2130
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
I think so!
Sweet. I forget, what were the problems you were having?
Times are GMT -7.   It's 08:17 AM.
