Old 10-27-2012, 01:00 PM   #2476
Cruiser
Oddometer: 1,358
if that was closer and I had the cash Id be all over it..
Steve C
04 KTM 525 sx/exc-ds!-its street legal,really officer it is! well..
03 KTM 625-gone....
97 GG 250ec-for sale,, just email me if interested
Cruiser is offline   Reply With Quote
Old 10-27-2012, 01:39 PM   #2477
dstriffler
Oddometer: 386
I'd definitely buy the seat, and maybe all the fairings from you if you're parting it out.
dstriffler is offline   Reply With Quote
Old 10-27-2012, 03:33 PM   #2478
dstriffler
Oddometer: 386
Yeah I had posted one in LA recently, hoping someone would buy it. If I saw one in at least the New England area like that I'd buy it immediately.
Old 10-27-2012, 03:46 PM   #2479
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 687
Mine is for sale in the flea market. It spent most of it's life in upstate NY (Finger Lakes then Plattsbugh). But now it is in Michigan. I could always bring it back to the area if that makes it more appealing.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 10-28-2012, 01:54 AM   #2480
Mike the Yank
Oddometer: 439
Cool2
another one forsale on Au Ebay.
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Old 10-28-2012, 07:41 AM   #2481
Cruiser
Oddometer: 1,358
Your killing me.. always one available when I have no cash... unless you want a 97 GasGas in trade..
Steve C
03 KTM 625-gone....
Old 11-01-2012, 05:06 PM   #2482
Skapegoat
Oddometer: 96
Originally Posted by FLICKIT View Post
Hey John, welcome to the forum :)
You probably know, but I'll mention it anyway.... To check the oil on the Dominator you need to run it for a at least a few minutes to pump the oil up into the frame tank, stop the engine, then check it straight away... It seems best to actually ride the bike a bit rather than just having it sitting idling...
If the oil is dirty, I'd be inclined to change it then check it regularly to see how much it's using... They burn a lot more when the oil gets old and thin...
Mine was using a fair bit, about 1L in 1500km, I found the piston and bore were a bit scored so I did a rebore, new piston, rings, valve stem seals, valve guides... The valves and seats were ok, they just needed a clean up... I also replaced the oil pump because it had digested some metal at some stage...
I've been running Dunlop D606, they are very similar to the MT21 mentioned above... I get about 4500km out of the rears, and about double that from the fronts.... They handle on road and off road well, at around 20-22psi...
Thanks for the tyre advice.
Nice photo, haven't had a second to work on mine yet as I moved house.
Should get a couple of hours this week.
I have managed to change the oil and filters aswell as clean the brakes but haven't driven it since.
I got good second hand exhausts to and Vht painted them.
Sounds a bit quieter now.
I have a Sidestand, seat cover, new battery to get, then to sort and the carb has a flat spot so will clean that too.
After that it's on the road and to the hills.
It's all time and money but she will be flying by January!
Skapegoat is offline   Reply With Quote
Old 11-03-2012, 06:14 PM   #2483
dstriffler
Oddometer: 386
I'm recovering my seat and wondering if there are any replacements for the foam. Are there any different materials anyone has tried, or any way to get new foam?
Old 11-03-2012, 06:18 PM   #2484
mikejohn
mikejohn's Avatar
Oddometer: 1,199
Saw an NX 650 downtown Nashville TN today about 2:45 on 3rd ave, anyone on here?
mikejohn is offline   Reply With Quote
Old 11-04-2012, 01:12 AM   #2485
Bounder
ExternallyDisplaced
Oddometer: 922
Is the whole piece of foam damaged or is it just a section?
You can use an electric knife to cut out the damaged section and stick a new piece in place with contact adhesive.
It can be reshaped with a sandpaper flap disc on a 4.5" grinder (outside) I used good quality commercial grade vinyl to recover one seat, it worked out well, apart from the parts that were sewn.
I would just do it in one piece next time.
Foam should be available from an upholsterer.
Bounder is offline   Reply With Quote
Old 11-04-2012, 04:35 AM   #2486
dstriffler
Oddometer: 386
The foam is fine, its just a little dirty somehow and slightly brittle. I have a sander and the necessary tools to shape the seat, I was just unsure if there is a better material to be used in place of the standard foam. The seat cover I put on should last another 15 to 20,000 miles, so I'd like to have the best material I can. Before I decided to recover the seat I was just going to buy a Renazco seat, but I really like the stock look.
Old 11-04-2012, 10:59 AM   #2487
Bounder
ExternallyDisplaced
Oddometer: 922
There is an inmate here Underground that redid his seat and widened it a little to make it more comfortable.
There is a thread about it.
Old 11-05-2012, 01:18 AM   #2488
Underground
Underground's Avatar
Oddometer: 309
Yep if you look on my build thread you will see what I did and after many thousand hard k's I'm still liking it.Simple but 100% better than OE and so much easier on my old arse.
Build thread is likely to turn into a rebuild thread though....anyone got a good head they want to sell?
'88 RD03 XRV650... X 2
'88 NX 650 Dommie
Underground is offline   Reply With Quote
Old 11-05-2012, 07:09 AM   #2489
dstriffler
Oddometer: 386
That seat looks awesome, how did you attach the extra foam on the sides to the original seat?
Old 11-05-2012, 03:52 PM   #2490
mas335
xendurist
Oddometer: 2,002
http://www.seatconcepts.com/
They don't offer a seat for a NX but they might offer it as a custom cover plus the foam.
I have a NX seat in the flea market that has had the foam replaced with a much firmer and taller profile. Don't know who made the cushion but apparently someone does make a replacement.
Transalps
mas335 is offline   Reply With Quote
Times are GMT -7.   It's 07:26 AM.
