Old 11-12-2012, 05:11 PM   #2506
Skapegoat
Oddometer: 96
I was wondering why my dominators rear running light wasn't working...
I thought it may have been the bulb but it wasn't.
The bulb housing has literally just corroded away so some genius had Sellotaped the bulb in place.
Off to the breakers to mo to see if they have a replacement!
Notice the rusting and rotting brown parts.
Skapegoat is offline   Reply With Quote
Old 11-12-2012, 07:05 PM   #2507
Sierra Thumper
Oddometer: 641
Just Mother Nature reclaiming what is hers
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 11-13-2012, 08:38 AM   #2508
dstriffler
Oddometer: 382
It seems like every bike has some botched up repair job from a previous owner. While I'm working on removing the stain from the speedo plastic, does anyone know to remove this? It appears to be some type of cement holding the bottom of the fairing to the mount. The key is to remove it without damaging the rest of the plastic. I used a grinder to grind it down a lot, but I still have this blocking me from mounting the plastic air guide. I was hoping some kind of solution soak would dissolve it, but not remove the paint from the fairing. If not I suppose I can leave it there and just drill a hole through it. But if something will remove it that would be great, because the previous owner also decided to use this all over the carb to stop a leak. I already installed a brand new XR650 carb, but I still have the old carb, and I'd still like to get it off. I'm also thinking I might find this elsewhere on the bike.
Photobucket
dstriffler is offline   Reply With Quote
Old 11-14-2012, 08:04 AM   #2509
Timieh
Timieh's Avatar
Oddometer: 29
Dear Friends
I don't know what to do next
My other engine of my domi got it complete with a new piston etc.
But 1000km later it also cracked and I was grinding over the floor.
But now I don't trust that engine anymore because it is the 2nd time. So I bought an other Domi for parts and stuff.
And used up the Engine, Everything worked fine until I needed to pull out the air out of the oil pump......
Tryed several things, Now the pump do pump oil throught the under channel [not the left one] So i mounted my oil filter back in place loosen the banjo at the top and started it on the startmotor, No oil coming out. and the battery was getting empty.
Charged it up for 1 day.
The other day I checked again there was oil coming from below, layed down my motorcycle, put the oil filter compartment full of oil, so there is no air inside it. Put my motorcycle upright started it
Waited for some time around 40sec. And there is also no oil comming out off the top.
What to do
The only thing I can think, remove the pump from the engine aind do it like the manuel :S
Trying my best words of English. Honda NX 650 RD08 1996 Dominator
Timieh screwed with this post 11-14-2012 at 10:01 AM
Timieh is offline   Reply With Quote
Old 11-14-2012, 12:18 PM   #2510
FLICKIT
FLICKIT's Avatar
Oddometer: 881
Check the rubber hoses that go from the frame tank to the engine, I have read that can get kinked and blocked off...
Also, if you haven't removed/cleaned the fitting and screen from the bottom of the frame oil tank, it might be worth doing...
There's a vent pipe that goes from the rocker/valve cover to the frame oil tank, I removed that from the rocker cover and put a little air pressure on it to pressurize the oil tank and force the oil through... With a small amount of air pressure, the engine only needed cranking over a few times before the oil is coming out the banjo fitting on the head...
Good luck :)
Edit:
FLICKIT screwed with this post 11-14-2012 at 12:39 PM
FLICKIT is offline   Reply With Quote
Old 11-14-2012, 01:15 PM   #2511
Timieh
Timieh's Avatar
Oddometer: 29
Have tried it with a bicycle pump, That needed to be enough pressure.
But I only did it to control if there is oil coming inside the oil compartment. and that does.
But when i close it up. It aint reaches my head :S ?
Old 11-15-2012, 11:21 AM   #2512
Skapegoat
Oddometer: 96
Recovered my seat today!
It went from this....
To this...
First time covering a seat it's not perfect but better than it was!
And I only stapled myself 213 times
Old 11-16-2012, 12:30 AM   #2513
Timieh
Timieh's Avatar
Oddometer: 29
It looks you did a good job
Old 11-16-2012, 06:51 AM   #2514
Skapegoat
Oddometer: 96
Thanks, it looks better in the photos than real life.
My only tips are put a black sack bin liner under the cover to help it slide on and to start from the front.
Also USe an electric staple gun.
Old 11-16-2012, 02:03 PM   #2515
Bounder
ExternallyDisplaced
Oddometer: 874
Heating the vinyl with a hairdryer makes it easy to stretch as well.
I use a Black and Decker Power shot stapler, its not electric but it puts the weight forward when you use it, not at the back.
I also use stainless staples.
I'll be redoing one soon, as soon as I decide what colour I'll be going with......
Bounder is offline   Reply With Quote
Old 11-19-2012, 07:33 AM   #2516
Timieh
Timieh's Avatar
Oddometer: 29
Pretter handy,
But does someone god the whole one, only found a part of it and nog looking great
Old 11-20-2012, 04:51 AM   #2517
dstriffler
Oddometer: 382
Imagine if these were NX650's
http://cgi.ebay.com/ebaymotors/2-TWO...item43b611695a
Old 11-20-2012, 02:31 PM   #2518
Skapegoat
Oddometer: 96
Originally Posted by dstriffler View Post
Great find, buy them!
Old 11-21-2012, 04:14 AM   #2519
CNRED
It'll be OK
Oddometer: 629
Or even 250's
2011 WR250r
2007 BMW f650GS
1988 Honda NX650 - X2
1982 Honda GL1100 - X2
CNRED is offline   Reply With Quote
Old 11-21-2012, 03:23 PM   #2520
Slim-Line Tonic
Watch time fly...
Slim-Line Tonic's Avatar
Oddometer: 56
got me one too!! an old 89 with a lot of km's (65k)
IMG00074-20121120-1132 by MACK1869, on Flickr
need to get a higher screen too, to get more wind protection...
IMG00075-20121120-1143 by MACK1869, on Flickr
And a mirror too, but i think the screwing bracket is broken too :-s
Slim-Line Tonic is offline   Reply With Quote
Times are GMT -7.   It's 10:21 AM.
