Old 04-28-2009, 07:21 AM   #241
janne.kovanen
Oddometer: 5
Originally Posted by pablo83
Anyone know the rear spring rate?
Original is about 13 kg/mm. Wilbers uses 16 kg/mm for 80 kg driver. So I cutted about one round of. I have excel sheet somewhere where I calculated how much to cut of.
I use africa twin shock with shortened stroke.
If you have other questions feel free to contact.
janne.kovanen is offline   Reply With Quote
Old 04-28-2009, 10:35 AM   #242
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Are you using the NX spring on the AT shock?
Does the AT shock have adjustable compression? rebound? remote reservior?
Pablo83 is offline   Reply With Quote
Old 04-28-2009, 10:51 AM   #243
janne.kovanen
Oddometer: 5
At shock has remote reservoir and adjustable compression. Yes, nx spring in AT shock. AT original spring is about 10kg/mm. I added schrader valve to AT shock and it is serviceable.
Old 04-28-2009, 11:32 AM   #244
ghostrider1200
ghostrider1200's Avatar
Oddometer: 24
New to me NX650
I bought an '88 NX650 a little over a month ago. The bike needed a little TLC but seemed solid. When I got it, it looked like this
I ended up repairing a lot of the plastics - repairing the mounting tabs and cracks. Next on the agenda was to replace all the old rusted bolts with new stainless hardware. Ever bolt that I took out got replaced with a new one.
I was not very happy with the stock headlight, and on my first trip into the woods, a tree took care of that problem. So instead of finding a stock replacement I decided to convert to a dual headlight setup. I bought 2 Trail Tech HID SCMR16 lights. They only pull 30 watts each but output 100 watt halogen equivalent. I bought 1 flood and 1 spot. I modified the stock headlight mount and made a bezel from sheet metal.
After I welded the bezel together, I coated it with Truck Bed liner coating. I wired the flood light to the stock low beam and the spot to the high beam switch. They are really really bright, I have them pointed down and have not had an issue with cars flashing me as of yet. With both of them on - the visibility at night is really really good. One down side of the HID setup is that they are not instant on - they take a few seconds to fully come on.
Next was to raise the front fender. I started off mounting the stock fender higher, but decided that what I really needed was a flat top fender that I could mount to the bottom of triple trees. I found a blue dirt fender at Cycle Gear that I cut down.
Mark
ghostrider1200 is offline   Reply With Quote
Old 04-28-2009, 01:06 PM   #245
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Nice setup, Mark. I like the high fender on this bike and it's such an easy mod to do.
Old 04-28-2009, 06:45 PM   #246
AJ..
AJ..'s Avatar
Oddometer: 1,643
Hello evening to all...
I am back to continue what i have left behind awhile ago...Sold my '95 domi,bought an XRV750,and at the same time, yes...bought back again from the friend who actually bought back the '87 domi his sold me..pretty much confusing i know...
here's the domi that i've got back recently...
since the domi have lost it's original front bits,i am trying hard to recover the front fairings since now i have scored a deal on a used aprilia pegaso fairings
DRZ digital meters holding up.
and the early stage is complete.
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 04-28-2009, 07:21 PM   #247
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
that fairing looks like it's made for the bike. good job
Old 04-28-2009, 07:26 PM   #248
KeithDommirider OP
KeithDommirider's Avatar
Oddometer: 613
Very nice , where did you get the centre stand ?
KeithDommirider is offline   Reply With Quote
Old 04-29-2009, 12:51 AM   #249
AJ..
AJ..'s Avatar
Oddometer: 1,643
thank you doods...
the centre stand from SW-Motech.
Old 04-29-2009, 06:51 AM   #250
bartender
Jack of all trades
Oddometer: 83
looking good man. What crashbars are those?
bartender is offline   Reply With Quote
Old 04-29-2009, 07:43 AM   #251
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,002
They look like the Hepco-Becker ones.
I am off to SW Mototech to see about a center stand!
Brad Felmey is offline   Reply With Quote
Old 04-29-2009, 08:34 AM   #252
AJ..
AJ..'s Avatar
Oddometer: 1,643
yes...the crashbar are from Hepco&Becker...
I apologise for giving wrong info...sorry,i think i've made a mistake about the mainstand...abit confused with the domi and my TDM.
ok,it's "Five Star"
The DRZ meter works like a charm...
Old 05-06-2009, 04:54 AM   #253
AJ..
AJ..'s Avatar
Oddometer: 1,643
I've finally fitted almost all the pegaso fairings onto the NX...except that the front low fender was from XRV750...with some added decals,the bike is hoping not to be mistaken for a pegaso...
the sideboards and tail just needed minimal mods...
what you guys think?
for the better or worst?
Old 05-06-2009, 05:16 AM   #254
KeithDommirider OP
Oddometer: 613
Looks good.
No luck finding a centre stand here , I sent off a few email enquiries and they don't make the centre stands anymore :(
Old 05-06-2009, 09:56 AM   #255
AJ..
AJ..'s Avatar
Oddometer: 1,643
maybe so....as 1yr ago,when i bought my mainstand for the domi that I've sold...i was told that,that was the last piece...
maybe you can try hunt for a used one...
Times are GMT -7.   It's 01:25 PM.
