Old 12-03-2012, 12:30 PM   #2566
Skapegoat
Oddometer: 96
Originally Posted by Bounder View Post
Once you loosen the carb, you can take it out the left side with some judicious wiggling.
What was the jetting in the carb?
148 main jet.
It was more that the pump was stuck seized open!
The pilot was set at 3.5 but I put it back to 3 stock.
It's running a k&n.
I don't know a huge amount about carbs, I have cleaned a good few but generally run them standard.
Seems like its all sorted bounder, no flat spots and a power increase for a 10 can of carb cleaner!
I'll take that any day.
Skapegoat is offline   Reply With Quote
Old 12-13-2012, 03:42 PM   #2567
dstriffler
Oddometer: 373
I just recovered my seat, and made a new passenger strap. But the metal fittings on the end of my old passenger strap were rusted and falling apart, so I couldn't use them on the new one. What can I use? I think if I just put holes in the new strap, they'll pull through and rip it apart.
dstriffler is offline   Reply With Quote
Old 12-13-2012, 03:46 PM   #2568
dstriffler
Oddometer: 373
Heres a pic of what I'm looking for, I circled it in red. I have the bolt, just not the metal that helps hold the strap.
Old 12-13-2012, 04:14 PM   #2569
mcma111
mcma111's Avatar
Oddometer: 12,067
Find an upholstery place and have them pop in a grommet.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-14-2012, 01:10 AM   #2570
Timieh
Timieh's Avatar
Oddometer: 29
Heee Guys
Got a little problem, swapped my engine with a other one on my Domi,
But now when he is warm.
He is working idle, then sometimes he misses 1stroke sometimes the engine even turn off....
Also when i'm riding and stopping at an intersection he switches off, The carb is from the other engine and was working fine, even as the elektronics.
Should it be carb setting's ????
Bst regards
Trying my best words of English. Honda NX 650 RD08 1996 Dominator
Timieh is offline   Reply With Quote
Old 12-14-2012, 02:34 AM   #2571
scrambler66
scrambler66's Avatar
Oddometer: 295
Sounds like it is. The different Domis had different carb settings and jets. And the symptoms you are describing sound very much like air leaking, make sure that especially the carb insulator is without cracks.
And I take it that the swapped engine is also from a Domi, one from a SLR650 or FMX650 will not work because of different pulser bosses
scrambler66 is offline   Reply With Quote
Old 12-14-2012, 09:20 AM   #2572
Bounder
ExternallyDisplaced
Oddometer: 835
Do you really want that strap?
The Euro models never had it, they had a rack instead.
I took mine off, made it much better looking IMO.
Mine is arouund somewhere, if you really want it and I can find it you can pay the postage and I'll send it to you.
Bounder is offline   Reply With Quote
Old 12-14-2012, 09:30 AM   #2573
dstriffler
Oddometer: 373
That would be great! The postage shouldn't be too much, since its just a strap. I'd like to keep it on there since my gf uses it to hold on to sometimes, and it makes a nice handle for moving the bike around in the garage. Let me first check at an upholstery place, to see what they would have. They're kinda expensive, but they should have something that will work.
Old 12-14-2012, 09:54 AM   #2574
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 659
A canvas shop - any place that makes awnings or does boat covers would have the equipment to install a brass or stainless grommet. Check with "tack" shops (places that work with leather, saddles, bridles or other horse stuff).
There's a tack place that I go to locally. They have done everything from replace zippers in Cordura riding jackets, replace velcro on leather riding boots, make some quick disconnect buckle straps for soft saddle bags on my dual sport bikes. These places usually have some old-timers working there who are amazed to hear about knuckle-heads like us who ride off into the woods for days and days. Good folk.
No matter which way you go...it's likely to be cheaper than internation shipping from Europe.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 12-15-2012, 11:08 AM   #2575
MartiniUp
Oddometer: 1,859
I have an '88, where can I find a rear sprocket, and which brand front 650R is best? What other Hondas cross over to the rear? Thanks.
MartiniUp is offline   Reply With Quote
Old 12-15-2012, 12:11 PM   #2576
Bounder
ExternallyDisplaced
Oddometer: 835
XL600R XR600, XR600R all fit the same front sprocket.
XR600R rear is the same.
Old 12-16-2012, 07:58 AM   #2577
dstriffler
Oddometer: 373
I got mine from JT sprockets - they had both the front and rear in varying sizes. I dropped 2 teeth in the back, from the stock 45t to a 43t. Off-road its not as good, but on the highway its a great improvement. I might go back to the stock 45t when it needs to be changed though.
Old 12-16-2012, 01:45 PM   #2578
Pasoren
Oddometer: 13
Colour codes needed!
Hi all! I have a 1994 Domi, red/black, and I only have the colour code for the black parts, not the red. It's similar to the bike in this post: http://advrider.com/forums/showpost....postcount=2563. The black colour is NH-217M, the red colour is not R-201...
Can anyone help? I have checked all the plastic parts, but cannot find any colour codes.... I have found some replacements pieces that needs paint...
Pasoren screwed with this post 12-16-2012 at 02:14 PM Reason: Added photos
Pasoren is offline   Reply With Quote
Old 12-16-2012, 06:27 PM   #2579
dstriffler
Oddometer: 373
I've searched cmsnl.com, and for the earlier years they don't even have complete sets of plastic in one color. I'm pretty much resigned to the fact that anytime you buy fairings and body panels, you're probably going to have to paint them. I believe color rite makes the paint. They have most colors.
Old 12-16-2012, 11:02 PM   #2580
scrambler66
Oddometer: 295
Hi,
the color code your are looking for is
Honda R134 Fighting Red
http://www.colorrite.com/product/hon...g-red-1335.cfm
http://www.motorradlack.de/?s=r+134&x=0&y=0&lang=de
Times are GMT -7.   It's 01:59 AM.
