Old 01-24-2013, 08:52 AM   #2686
scrambler66
scrambler66's Avatar
Oddometer: 310
Originally Posted by dstriffler View Post
I recently bought a set of European handguards for the NX. My problem is that the bolts through the front brake lever and the clutch lever aren't long enough to support handguards. I could order the European bolts from cmsnl.com, but it would be $52 with shipping. Is there a better solution for this? The bolt is not a standard type, so I don't think my local hardware stores would have anything like it. Would a standard threaded bolt work? Here's a picture of what I need:
are you obsessed with expensive import parts, or why don't you take the parts from the XR650L ?
Usually I do it the other way around and buy parts in the US, way cheaper than in Europe
http://www.partzilla.com/parts/detai...3-KF0-770.html
http://www.partzilla.com/parts/detai...4-MK5-000.html
scrambler66 is offline   Reply With Quote
Old 01-24-2013, 09:06 AM   #2687
dstriffler
Oddometer: 378
Ah I can't believe I forgot the new XR650L comes with handguards!!!!
dstriffler is offline   Reply With Quote
Old 01-25-2013, 12:36 PM   #2688
micknmeld
Always in trouble
micknmeld's Avatar
Oddometer: 70
Anyone here able to tell me the suggested fork oil volume and weight for a 89 Domi?
XR650R, own one and only then,....... will you understand why we do it.
micknmeld is offline   Reply With Quote
Old 01-26-2013, 11:26 AM   #2689
Skapegoat
Oddometer: 96
As per 88,89 manual 592cc per fork which should give you an air gap of 120mm
Skapegoat is offline   Reply With Quote
Old 01-30-2013, 12:10 AM   #2690
JSeward
Oddometer: 40
First Engine Rebuild
Hi All
I am a nooby, so sorry if I have hijacked the thread. Tell me to sling it if I have !
I am stripping down an old 1988 NX650 to fix a 3rd gear problem. I am pretty much in to the guts, but am a little stuck with the kickstarter spindle. The freeby manual I have doesnt mention the kickstart spindle or how to remove it. Could anyone give me any pointers ?? any advice much appreciated !!!!!.
I have removed the outer circlip (which is shown on the inside on exploded drawings I've seen ?!) but thats about it.
Cheers
J
JSeward is offline   Reply With Quote
Old 01-30-2013, 12:14 AM   #2691
JSeward
Oddometer: 40
I have a couple going free if you want them (and I can find them!)
Cheers
J
Old 01-30-2013, 12:39 AM   #2692
Timieh
Timieh's Avatar
Oddometer: 29
He guys,
Got a question for you..
Now I got issues to my Carb jet setting's. When idling sometimes he skips 1 stroke :S
The CO screw is too short.
Sow how to handle this? Bigger main jet and idle jet ? [got now 155 / 48]
Got an 1990 engine block, driving in the Netherlands/Sea level
Got an K&N No modifications on the air box, On the RD08 exhaust system there are about 8 extra holes in each exhaust. Think it wasn't loud enough for the other owner of the bike.
You guys got some tips ?
BTW checked for leaks, can't find anything
Trying my best words of English. Honda NX 650 RD08 1996 Dominator
Timieh is offline   Reply With Quote
Old 01-30-2013, 02:52 AM   #2693
Bounder
ExternallyDisplaced
Oddometer: 848
Originally Posted by Timieh View Post
He guys,
Have you tried the carb modifications?
Drilling the hole in the slide to 4mm and putting a small washer under the needle.
That helped with my bike.
Bounder is offline   Reply With Quote
Old 01-30-2013, 05:27 AM   #2694
CNRED
It'll be OK
Oddometer: 604
Originally Posted by JSeward View Post
Hi All
Cheers
J
I'm buiding an 88 as well, not aware of a kick starter on my bike.
2011 WR250r
2007 BMW f650GS
1988 Honda NX650 - X2
1982 Honda GL1100 - X2
CNRED is offline   Reply With Quote
Old 01-30-2013, 05:28 AM   #2695
dstriffler
Oddometer: 378
Cheers
J
Thanks but I was able to get the bolts from a new XR650L and use them.
Old 01-30-2013, 07:23 AM   #2696
Bounder
ExternallyDisplaced
Oddometer: 848
US models never got a kicker, the ROW models got them up to 1995 IIRC.
Handy to have, If I ever split my cases I'll certainly be fitting one.
Old 01-30-2013, 09:29 AM   #2697
JSeward
Oddometer: 40
Yep this is a UK version as far as I can tell. Any idea how it comes out so I can split the case ? I cant see anything holding on from the outside, will it just pull out ??
Cheers
JSeward screwed with this post 01-30-2013 at 10:12 AM
Old 01-30-2013, 06:10 PM   #2698
Honda Scoot
My First Gold Chain
Honda Scoot's Avatar
Oddometer: 364
I have compared the bike piece by piece to the parts fiche. Looks like the spoke sets will be the most costly item required even though the OEM sets from Service Honda are less expensive than the Buchanan's?
Here is the first item made for it. Over sized carbon clean out port covers with US Forest Service approved inconel spark arrestor screens. This should allow 30% of what the headers can flow to bypass one chamber of the the stock RD02 cans.
Honda Scoot is offline   Reply With Quote
Old 01-30-2013, 06:21 PM   #2699
Sierra Thumper
Oddometer: 641
Neat idea
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 01-30-2013, 11:53 PM   #2700
Bounder
ExternallyDisplaced
Oddometer: 848
Cheers
Once the lever is off, the case should just slide over the shaft no?
Times are GMT -7.   It's 08:17 PM.
