Old 03-24-2014, 06:22 PM   #3541
Minidragon
Oddometer: 677
Originally Posted by RadekSkylark View Post
When I bought this bike the where only strange noises in second gear, third seemed to be fine. When I disassambled the engine, there was one tooth broken off of the M2 gear. Then I got spare transmission, which didn't have two gears, M5 and M3. M5 is fine, but as you saw in picture M3 has some damage...
About you NX - do you have engine disassambled? :/ (to check this gear - the difference between old NX and post 91' NX gears as old NX gear is the same as in XR650L - part # are the same)?
Wow one tooth missing on the 2nnd gear and still working..?! Yeah you need to get that M3 gear.
The engine is not completely disassembled..yet..within a couple of weeks,I hope.
Yeah I'll try do some measurements when engine is disassembled.
XR650L-93 Yes
NX650 -93 gone..
NX650 -89 parting out
Honda Dax 125 -74
Minidragon is offline   Reply With Quote
Old 03-25-2014, 09:13 AM   #3542
rangerman275th
Damage Control
Oddometer: 9
So, I have an 88 NX650 here in the San Fransisco area that I am parting out. If anyone has parts they need let me know. Engine has 61,000 miles on it and ran strong before I pulled it out.
rangerman275th is offline   Reply With Quote
Old 03-25-2014, 09:55 AM   #3543
turbojerk
turbojerk's Avatar
Oddometer: 108
Rear rack??
turbojerk is offline   Reply With Quote
Old 03-25-2014, 09:58 AM   #3544
RadekSkylark
Oddometer: 97
If you disassamble you engine in one week, and with help of pictures we check that M3 gear from that gearbox will fit my transmission, I'll buy it for normal price. (USPS international shipping will be required, though).
RadekSkylark is offline   Reply With Quote
Old 03-25-2014, 09:59 AM   #3545
rangerman275th
Damage Control
Oddometer: 9
I should have done the last post better. When I get home I will post a list of parts in the "For Sale" section and link to it.
Old 03-25-2014, 10:38 AM   #3546
rangerman275th
Damage Control
Oddometer: 9
You"ll buy the engine or just the M3 gear? I want to keep the engine intact.
Old 03-25-2014, 11:03 AM   #3547
RadekSkylark
Oddometer: 97
Oh sorry, I tought you'll be disassembling it :(
P.S. I'm interested in gear only! :/
Old 03-25-2014, 11:48 AM   #3548
dstriffler
Oddometer: 373
This is on ebay, not sure if it helps your gear situation at all.
http://www.ebay.com/itm/1988-Honda-N...ab380f&vxp=mtr
dstriffler is offline   Reply With Quote
Old 03-25-2014, 01:05 PM   #3549
RadekSkylark
Oddometer: 97
Thanks, but unfortunately it doesn't :)
Old 03-29-2014, 10:54 AM   #3550
turbojerk
turbojerk's Avatar
Oddometer: 108
No more emissions for this guy! Woot!
Old 03-31-2014, 05:41 PM   #3551
Minidragon
Oddometer: 677
Why not. Those mufflers of yours is a rarity.Cool see something different..
XR650L-93 Yes
NX650 -93 gone..
Honda Dax 125 -74
Old 04-01-2014, 08:36 PM   #3552
turbojerk
turbojerk's Avatar
Oddometer: 108
All done. Completely serviced, de-smogged, carb cleaned jetted and tuned. New hand guards and supermoto fender installed... Need nothing but good weather now!
Old 04-03-2014, 03:24 PM   #3553
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,187
I went to change the rear tire on my NX today and noticed the hub was pretty far gone. The rear pads are good but the hub itself is now bell shaped. I guess some dirt got in there or something, and messed it up pretty bad. I found a few used on ebay, but I'm hesitant to buy a hub used because it would be a temporary fix. Plus I would hope the used hub is a little better than mine. The NX hub is obsolete, as is any similar hub like the XR600R hub, or the Transalp hub. What is the solution here?
That is the exact reason I dont own a NX650 still.
Great bikes, mine Imodded to be my Mexico bike.
Took me all over the Copper Canyon and beyond.
I was looking into swapping out the swingarm, rear break, and rear wheel
with a disc system off a Honda XR400/650.
It can be done, but a real hassle for sure.
Good luck!
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is online now   Reply With Quote
Old 04-04-2014, 01:10 AM   #3554
Minidragon
Oddometer: 677
The hub itself got bellshaped,hm first time i've heard that..but I guess antyhing is possible.. XR600r/XR650L is not the same hub as NX650,and they don't have cush built in like NX/Transalp,so they do get a lot more stress on the transmission and countershaft,results in splittin engine cases and put in new one after a while.I don't know if Transalp will fit.
Let me know if you'd be interested in buying NX (rear) wheel set,preferable to sell as complete wheel set.
And a swingarm(with disc brake)if you'd like
XR650L-93 Yes
NX650 -93 gone..
Honda Dax 125 -74
Old 04-04-2014, 08:50 AM   #3555
CNRED
It'll be OK
Oddometer: 587
PM sent if dstriffler is not interested.
2011 WR250r
2007 BMW f650GS
1988 Honda NX650 - X2
1982 Honda GL1100 - X2
CNRED is offline   Reply With Quote
Times are GMT -7.   It's 04:04 PM.
