Old 07-15-2010, 10:51 AM   #1066
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Originally Posted by switch
You need earplugs...
Exactly. These valve trains are loud. Probably has to do with the extra parts required for the RFVC setup. What should worry you is any type of tapping noise where it sounds like the cam or one of the rockers does not have constant contact with whatever component it's supposed to be in contact with.
Pablo83 is offline   Reply With Quote
Old 07-15-2010, 11:03 AM   #1067
BLM Poacher
Oddometer: 12
88' NX 650 rear brake conversion ?'s
Has anyone updated an 88'Dominator Rear brake drum set up to Disc ?
Will the swing arm work ? What year arm, wheel, brake Work ?
Love the bike, Just want to update the rear Brake !
Ride Stealth ! Poach Often !
BLM Poacher is offline   Reply With Quote
Old 07-15-2010, 11:06 AM   #1068
BLM Poacher
Oddometer: 12
88' NX 650 rear cargo Rack ?'s
Looking for a Rear, Cargo Rack ? OEM metal rack.
Old 07-15-2010, 12:34 PM   #1069
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
There seem to be widely differing opinions on this. The valvetrain in my 600 never made any noise with the stock cam and the valves have never been out of spec since I bought it in '04. The Hot Cam calls for slightly wider clearances and results in a little more "sewing machine" sound, but it's not something I have to make myself ignore. IMO, the valves should not make a lot of noise.
Something else that comes to mind is a noisy automatic compression release.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 07-15-2010, 01:40 PM   #1070
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 438
Another source of noise in this engine is the cam chain. The tensioner is spring loaded and held from rebounding back by a one-way clutch. This item can go afoul and sound a lot like valvetrain noise. Mine is most noticeable when cold. This is on the list to get replaced when the top end eventually comes off.
Piston
PistonPants is offline   Reply With Quote
Old 07-15-2010, 03:58 PM   #1071
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
That's interesting, I've always thought my NX650 and both XR650Ls had noisy valves. At first I check and re-checked them to make sure everything was okay. I eventually got used to the sound.
Describing it as "sewing machine" like is very accurate.
Old 07-18-2010, 03:55 AM   #1072
jj5
Oddometer: 144
anyone here has a example of alternative blinkers at the front of a dommi? I currently have none and i want to mount some led blinkers but i cant realy think of a good spot. Only option i can think of is drilling some holes but im hoping for something less permanent
blinkers:
jj5 is offline   Reply With Quote
Old 07-18-2010, 11:45 AM   #1073
jj5
Oddometer: 144
nvm ordered tusk d-flex handguards with build in blinkers
Now all i need are bigger footpegs the standard footpegs are made for people with very tiny feet
Old 07-19-2010, 03:20 AM   #1074
zoki1
zoki1's Avatar
Oddometer: 128
thanks for your information
zoki1 is offline   Reply With Quote
Old 07-19-2010, 01:08 PM   #1075
BLM Poacher
Oddometer: 12
Dominator Bone Yard ? Used part's ? ?
AnyBody know of any NX650 Bone Yards ?
Old 07-19-2010, 01:16 PM   #1076
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
eBay.
There are no NX650 specific salvage yards are parts stores.
Old 07-19-2010, 02:29 PM   #1077
BLM Poacher
Oddometer: 12
Bone yards ?
I just keep Looking for Part's ?
I may have to Build a REAR cargo Rack.
So, has anyone Converted the Older Rear Drum Brake bike to a Disk Set-Up ?
I want those part's as well !
Old 07-19-2010, 03:00 PM   #1078
jj5
Oddometer: 144
The early dommies in europa had disk brakes. Dunno if you can use those parts?
Can you make a 12V power socket on the dommi to power a GPS or phone?
Old 07-19-2010, 03:03 PM   #1079
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Swingarm, rear wheel hub + spokes, brake disk, brake caliper, caliper mount, hose, pump, remote reservoir, brake pedal. I could help you there, but overseas shipping is really out of the question - financially-wise.
Sure. Just get yourself one and mount it. How is another question. Need any assistance?
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Old 07-19-2010, 03:08 PM   #1080
jj5
Oddometer: 144
yes little more info about how it is done would be welcome.
Times are GMT -7.   It's 01:09 AM.
