07-29-2010, 06:54 AM
#1156 | |
Oddometer: 233
Thanks. Do you know of an example of such a Filtration/regulation mechanism? The lights are 12v designed for vehicle/moto use. I've had them, same lights but not exact same units, on a Jeep and on a DR650 direct wired with no issues. Thanks allot for the help on this!
Brian McVickers '88 Honda NX650, '05 KTM 950Adventure, '01 Land Rover DII www.overlandjournal.com, www.expeditionportal.com, www.overlandrally.com |
07-29-2010, 02:42 PM
#1157 |
Oddometer: 47
Evening Gents,
Friend and I finished building an 1991 XR - 1996 dominator hybrid, making what we think is a practical rally bike Bike was running great so we thought we would experiment with using the XR carb and fitted it last night after a thorough clean. Bike runs fine up to 3,000 revs then bogs on the XR carb Before we start messing around with jets and needles has anybody fitted an XR carb to a dominator and gone through this process?Cheers |
07-29-2010, 02:57 PM
#1158 | |
Sleep, Wrench, Ride
Oddometer: 4,444
That XR600R carb is a non-pumper, slide-carb, right?
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
07-29-2010, 02:59 PM
#1159 | |
Sleep, Wrench, Ride
Oddometer: 4,444
Also, you should check the voltage when the bike is running vs voltage from just the battery. It's possible the regulator is going bad.
07-29-2010, 03:09 PM
#1160 |
Oddometer: 47
Pablo, correct the carb is from an XR600 and yes its a slide carb.
07-29-2010, 03:36 PM
#1161 | |
Sleep, Wrench, Ride
Oddometer: 4,444
I guess a massively undersized (or clogged) main jet could cause that. If the choke is stuck open, maybe that could cause it too.
07-29-2010, 03:48 PM
#1162 |
Oddometer: 47
Pablo, carb was thoroughly cleaned and full functioning before being put in bike.
I'll let you know he results of tweaking carb over the weekend. |
07-29-2010, 04:16 PM
#1163 | |
Oddometer: 179
07-29-2010, 05:31 PM
#1164 | ||
¯\_(ツ)_/¯
Oddometer: 1,246
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
07-29-2010, 05:50 PM
#1165 | |
Sleep, Wrench, Ride
Oddometer: 4,444
07-30-2010, 05:17 AM
#1166 |
Oddometer: 47
XRinator
Were at the same offroad site again next Tuesday, so I will take more detailed photos.
The bike uses all the XR600R running gear, frame, seat, acerbis tank, plastics etc. the Dominator motor, front fairing, loom, front mudguard, carb. Custom battery box under rear mudguard So what do you get if cross and XR600R, Dominator, Hearse and an H&K MP5 ............... you get an XRinator!The original XR was swapped for a hearse bought for £100, the dominator was also purchased for £100, the Acerbis tank was swapped for a H&K MP5 (repilca) . Bar that it was a pretty straight forward build.
07-30-2010, 07:49 AM
#1167 |
Oddometer: 144
Sounds good. Got any building pictures?
07-30-2010, 07:44 PM
#1168 |
Sleep, Wrench, Ride
Oddometer: 4,444
General information on worldwide model year changes to the NX650
Originally posted by Switch on www.xrv.org.uk CHARACTERISTICS OF EACH "GENERATION" (specifications similar to previous years, unless specifically mentioned as a change): 1. 1st generation / version 1 (also made for US) - 1988 RD02 designation type 1 fairing + seat turn signals external from fairings golden rims square-base end cans with golden caps long carb 'neck' (intake manifold) 13L fuel tank Nissin front (disk) brakes drum rear brakes front sprocket countershaft with 7 teeth kick-starter 'short' pro-link rear shock rectifier mounter on the back of the airbox fuse box with 3 fuses + 1 or 2 diodes (unsure where they switched over - perhaps the one with a single diode doesn't have a sidestand cutoff switch?) 2. 1st generation / version 2 (european) - 1988 -> 1989 disk rear brakes (Nissin) 3. 1st generation / version 3 - 1990 - 1991 removed kickstarter (can still be added with some work) front sprocket countershaft with 14 teeth 4. 2nd generation / version 1 - 1992 -> 1994 type 2 fairing + seat removed possibility of adding kickstarter (modified engine block) turn signals integrated into front fairings turn relay now has 3 terminals (extra terminal connected to ground) 16L fuel tank w/3 mount points for each front fairing fuse box with 4 fuses and no diodes 5. 2nd generation / version 2 - 1995 RD08 designation (VIN starting with ZDCRD08...) front right footpeg mounting changed round end-cans with silver caps short intake manifold "long" pro-link rear shock (actually frame mount 1 inch higher) redesigned airbox (same air filter though) repositioned rectifier from rear of airbox to under the luggage rack (also longer wires on rectifier) 6. 3rd generation / version 1 - 1996 - 1997(some) type 3 fairing (seat compatible with type 2) silver rims turn signals external from fairings 16L fuel tank w/2 mount points for each front fairing and slightly offset bottom mounts 7. 3rd generation / version 2 - 1997 -> 2003 Brembo brakes EXTRA THINGS THAT WERE CHANGED: ALL YEARS: seat height - the claimed seat height varies wildly between 82cm and 89cm; I don't have exact info ALL YEARS: Honda tuned the carb settings a LOT, based on year and country of export; main jets vary from 140 to 160 (all valid stock sizes). Idle jet is 50-55 all the time, I believe. Air screw settings are a mess. LATE YEARS: Honda apparently messed with the camshaft or valvetrain; the is a POSSIBILITY that newer than 1997 bikes need 0.10mm of exhaust valve lash instead of the 'standard' 0.12mm; this is UNCONFIRMED LATE YEARS: somewhere along the way, the crank sensor was changed from single-pickup single-sensor to a multi-pickup single sensor setup; result is that new and old ignitions don't quite match; bike might run but will show wrong RPM; use at your own risk or ask beforehand EARLY YEARS: it's unclear to me what Honda did to the rear shock mount on early models; I've seen three frames (91, 90, 96) that have different rear shock mount height, measured directly against the lower lip of the headstock Things NOT related solely to production year: parking lock (locked handlebar with position lights on) -- this is specific to Austria, I believe smog pump (externally mounted on the left side of the cylinder) -- no idea on specifics here - US California has it, but also some EU bikes luggage racks speedometer markings (km/h, mph) -- related to US/UK models, likely front headlight protector -- must've been an optional for 1st generation models, either OEM or aftermaket sidestand switch, either as a simple warning light or as an engine cutoff (1st generation only, but unsure of years/coutnry - later models include the full package: warning light + engine cutoff)
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 Pablo83 screwed with this post 08-10-2011 at 07:21 AM |
07-31-2010, 03:34 AM
#1169 |
Oddometer: 144
great list.
Never occurred to me the 1990+ had bigger tanks i thought it was a mistake in spec list of various websites :P oh well in return i have a kickstart |
08-03-2010, 02:02 PM
#1170 |
Oddometer: 47
XRinator pictures as promised
![]() ![]() ![]() Put the Dominator carb back on for now until the new jet and needle arrive for the XR carb. Unfortunately i have not got to drop the engine out again as shortly after these photos Phil flipped it and bent the gear selector shaft
