Old 12-24-2010, 06:52 PM   #1366
mikejohn
mikejohn's Avatar
Oddometer: 1,188
Ok, i been saving my spare change over the last year, you know, come home drop it in a jar, well i figure i have about $400-450 saved up, i would like to get a carb to replace the cv carb that is on the 88, which after market carb to go with.
thinking about making this NX into HALO Light Scout Bike, usine matt black and matt green paint, i have a set of KTM forks that i am planning to use, i will have to build a new set of triple trees, i am going to run a 17 inch wheel up front, when i get ready to do the build i will post photos
mikejohn is offline   Reply With Quote
Old 12-24-2010, 06:59 PM   #1367
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,269
Looks great! Nothing like taking a simple bike and making it even simpler.
Brillant!
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 12-25-2010, 07:43 PM   #1368
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
Originally Posted by backttracker View Post
What i did to the dominator!!!
http://nx650elsinore.blogspot.com/
Nice writeup. Thanks for sharing. I'll be doing an XRV street tracker project soon. Your article has a lot of good info.
Pablo83 is offline   Reply With Quote
Old 12-26-2010, 12:51 PM   #1369
rangerman275th
Damage Control
Oddometer: 9
I picked up an 88 for $200, runs strong. I was planning to take it away from its root and do more of a flat tracker, but wasn't sure if the Dommie's would berate me for doing such a thing. After seen that sweet bike, I may have to do a write up.
rangerman275th is offline   Reply With Quote
Old 12-26-2010, 04:26 PM   #1370
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
please do
Old 12-28-2010, 06:49 AM   #1371
Dan_Blomgren
Ragnarök
Dan_Blomgren's Avatar
Oddometer: 22
Winter riding
Just wanted to share that the Dominator indeed is a very fine bike for riding wintertime.
Best regards/Dan
(pic from yesterday)
/Dan
R1200GS-10
Dan_Blomgren is offline   Reply With Quote
Old 12-28-2010, 07:03 AM   #1372
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Nice!
I personally prefer a fully tacked (i.e. 100 snow tacks per wheel) Husaberg for winter roads
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Old 12-28-2010, 08:06 AM   #1373
Dan_Blomgren
Ragnarök
Oddometer: 22
Originally Posted by switch View Post
Nice!
Husaberg is a nice ride!
I use TKC 80 with approx 220 studs in each wheel.
Makes a very good ride on icy roads.
/Dan
/Dan
R1200GS-10
Old 12-30-2010, 04:24 PM   #1374
outback96
Oddometer: 15
does anyone know if the NX650 motor will fit into a xr600 frame? Thanks
outback96 is offline   Reply With Quote
Old 12-30-2010, 04:31 PM   #1375
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Maybe.
The engine in itself WILL fit the frame. Fittings and supports (i.e. engine mounts) are in the same positions throughout the history of the less-than-modern XR/XL/NX bikes. NX650 and XR600R differ only through cylinder/piston dimensions, camshaft profile and electro starter gears. Maybe decompression mechanism but I'm not sure of that.
Two things you will have to consider: NX needs room to accomodate the electric starter, directly behind the cylinder, on top of the crankcase and somewhat below the carb.
Also while the motor might fit, most other things (airbox w/ battery holder comes to mind) are almost guaranteed not to.
Old 12-30-2010, 05:38 PM   #1376
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,260
If it's a 1988-2000 XR600, then yes, it will drop-in for the most part. Except for the starter itself, both engines have the exact same external dimensions. You will need to use the 600's stator and accommodate the NX's lack of a kick start.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 12-30-2010, 06:24 PM   #1377
outback96
Oddometer: 15
thanks for the information. trying to plan out a build and after checking classifieds there's a considerable cost difference between the two frames. I have the NX already but if my motor will slide in the xr frame, then I wouldn't have to tear apart to build up.
Old 12-30-2010, 07:08 PM   #1378
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
As the others said, if you're using the NX intake and exhaust you should have minimal problems fitting the XR engine in. The only place I think you'll have an issue is with the rear brake switch. It sits right where the XR's kickstart lever will sit. If you weld, or know someone who does, the switch bracket can be moved somewhere else. Even if welding isn't an option you can probably reattach the switch to the back of the frame tube using a hose clamp and maybe a screw to keep the clamp from sliding up and down.
Some non-US model NX's came with a kickstart. Can someone who has one of these tell me where the rear brake switch mounts on these bikes?
Old 12-30-2010, 10:29 PM   #1379
RED1
Oddometer: 493
If you want to put a genuine brake light switch holder on an XR600 use part No 7, 35358-MK2-650ZC, you can get from australia or europe as they had them fitted in those countries.
This is the australian model drum brake, kickstart 88,89 NX650, you can order parts from cmsnl in europe.
RED1 is offline   Reply With Quote
Old 12-31-2010, 12:23 AM   #1380
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
If you plan on using from the NX, you need to use the following:
- Engine
- Carb
- Electrics (CDI, battery, charging regulator, handlebar controls, lights, turn sigs)
- Airbox (this is very important as you can't use an XR/XL airbox with NX carb)
An the XR parts you will want, and their problems:
- Frame (problem: no fitting for NX airbox/battery holder)
- (maybe) Wiring harnass (problem: not compatible with the NXs electrics)
- (maybe) Exhaust (problem: not compatible with NX airbox)
- (maybe) Rear shock (problem: not compatible with NX airbox)
Times are GMT -7.   It's 01:13 PM.
