Old 10-03-2014, 07:24 PM   #1
jtwodogs OP
Oddometer: 30
Does this look like the engine has been cracked open
Looking at a used 2007 bandit. Below are some pics of the right side of the engine with what looks like some sealant that has oozed out. Does not look like factory. Just wondering some opinions were?
Anyone know what that cover, covers?
jtwodogs is offline   Reply With Quote
Old 10-03-2014, 07:45 PM   #2
beemerkid
Do you ADV
Oddometer: 932
First, that thing looks really clean for an 07. The sealant might be factory, I have some oozing out of the case pieces on my Ducati I bought new, sloppy but it happens, even in the factory. Is it the same color as other sealant on the engine? As for what the cover covers, I cant speak to that but a cover coming off of something isn't always an indication of something horrible. Maybe thats where you turn the engine from for valve adjustments?? Or just routine or light corrective maintenance? Did you ask the owner?
Originally Posted by Mr.Grumpy View Post
I swear to God that I will beat you senless with a Sanka can before I die.
beemerkid is offline   Reply With Quote
Old 10-03-2014, 08:02 PM   #3
jtwodogs OP
Oddometer: 30
Not really concerned about current owner. He has been more then forthcoming with all details.
He told me owner before had replaced fuel pump. Not sure what all else the owner before had done.
Old 10-03-2014, 08:06 PM   #4
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,657
That's the clutch cover and the gasket is installed dry from the factory.
Old 10-03-2014, 08:08 PM   #5
mcma111
mcma111's Avatar
Oddometer: 12,091
Sealant at the case split before the side cover is installed. Normal.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-03-2014, 08:22 PM   #6
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,740
Looks normal for factory. As clean as that thing is, and how the bandit motors are, Id buy it if it runs good. They're pretty hard to kill motors.
FWIW, a dealer could've opened it up for a post purchase service. Heard of a few cracking up both covers to verify tightness of the internals on the first service for warranty. If it doesn't leak, I wouldn't bother nit picking it that much.
That's your clutch cover FYI. You SHOULD remove it from time to time to check your clutch springs.
Danjal is online now   Reply With Quote
Old 10-03-2014, 08:34 PM   #7
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,657
Oh that's right, those have an oil pan style main case.
Old 10-04-2014, 04:34 AM   #8
jtwodogs OP
Oddometer: 30
Thanks for the much needed info. Great having this wealth of knowledge at my fingertips.
Yea, the owner of it now seems like a great guy and has been very forthcoming with all info., I was just concerned that maybe a PO had been into something, but obviously it can be a routine type thing, so you guys have helped alot.
Old 10-04-2014, 05:25 AM   #9
sander
sander's Avatar
Oddometer: 313
I'm pretty sure you take off that little cover for a valve clearance check. So depending on mileage it's a good sign.
sander is offline   Reply With Quote
Old 10-04-2014, 06:39 AM   #10
jtwodogs OP
Oddometer: 30
Thats even better! Thanks Sander.
Old 10-04-2014, 08:17 AM   #11
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
wealth of knowledge? youve had a couple guys tell you its a clutch cover, its very obviously not.
i did a little googleing and cant tell whats all under there but its a crankshaft cover. maybe for turning the engine for timing and valve checks as mentioned, but i dont know for sure.
2 SPOT is online now   Reply With Quote
Old 10-04-2014, 09:04 AM   #12
jtwodogs OP
Oddometer: 30
Thats why I asked, I am ingnorant of what it covered, I just assumed the people chiming in were knowledgable in that particular area. I guess if it does go to the crank, and a valve check was done, that is a good thing.
Old 10-04-2014, 09:14 AM   #13
kiwi_outdoors
kiwi_outdoors's Avatar
Oddometer: 108
yup-crakshaft cover - see link below
http://www.bikebandit.com/oem-parts/...7585#sch554040
kiwi_outdoors is offline   Reply With Quote
Old 10-04-2014, 11:06 AM   #14
Tweaker
Oddometer: 9,468
Yea, amazing. Give them the benefit of the doubt that they didn't bother looking at the second picture. This is why you let a thread ruminate before taking any chances.
Tweaker is offline   Reply With Quote
Old 10-04-2014, 08:14 PM   #15
EmBeeZedEx
Oddometer: 122
ah damn, I'm too slow... clutch cover is to the left in the pic... was fiching up what IS under there. Beemerkid has it, that's where you turn the motor by hand when checking valve clearance
EmBeeZedEx is offline   Reply With Quote
Times are GMT -7.   It's 04:06 PM.
